Question about Maytag 24 in. MDB6600A Jetclean II Built-in Dishwasher
Maytag MDB6600AAW. Very Loud when washing, now door handle sticking
This machine seems to be loud then quiet when washing, but dishes comeout somewhat clean. We have very hard water. Also, now the door handle keeps sticking. Are these dishwashers plagued with problems and is there anything we can do about it?
  • 61 Answers
When the unit is running it is normal that it is a little more quiet. I think what your hearing is in the drain cycle for the first 30 seconds it is quieter than the next 60 seconds. The reason is in the first 30 seconds the water is leaving the machine and muffels the sound of the pump, for the next 60 seconds the pump is turning but the water is for the most part gone and the pump is sucking air which is louder and is normal.
Posted on Dec 18, 2008
Beko WME8772W washer not working
clean the filter first
look in the pump for any bits in it
Feb 06, 2014 | Washing Machines
Make loud noises on spin cycle and smoke when we open door
The loud noises seem to be a feature of newer front loading machines. We bought a Maytag and have had similar issues since day 1. We were told the bearings are the problem. They don't last and make major noise as they wear.
Oct 28, 2013 | Samsung WF316BAC 3.79 cu.ft High...
Loud washer! The last 5-7 minutes of the wash, the washer becomes very, very loud. This occurs in light loads as well as large loads. This just started about 6 weeks ago, any ideas?
My husband and I spent 4 hours Labor Day replacing the bearing and seal in my Maytag Neptune washer. Worn bearing are what is causing the loud noise. Maytag will only sell you the complete drum assembly. However, if you are mechanically inclined, you can purchase the bearings, 6206RS and 6207RS (we got ours from a local bearing company) and the seal kit can be purchased from repairclinic.com. There is a video on YouTube showing how to replace the bearings and seal. Our washer is now as quiet as it was when new!
Sep 04, 2012 | Maytag Neptune Washer
The latch is sticking on my dishwasher. How can I
replace the door latch and the handle check to see if the console loops that hold the latch are broken if so replace the console
Jun 02, 2010 | Maytag 24 in. MDB9750AW Dishwasher
My machine is very, very,very loud when in spin cycle. Does not shake, seems level.
ok,,your not going to like me now!!!
open the door and spin the drum by hand,,,it should spin quietly,,maybe just a slight sound from the motor turning,,,if it sounds like gravel and feels ***** to turn or there is lift in the drum then the drum bearings have worn out and you need new one's fitted,,,not a cheep job!
see i told you,,, now you hate me,,,dont you? and im an orphan as well!
May 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag MDBF750AWZ, Quiet Series 200 - sticking, stiff door handle
There are lot of handy sprays available. Try your super market or the hard ware stores where plumbing materials or sold.
May 03, 2010 | Dishwashers
I have a Maytag Quiet Series 400 and I can't get it to run on Normal,lite or other. I get a code 82 that appears. What does this mean?
My Maytag quiet 400 series is doing the same thing-buttons aren't responding or working. And now a second problem...it has become very loud and sounds like it is chewing up all the dishes.
PattyQ
Jan 10, 2010 | Maytag Dishwashers
Loud noise maytag dishwasher quiet series 100
Hi All,
I have had a Maytag Quite Series 300 for some years now and have done basttle with it on may occasions. I now consider myself somewhat of a veteran, although by no means a repair expert!
Grinding Noise: From either a clogged/blocked impeller or not enough water getting to the impeller.
For a clogged impeller, it is fairly easy to disassemble the washer to get at the impeller to remove any debris or blockages.
For not enough water it can be a number of things. First of all, you will notice that the noise lessens if you add a jug or two of extra water. This is because if the water level is too low, the pump impeller will get some air mixed with the water & this is LOUD! Now for the causes:
Float – If the float gets stuck in the wrong position (debris or water deposits), it will not fill enough.
Float Set Wrong – Seems thats some of these dishwashers have the float set a little too low to let the dishwasher perform without grinding. A few pennies attached to the float with a rubber band seems to help here. Don't go too far or you'll flood your kitchen!
Timer – Some folks have mentioned that dishwashers that fill on a timer will not fill enough in the allotted time, if the water pressure is low. While this is true, I have looked over the electrical & parts diagrams for the QS300 and I do not see a timer listed anywhere. Also, the wiring diagram appears to show that this dishwasher only uses the float to achieve the correct water volume. I could be mistaken here.
Note that in VERY hard water areas (like mine – TDS of 850 hardness or 49 Grains), the plastic fins on the cover of the impeller get very choked up with water salts and this can impede flow, leading to a low-water symptom, when in fact, there is plenty of water.
Dishes Not Cleaning:
Poor Water Flow – See above, all the above items will negatively impact dish cleaning.
Poor Q uality Detergent – After trying them all – Yes, all – Do not use cheap detergent. Buy the brand names: Cascade or Electrasol work well. I have found that by far, the little packs work the best. We found that the liquid works second best and the dry stuff really isn't up to the task at all, no matter which brand.
Spray Wands Catching – We found that our lower spray wand was catching on the bottom of lower dish tray, so I very slightly bent down the legs that the wheels mount to in order to lift the dish tray/basket a little and give the wand a little more room. This worked well.
Spray Wand Nut Too Tight – The factory seems to send the dishwasher out with the nut on the bottom spray wand tightened a little too far. Loosening this a little bit lets the bottom wand rotate much more easily.
Top Spray Wand Not Meeting Receptacle – The top spray wand is attached to a pipe that mates with a port (well, one of two ports, depending on if you have the top rack in the “Upper or “Lower” position). The pipe seems to have a tendency of missing the port. A well placed elastic band will help here. Note that on our dishwasher, by the time the first elastic band wore out, the pipe had been permanently moved to the correct position by the gentle pressure.
Tines/Dish Holders On Top Rack Falling Over – The tines (metal spikes) that hold dishes on the top rack fold down by design. Issue here is that they do it sometimes during the wash, causing the dishes to fall over and block the spray. A few well placed rubber bands help here as well.
Water Salt Buildup – If you live in a very hard water area, you can still get clean dishes from yor dishwasher. We do and we have VERY hard water. Buy a gallon of vinegar once a month. Pour this into a clean dishwasher. Turn it on so that it runs for 2 minutes to circulate the vinegar. Open the door & let stand over night. Close door & finish cycle. This will cut down significantly on the hard water salt buildup in the washer.
It's A Maytag – Sorry folks, it's true. I have learned (after purchasing the dishwasher) that Maytag has run into financial difficulty in recent years and has reduced build quality to save money. If you got suckered into buying one of these, you will very likely never buy one again. My opinion is “Do not by Maytag.”
Hope this helps someone!
Dec 31, 2008 | Maytag 24 in. MDB9750AW Dishwasher
My wash spins SO loudly
hiya
sounds like your drum bearings are in need of replacing.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 19, 2008 | Washing Machines
Maytag 24 in. MDB6600A Jetclean II Built-in Dishwasher Logo
194 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
