Question about Maxtor Hard Drive
I have a Maxtor 30Gb Model 5T0303H drive , I need slave jumper settings (diagram) to install as second drive in desktop...Please help Thanks John
  • ebax4454 Aug 23, 2008
    the disk is not spinning it suddenly stops and cannot be read by the system pls. advice.
    Scholar:
  • 152 Answers
HJOlive - here is the site that will help you with your slave settings:
www.maxtor.com
and follow the instructions.
ebax4454 - does this happen when you start up or does it do this all the time? Can you hear it spin up when you first start the pc? Is this the only hard drive in your system? Do you have another drive that you can use to start your system so that you can access this drive to at least see if you can get the info off of it. Then, check and see if it's under warranty.
Posted on Aug 23, 2008
My maxtor hard disk drive have a problem it has a size of 30GB but when i look in to the bios it becomes 2GB, what happened to my hard disk ? what i'm gonna do ?
Hmmmmmmmmmmmm......
Where did you get that HD?
Either its a second hand HD and made a profit selling it as 30gb. Though it happened to me! or
Theres an error on the jumper setting and partition.
Check the HD in actual, set it *** slave, connect it in your board and take a look on the property.
Hope that helps you out!
Dec 15, 2010 | Maxtor Computers & Internet
Maxtor hard drive jumper setting for model 6v200e0
here is a poster of Maxtors jumper settings for each kind of drive.
Nov 12, 2009 | Computers & Internet
What is the jumper setting for 'Slave' on Maxtor
Look at the picture, I cannot memorize all hardisk jumper but almost all drives have label in it. where you put the jumper for the Cable Select, Master, Slave.
See picture below. Opposite pins has label on it to where you put the jumper.
Oct 24, 2009 | Maxtor DiamondMax 6L160P0 160 GB Hard...
I am about to add a second IDE hard drive to my P.C. and the instructions i have say change the jumper chip to slave! I cannot see any obvious ways to do this physically on the the hard drive. What do i...
All hard drives have a set of jumpers on the end by the power connector. There is also a diagram of the location of these jumpers, for Master or Slave, or maybe Chip Select. On each IDE cable (2 connectors) there will be one Master, one Slave as identified by these jumpers. These jumpers are quite small and easily misplaced, so be careful !!!
Oct 13, 2009 | Computers & Internet
I need jumper settings for maxtor n256 model 96147h6 i wish to run it as a slave pls help. thx
For use as slave there is no jumper connected. (Master on/slave off0
Oct 04, 2009 | Maxtor Hard Drive
I want to install as second drive - i need the jumper settings
There should be a diagram on the front of your drive at the top left that shows you the jumper configs.  For most Maxtor drives, if you want a drive to be slave, you remove all jumpers.
Cheers!
May 01, 2009 | Maxtor Ultra hard drive kit 80GB 7,200 RPM...
Can not find Jumper diagram on N256 Maxtor model 33073H3
Hello there soggytundra, here's your GEEK-steer ...
Despite your question being posted here 5 days ago, I'll presume you still (and if not, then someone else will) need the answer ...
Virtually all Maxtor drives adhere to the following general rules concerning jumper settings (at least up until now):
= MASTER (M): Insert jumper over the FIRST COMPLETE pair of VERTICAL pins.
Examples:
Xoo o oXooo Xooo
Xoooo Xooo Xooo
= CABE SELECT (CS): Insert jumper over the SECOND COMPLETE pair of VERTICAL pins.
Examples:
oXo o oXooo oXoo
oXooo Xooo oXoo
= SLAVE (S): Do NOT insert ANY jumpers (or at least NONE VERTICALLY, but you may HORIZONTALLY across the TOP row as simply a means of storing the jumper).
Examples:
ooo o ooooo oooo oooXX oooXX ooXX
ooooo oooo oooo ooooo oooo oooo
TIP: As a general rule, if you KNOW the role of the jumper capable device you're installing, it is better to NOT use Cable Select (CS). In this case you do, therefore it would be best to specifically designate the (33073H3) drive as (secondary) Slave [and your other (primary) drive as Master].
Good luck and GOD-speed. Please post back if you have any further questions, and/or just to let me (and others in similar need) know how well this steers to solution.
"Today's the best day of my life...and NOW you're part of it!"
Mar 28, 2009 | Maxtor Hard Drive
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
Need help on how to attach jumpers on Maxtor Hard Drive Model # 4D040H2
It is in my experience with hard drives used in external USB enclosures - the jumpers are not nessessery.
Jul 04, 2008 | Maxtor Hard Drive
Maxtor Hard Drive Logo
188 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
