Tefal Pro Express GV 8120 Iron Logo
Posted on Jun 14, 2011
I have a Tefal Pro Express Turbo iron (purchased in 2005). In the past 2 days the steam is constantly on - the button does not appear to be stuck. I can't get the steam to stop... unless I take out all the water - but the electricity cord gets extremely hot to touch. Is this a common fault, or could it be failing because of its age? Help!
Anonymous
Level 1:
New Friend:
  • Contributor 33 Answers
  • Posted on Jun 14, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
33
Questions
0
Helped
6494
Points
90
Yes, if your electric cord was extremely hot to touch is not common. It's posing danger to your unit and to your entire electrical system that may cause fire. Please let a qualified electrician inspect and repair your unit. The unit thermal fuse may not functioning that automatically switch off or cut the electric power of your unit when it gets too hot. Thank you for asking.
I've been given a Tefal Pro Express Care Iron but I can't remove the Anti-Calc collector.
Question edited for clarity, it is a 'Tefal' not a 'teal pro'.
If it breaks, you can buy another, but descale the inside with CLR or a proper descaling solution.
Calc Collector Tefal Pro Total Express Steam Iron Anti ...
Part Seeker https://www.partseeker.co.uk > Shop
Calc Collector Tefal Pro Total Express Steam Iron Anti Limescale Cap Remover - 144190 ... Genuine Tefal replacement removable anti calc lime scale collector ...
£13.99 · ‎In stock
Jul 25, 2023 • Irons
I have a tefal pro express turbo GV8150 and there is constant team coming from iron without me touching the steam button. Can anyone help with a diagnosis and or possible fix?
constant steam means the control valve is not working
descaling may fix the problem
the other fix is a new iron as the cost to repair is generally more that a replacement price
Sep 30, 2016 • Tefal Irons
The iron has been all descaled, however we cannot get any steam when pressing the button. It is a Tefal express generator model 3 years old.
Once you have descaled the boiler and refilled your frontpiece of the iron itself (hopefully with distilled water - any supermarket) you press the "reset"/ "restart" button on the back end of the steam generating unit. When the water is hot enough press steam button & turbo button a few times - WARNING: make sure iron is facing downwards and cover ironing board with old rag because initially brown steam splatter will come out on first few steam releases.
Feb 14, 2015 • Tefal Irons
2helpful
2 yr old Tefal Pro Express Steam generator Iron Trips Fuses
hello does all the electric go off in your home if so theres a bad earth on the iron or the iron element is shorting out also make sure theres no water getting into the iron good luck
shaun
Tefal Pro Express - Constant Steam (Model 2932)
Great answer from Jacquief above. To which I add try giving the base of the iron and its button, a very light tapping with a tack hammer (much smaller and lighter than a standard hammer) wrapped in a tea-towel. This can often break up the lime scale seal which has formed somewhere inside and is not responding to Jacquief's method. In future never use scale laden tap water in your iron, use $2 litre bottles of distilled water from any supermarket.
6helpful
Found this on another site and just tried it. Put 50/50 water and vinegar in the tank and leave it to go through on the constant steam. Give it about 5 minutes then try the button. Mine gave an extra spurt of steam at this point but still continued giving steam out all the time. I refilled with the water vinegar mix and just kept pressing the steam button and letting it go through. Eventually it fixed it and the constant steam stopped. Something to do with a piece of limescale blocking the solenoid but that's all Greek to me! Hope this helps. Kind regards.
2helpful
Tefal Pro Express
  1. solenoid valve blocked
  2. swich for steam broken
  3. you forget it in turbo steam mode and you have steam all the time
ps see below on link turbo button
http://www.gostore.com.au/~ebay/krups/tefal/proexpressturbo/TefalProTurboAuction(3).jpg
Tefal steam generater pro express turbo
Most of the time the electro mechanism release the steam still open and not able to returning in closing position.Try to cclick quite few time to excite the mechanism and some times work.Also can be the micro switch defective.
Good Luck
Jun 09, 2008 • Irons
Top Tefal Irons Experts
ZJ Limited
ZJ Limited
Sulejman Sulejmani
Sulejman Sulejmani
john h
Are you a Tefal Iron Expert? Answer questions, earn points and help others
