Power off the printer using the power switch located on the front, right side of the machine under the Control Panel.
Wait until the Touch Screen becomes blank.
Press the power switch again to power on the printer. The entire power on process (to power on and complete a self test) takes less than 45 seconds. Certain functions of the printer, such as copying, will be available before other functions.
If this fails to solve your issue contact service.
Hope it helps!
Normal
0
Driver could be corrupt. Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
The most common explanation for the error 'U4-2' in all the 'Xerox' machines is "Fuser warm up failure occurred". I am very sorry that such a problem has occured for you. It cannot be solved by you, if you are not a qualified technician and without proper tools.
Please do call the nearest service centre for a visit and they will probably solve it in a day. Remember, they need the service manual procedures for solving it properly.
Don't worry, it is a very common problem. But only authorised service people can help you in a good way.
