Question about Toshiba TZ50V61 50" Rear Projection Television
Bulb Do you remember what the bulb cost and were you able to fix it yourself?
It cost about 150 just check online to see if you can find the replacement bulb, for me it did fix my problem.
Posted on Aug 20, 2008
Need to replace the halogen bulb in a Secura 798HD table top oven. Everything else seems to be working. If someone does these kind of repairs it would even be better.
it is possible to do it your self but if the oven has some years on it the cover for the bulb may be stuck from old burnt grease
to add to your problems is it a special bulb only available from the spares department of a service center as the glass for the bulb has to heat resistant to above 350 C so any old bulb will not do
you could get a service technician out to do the job if you have one close by
Nov 29, 2016 | In Microwave Ovens
Bulb light failure how much?
Normal bulb should cost about 5-10$. You can replace it yourself in under 5 minutes.
May 27, 2014 | Car Audio & Video
Need to replace headlight bulb BUT being told whole assembly needs replacing at silly cost for a headlight ($1500)
WTF !!!!
Who told you this exactly?
All you need to do is replace the bulb at a cost of a few dollars......Job done!......
Do it yourself, it's quite easy.
If you have the HID bulbs, then they will be more expensive than ordinary filament bulbs but certainly nowhere near $1500.
I'm from the UK so I don't know the prices in the USA.
Jan 13, 2010 | 2001 Cadillac Sts
LIght is out in freezer. How to replace and can I do it myself?
Yes you can do yourself
Usually in a medal frame - use screwdriver to pry gently away - inside is a module with bulb - a number will be on it - just take out and insert new one and put frame back
You can obtain at an appliance parts store or on ebay usually (mine costs about $10-$12 at appliance store.)
I thought you meant the power light on freezer but
on reading it again looks like you mean in freezer - same idea but it's more likey a fridge / freezer bulb - just take off the panel and take your sample to a lighting or hardware store or contact manufacturer on their website if it is an oddball bulb.
May 09, 2009 | Refrigerators
Screen is not as bright
Time for a replacement bulb.
If you feel ok replacing the the bulb yourself, they are available on the internet at a good cost.
If you don't, bring it into a service center near you. They normaly charge around $100-$200 to replace the bulb.
Jan 23, 2009 | Mitsubishi WD-Y57 57" Projection HDTV
My stereio light dont work some times it will come on. I have a 2003 pontiac grand prix origanal equip
I had the same problem. There is a bulb inside the stereo itself. That bulb goes bad ~every 5-6 years. It costs ~$20. It is pretty simple to fix yourself. Here is the website where I got the bulb
I would assume you have the same problem.
You can determine it easily. If your radio is on, and you shine a light on the display, and you can see the numbers/text to what you are doing, then your bulb is burnt out.
Jan 03, 2009 | 2002 Pontiac Grand Prix
Headlight - Xenon - on 2003 Saab 9.3. Is this something a handy owner can replace. Also the dealer wants $275.00 for the bulb. Is this really the price?
if that is for one bulb, that's crazy. you can get them much cheaper online. it's not difficult to replace the bulb yourself. the bulbs ususally cost roughly $117 USD each. If the dealer is suggesting they will change the bulbs for both, it's a deal to have them replaced for less than $250 USD. I won't lie, it's a pain in the ****.
Aug 02, 2008 | 2003 Saab 9-3
Lamp Replacement on Sony Wega TV
Is your TV still under warranty? If it is, then you should send it back and let them fix it. If you do it yourself, you might void the warranty.
Jan 29, 2008 | Sony KDSR50XBR1 50" Projection HDTV
My camera c633 takes photos but flash wont work????even with new batt???
It is eathe the bulb or the flash circuit. if you are going to fix it yourself watch out for the flash compasitor. If you are going to send it in watch the cost. It sould be fairly cheap to have fixed.
Dec 31, 2007 | Kodak EasyShare C633 Digital Camera
Broken bulb
Get yourself a cork from a bottle of wine (wait to drink the wine until after you've removed the bulb!). Now, with the power plug REMOVED from the wall socket, gently but firmly press the cork into the broken bulb. You should now be able to screw the broken bulb out of the socket. If there's not any bulb glass or shards or anything else for the cork to grip, you may need to insert a small pair of pliers into the socket, and with reverse pressure (i.e. pulling the handle apart as opposed to squeezing together) you may be able to remove the bulb. And if that doesn't work, well, keep trying. You just need to be creative. Try using needle nose pliers and grabbing the edge of the bulb socket and gently work to loosen (remember lefty loosy, righty tighty) turning counterclockwise to remove.
Dec 30, 2007 | Kenmore 62702 Microwave Oven
Toshiba TZ50V61 50" Rear Projection Television Logo
59 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
