Question about Systemax Computers & Internet
I tried to add memory ram to my computer, but it was not compatible and now my computer does not start. the monitor only shows me a "CMOS ERROR" AND warn me that my CPU has been changed or the CPU ratio changed fail. It ask me to re enter settings in CMOS setup. how can I fix the problem? thank you
  • Systemax Master
  • 3,051 Answers
If you put your old memory in and boot into bios setup and go to default or fail safe settings that should work then get the right memory that u need and install as usual
Posted on Aug 20, 2008
2 Suggested Answers
DickCanFixIt
  • 948 Answers
SOURCE: PM800-8237
If you have correctly set the CPU in the BIOS, and saved the settings and still get the error, the CPU is not compatible with your system.
Most likely you have not set the BIOS right or have not saved it.
Posted on Jul 02, 2009
Acer aspire t 160 wont boot after ram installation
When purchasing RAM make sure ram modules are of the same brand any type
IE corsair ddr3 low density or hynix high density ddr2 you should always try to keep the same brand and type of ram
reason being the compatibility issue
and always place the largest ram module closest the CPU central processing unit
also check the ram sockets for dust and make sure the ram modules are securely seated you can do this by pressing the levers at either end of the ram sockets.
If you're not sure if a module is right for your system, use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules.
First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system.
You should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible.
You could put the old ram back in your computer and see if it starts then you will know if its the ram.
Hope this helps.
Nov 23, 2012 | Acer Aspire T160 (AST160UA3400) PC Desktop
Cmos Checksum Error
Check CMOS and Memory Modules:::If the error message is "UNEXPECTED_KERNEL_MODE_TRAP," then it indicates you have problem with the memory of your computer. You need to check whether the SIMMs (Single Inline Memory Modules) are compatible and have the same speed. Secondly, also check whether you have set the CMOS (Complementary Metal Oxide Semiconductor) to the right amount of RAM. If these solutions do not work, you might have to replace memory in your computer....try to use system utility tool like Reginout.. Hope the problem is resolved.
Apr 13, 2012 | IBM ThinkPad T43 Notebook
Computer is on but blank screen
Check the RAM .
If the problem is same . remove the cmos battery and install again.
Reply me soon.
Hope this help.
Feb 19, 2011 | Intel Motherboard
Hard drive light flashes 10 time, but screen does not power on
man jst remove ur ram nd use a eraser rub the ram then insert the ram properly nd also check ur cmos battery.......ur work is done....
Aug 30, 2009 | E-Machines eMachines Desktop PC
RAM Problem
either the ram is faulty or not compatible try using in a different board
the motherboard will beep with no memory in
Jan 17, 2009 | Intel Motherboard
RAM Problem
The most likely cause is the RAM is not compatible with the motherboard.
Jan 17, 2009 | Computers & Internet
Can not upgade memory from 2G to 4G
have you checked the frequency of the new ram you are using if its not of the same type and of same frequency as of the another one your system wont boot
Sep 14, 2008 | Acer Aspire™ T180 PC Desktop
BOOT falilure after RAM installation
Did you make sure that the new RAM was compatible with the motherboard? ...?
Some RAM manufacturers are not compatible with certain motherboard manufacturers....
Aug 20, 2008 | PC Chips M810DLU (M810DLUV75C) Motherboard
NO video @ bootup
Are you sure that the memory you have installed is compatible with your motherboard.
It is weired but some memory do not work with certain motherboards, irespective of speed or voltage rating.
Aug 05, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Memory
how much ram? what windows version? windows Vista 32bit will not support more than 3GB
boot up and go into CMOS see if the memory shows up there, sometimes you have to go into CMOS and SAVE
hope this helps
thanks for the rating
Jan 08, 2008 | Toshiba Satellite A15-S127 Notebook
Computers & Internet Logo
Top Systemax Computers & Internet Experts
Mike
Joseph Hoffmann
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
