Question about Pyramid - PS21KX 20 Amp Power Supply Car Audio Amplifier
Hello, I have a pyramid power supply(PS-52KX), that recently started with a overvoltage problem. I run a Galaxy DX94 HP 10 meter transceiver, and just recently, when I key up the radio, the voltage goes from where I set it(around 14.5 VDC), to wide open voltage. I have recently replaced the TIP41C transistor, and the NTE 5554 Transistor (crossed referanced part number), on the small output board, that goes to the power posts. Still the problem remains. I'm not sure where to go from here. Any help would be greatly appreciated. I don't mind removing and replacing compounents. I just can't have my ham radios on and overvoltaged power supply. Thank You. Best Regards, Chris ---------------
  • 631 Answers
I'm not sure what you mean by 'wide open voltage'. If it's over 17v, the supply may have multiple problems. I don't have the 52kx schematic but other Pyramid supplies have over-voltage protection. There is an SCR that is triggered when the voltage gets to ~17v. This should clamp the output and trigger a shutdown. You should check the 16v Zener diode and the SCR. If the SCR or the Zener is defective, that would prevent the over-voltage from clamping the voltage. Also confirm that the SCR has a solid connection to the ground terminal of the supply. If it's open, that could prevent the clamp from shutting down the supply.
If the voltage is going high, measure the DC voltage from pin 4 to pin 5 of the LM723. It should remain the same at all times. Also measure the voltage from pin 5 to the ground terminal of the supply. That should also remain constant at all times.
Posted on Aug 20, 2008
  • Wayne Feierabend
    Wayne Feierabend Jan 12, 2017
    What is the value of Z1? Can't read/test mine cracked. Same unit PS52KX. What diode do I order?
Where can I get a free download of an owner's manual?
You can try contacting a local car audio professional or Pyramid customer support directly here:
http://www.pyramidcaraudio.com/ContactUs.aspx
Dec 31, 2015 | Pyramid Ps-52kx - 52 Amp 12-15v Ac To Dc...
I've got a new pyramid ps52kx, right out of the box. It shows 7.8 volts on the meter and the potentiometer will not adjust up or down, no control what so ever.. I did put an old used radio on it and no...
Have you set it up properly ? Consult instruction book. If you are certain it is defective, get a refund under the warranty (if it's new it should still be under guarantee)
18.January.2015.
Jan 18, 2015 | Pyramid PS52KX Pyr 46 amp power supply
Power supply smoked capacitor
Recommend contacting a local car audio professional or Pyramid customer support directly here:
Mar 30, 2014 | Pyramid Ps-52kx - 52 Amp 12-15v Ac To Dc...
I have a Pyramid PS-52kx. I need to know the value of R13 on the controller board, and cross-reference for TYN416
I HAVE A PYRAMID PS-52KX I NEED TO KNOW THE R13 RESISTOR OHMS AN TOLARENCE AND WATT.
Mar 07, 2011 | Pyramid PS52K Amplifier
Pyramid PS-52KX. Getting 24 volts DC on my output. I am knowledgeable in this department. I need to know what ac voltage should I be reading off of my transformer? I can't find a good schematic...
Sounds like the regulator goin. I've read when they go bad it will go full voltage which is 37vdc.
Looks like they use the LM723 regulator. I'm no expert, but may be that simple.
Here's a link to a schematic. Hope it helps
http://www.pyramidcaraudio.com/manuals/PS52K.pdf
I have a PS14KX. It won't handle any load. If you have any ideas let me know
Mar 05, 2011 | Pyramid - PS52KX 40 Amp Power Supply Car...
Was talking on cb and power supply went to beeping and will not quit. Unplugged it and plugged it back in and still does it. I have a Galaxy DX98VHP hooked up to it in a scale house. Took cb off and it...
THE BEEPS INDICATE THAT THE OVERVOLTAGE PROTECTION IS ACTIVATED,DO NOT HOOK UP ANY THING TO THAT POWER SUPPLY!!!OR THE FULL UNREGULATED VOLTAGE (20-30 VOLTS)WILL PASS FROM THE SHORTED REGULATOR TRANSISTORS TRHU YOUR GALAXY AND FRY IT.GET IT TESTED BY A PRO,USUALLY THE REPLACEMENT PARTS FOR POWER SUPPLY ARE DIRT CHEAP.
GOOD LUCK.
Sep 11, 2009 | Pyramid (PS36KX) 600-Watt Power Supply
Re: Pyramid PS-36kx power supply buzzer sounded,red light came on
Hi! I saw your question, and maybe this will help. I also have a Texas Star 100w amp, and this same power supply. Even though the nominal draw for your equipment is way below the rated amp flow of the power supply, when you key up, and the output on the amp is at max, you are drawing the limit of your power supply! Try running this setup at a lower linear output. You don't need the full 100 watts to get out! 60-80 watts is aplenty! You should start at a low output, and slowly increase the output(while keyed up), untill the power supply starts to complain.(buzzer/light). This is what your limit will be. The only other cure, is a MUCH bigger power supply. Unfortunately, I cannot afford a 60-90 amp supply, so this is what I am forced to do to use the one we have. Also,keep your cb's output very low when using the linear amp. These amps are supposed to get a low signal from your radio, or the linear amp is overdriven. (noisy and unstable. Hope this helps you! 73's to you! jimsjinx
Apr 30, 2009 | Pyramid (PS36KX) 600-Watt Power Supply
Pyramid Power Supply PS 52KX
I have used this tech for repairing some of my radio equipment and found him to be honest and dependable A rare thing now days. check with him at rmauro218@aol.com. Unless you are wanting to take a shot at repairing it yourself if so I will do some searching myself to see if I can give you a hand on it.
Sep 10, 2008 | Pyramid - PS21KX 20 Amp Power Supply Car...
Pyramid 35 amp regulated power supply
Use specified power supply by the computer.
Feb 05, 2008 | Computers & Internet
Pyramid - PS21KX  20 Amp Power Supply Car Audio Amplifier Logo
398 people viewed this question
Top Pyramid Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Mark Skinner
Frank Mangiapane
Level 1 Expert
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
