Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
SONY WEGA PROBLEM
My sony wega model KV-27FS210 (Chassis BA5D) comes on about 5 minutes after remotes switches it on. Technician says I neda power board cant locate one please help me . PCB#1-688-228-14
  • paray Aug 20, 2008
    Thanks for your quick response, but there is no sound nor picture until five minutes later. The board he recommended to change has the #1-688-228-13 inscribed on it.
    The board was recommended to be changed because the defective IC on it would be difficult to remove and replace.
    frank
  • paray Aug 21, 2008
    Will send the informatio as soon aas i return to mycountry Trinidsad
    frank
  • 4,234 Answers
That doesn't make sense. When you state that the TV comes on 5 minutes later, doo you mean that you get sound right away but hte picture comes on later? If so, a :power board" won't help. Please update this so we can narrow down the problem and get you a solution.
Thanks,
Dan
Posted on Aug 20, 2008
  • ABRsvcs Aug 20, 2008
    Frank,
    Even if hte IC is a surface mounted one, it should not be that difficult to replace. As far as I know, there areno surface mounted parts that would typically need to be replaced. Also, since the unit starts to work after a while, it suggests a connection problem not a defective IC. While an IC failure is possible, normally that type of failure would either cause hte set not to work at all or would fail after being on for a while. DO you happen to know what IC is defective?
    Dan
My tv sony wega dont turn on an the standby light blinks 16 times model KV-32FV310
Hello
Standby light on Sony TVs blinks 16 times is abnormal I thiks. It may come up to 8 blinks or so. You jsut switch off the set by AC mains switch at the front panel, switch it again with it and count the exact numbers. Never switch it On_Off by remote hanset.
If it happens even after this process, you just do the following
Press the following button on your remote control as stated
"Display"_"Channel"_"5"_"Vol Minus" [not plus] then "Power".
You may get "OVP" "OCP" "V STOP" etc displayed on the screen.
Just report the result to me through Fixya. Ok.
Nov 04, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron Wega KV-27FS100 picture on and off
i'd say your tv is unhappy.
unplug for 10 min..and see if that resets it.
May 31, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Click tv on but nothing happens stand by light blinking
Check to see if there is an alternate power switch, my TV has (2) power switches, one turns the power on but not the TV and the other turns the TV on as long as the power switch is on.
Apr 22, 2010 | Sony FD Trinitron WEGA KV-27FS210 27" TV
Sony KV-27FS210 won't turn on: 5 blinks
If you have little experience of TV repair then take off back cover of Sony Kv-27FS210 and find Screen Control Knob on flyback transformer, turn that knob slightly CW or CCW and turn on TV to get picture. I think you need to turn ON TV few times to get proper adjustement of screen volts.
Above said procedure is for non-tech person.
(Tech person will adjust screen volts (G2) as per procedure mentioned in service manual with proper tools.)
Jul 28, 2009 | Sony FD Trinitron WEGA KV-27FS210 27" TV
Sony trinitron KV-27FS100
probably, you have to call for a technician to check for it, the switch of the tv might have some dis alignment of cables
Oct 30, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
SONY WEGA KV-32XL90E
Hiii...
what chassis your tv set ?
Thank's
[Vrya]
Jan 23, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
My TV will not turn on!
I have a tie dye of rainbow colors on the whole screen. Is the screen shot?
Dec 08, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony WEGA® KV-BM142M40
press sequently (1) display (2) 5 (3)volume+(4) power or TV when tv in standby mode
Nov 11, 2007 | Sony WEGA® KV-BM142M40 14" TV
More than 5 blinks there is a problem in any other section. Maybe in powersupply section, deflection section and audio section also. Sometimes dry contacts in soldered points also give same symptom. Service persons only done this problem. If you technician give the chassis details.
Sep 05, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
129 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
