Question about Philips Magnavox 51MP392H Rear Projection Television
The problem with your TV
Mine is having the exact same problem! Has anything helped?
Jeff,
Mine is due to failed convergence circuits. Two chips need replaced. See best solution posted by richcradio below. Different model but same fix. If you can solder it's a fast, cheap repair. If not, I've been told it's somewhere between $400 - $600 for the repair dude to come and take care of it.
Good luck
Best Solution posted on May 09, 2008 The problem with your TV - 4%20stars.png
richcradio
Rank:expert_s.gif Guide
Rating: 92%, 11 votes
I had the same problem where all of a sudden it started bowing on top and bottom and the colors were bad. I read on here and other sites about the 2 convergance chips so I figured why not try as the tv was going to get thrown away because I could not find anyone that would touch it. Well I ordered 2 stk392-120's (I know others are saying use the 150's or 180's but I just wanted to put the same ones that were in there) I ordered them from electronix.com for 9.99 each plus 6.60 for shipping they took 3 days to get here and I installed them tonight and it worked great. The whole thing took only about 2 hours from start to finish. Here's a couple of tips....the chips are on the far left when looking at the tv from the back, make sure you mark with a marker where the wires go that you have to unplug as there are about 10 of them, each chip has 19 pins that you will have to soder make sure you have a soder ****** to get all the old soder up as you are heating them up, after you are done puting it back together leave the back cover off and turn it on, then go into your menu and go to pictureand go to manual converge and go to undo multpoint and restore factory as this will reset it all. Then if your color is still a little off as mine was there are 6 knobs in the back of the tv by the chips you were working on, find a channel with a lot of colors and try adjusting the top 3 a little at a time till you get the right color that you like. This should do it. It took 26 bucks and 2 hours for me to fix a tv I was ready to replace, thank god for the internet to be able to look stuff like this up. Good luck!
Posted on Aug 21, 2008
SOURCE:
I need a user Manual for a samsung plasma TV 42
if it is anything like mine you have to find the input you connected it to. use the source button on your remote or the source button on the TV . mine is the top button on the right side of the TV when you are facing it. Hope this helps
Jan 06, 2012 | Samsung Televison & Video
Just moved my tv (jo47baird) from 1 side of the room to the other now it wont switch on just the red standby light on it power botton dont seem to do anything.
my tv has done the exact same as yours has I have worked the problem down to 2 things it could b the LDVS board that you can buy for around £20-£25 or it could be or it could be the inverter and you can pick one of those up for £45-£60 hope that helps once I have fixed mine I could tell you what it is for certain
Dec 28, 2010 | Televison & Video
My television is a Samsung Slimfit tx-t2782 and I'm having problems with the tv staying on. Everytime I plug it in it comes on for a few seconds it shuts itself off. I was wondering if there is anything I...
I AM HAVING THE EXACT SAME PROBLEM WITH MINE ! But before mine turns off, it shows a blurry squiggly red mark on the screen then shuts off and wont turn back on sometimes for several hours.. And everytime I CAN get it back on, I have to unlpug the whole thing and plug it back in...
Nov 09, 2010 | Samsung SlimFit TX-S3082WH 30" TV
TV switching to standby
Hi.i had exactly the same problem with my bush 37 inch lcd tv and i took it to a friend of mine who is a t.v electrician he said it was a component in the back of the tv which he replaced and its now working fine.
Jul 05, 2009 | Televison & Video
MY LG 42 INCH LCD WAS DAMAGED THE SCREEN AN OBJECT WAS THROWN AT IT
it depends on the severity to know what all is damaged, is the "object" embedded in the screen still, did it crack the screen, do you see anything on the screen, And we will need to have the exact Make/Model of TV to suggest any parts or prices/repairs, I'm sorry that happened to you, I am ultra paranoid about that happening to mine (52"), I hope this helps, please give a fixya rating if it helps solve your problem
Jul 04, 2009 | LG 42LC2D 42 in. LCD HDTV
Hey Watch IT!!!!
Sorry BG but i saw your post only after posting mine.
I have not done anything wrong.
Sep 04, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Tv wont turn on help me plz
Can you describe exactly what happens when you unplug it for 5 minutes then plug it back in and then press power. Explain the sequence of events that happen if any.
May 13, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Sharp TV switches to "input 2"
Mine does the exact same thing. I've had it for a few years no, and it just started doing this. It's so annoying. I don't think the weather has anything to do with it, though. It started switching itself just every once in a while, not it is almost every time I turn it on. Sometimes it takes an hour or so to start doing this, other times it's right away. Help!!
Jan 20, 2008 | Sharp 32C-240 32" TV
Tv not working
i have the LC-26GA4U LCD TV & mine has the exact same problem. I brought it to an authorized sharp tv repair shop it turns out its the LCD panel. the panel costs $1700 & with labor installed it comes to $2055.43. almost exactly what I paid for the tv 2 years ago. good luck. Mike
Jul 11, 2007 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Scrolling through menu on it's own
I'm having the same exact problem. does anyone have suggestions? mine is going through the menu and other video ports without cause. mine is also about 2 years old and started doing it today. its always been in a dust free clean enviorment. please please please help.
Jan 15, 2007 | Toshiba 35A44 35" TV
Philips Magnavox 51MP392H Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
