Question about Fuji FinePix A360 Digital Camera
Downloading to laptop
When i plug usb cord to new computer it says connection error. it has worked on other computers. what is the issue?
  • nina 9 Oct 29, 2008
    did not have cd rom with camera linking to acer windows vistra basic acer laptop
When i plug usb cord to new computer it says error connection. it has worked on other computers. what is the issue?
Posted on Oct 04, 2008
SOURCE:
How do I fix the connection to my iPod, as when plugged in it says internal error
Make sure your computer is connected to the internet and see if windows updates the driver automatically when you plug it in to the USB port(s) on your computer.
Try going to the Device Manager and scroll down to where is says USB Root Hub. Right click on the top one and click uninstall. Then do this for all the others (although your mouse and keyboard might stop working, so you would have to unplug them and plug them back in again. Then go back to device manager and uninstall all the USB Root Hubs.
Restart your computer and the drivers for the connected USBs will be automatically installed.
Also, check you are using a usb 2.0 and not a 1.1.
If it still doesnt work. Take some isopropyl alcohol (90%) and a cue tip and clean out the USB port on the iPod charger and then plug it after (after it drys) and see if it works. If not, then clean the computer USB port with the cue tip and isopropyl.
Also, check your BIOS to make sure USB options are enabled.
Furthermore try a different ipod cable... However, I found that while the device is plugged in, try twisting the cord with your thumb and index finger, klnd of rolling it so the cord gets twisted. That might be enough to complete the circuit caused by fraying of the cables inside.
Good Luck
Sep 06, 2014 | Computers & Internet
Windows 7--64 bit. USB port, was working. Had power outage due to lightning striking corner of house, burned out some breakers. Printer was on surge protector, but printer and PC not powered off prior to...
See if printer will work in another working computer. If it does the issue is with your computer hardware/software. If it also does not work then the issue is with the printer. And if so, it is not cost effective to repair given the price of printers these days.
Mar 03, 2017 | Brother MFC495CW AllInOne InkJet Printer
My computer is telling me I need to install an ink cartridge even though I just replaced it.
This could either be a slight communication problem between your printer and your computer or a communication issue between one of your cartridges and the printer. Please follow the steps below to fix the problem:
  1. Reboot your computer.
  2. If usb-connected, disconnect the printer from your computer.
  3. Open the printer cover and remove the cartridges. Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center to remove the cartridges.
  4. Close the cover.
  5. Rebrick the printer (pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
  6. When the printer turns on, reinsert one cartridge first and close the cover. Check for any errors.
  7. Reinsert the other cartridge and check for any errors again.
  8. Replace whichever cartridge is causing the error to appear with a new cartridge or with a different known working cartridge.
  9. If usb-connected, reconnect the USB cable to your computer.
  10. Try to print from your computer to verify that the problem is fixed.
I hope this information has been helpful.
Sep 22, 2011 | Lexmark X4650 InkJet Printer
Code 43 - usb device not regognised
Hello
Issue After you plug the USB cable into the product and the computer, the error message 'Unknown Device ' displays on the computer. This document resolves this issue for Windows XP operating systems. Try the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting. Solution one: Check the USB connectionFollow these steps to test the USB connection between the HP product and your computer. Step one: Inspect the USB cable and connection The icon on the USB cable (c01424575.gif ) faces up when the cable connects to the product correctly. Check the back of your product and the back of your computer to make sure the USB cable connects correctly and securely. Step two: Reset the printerAfter you resolve all potential USB conflicts, follow these steps to restart the HP product.
  1. Press the Power button (c01602202.gif ) to turn off the product. NOTE: The product might not turn off after pressing the Power button. Continue to the next step regardless.
  2. Disconnect the power cord from the rear of the product.
  3. Unplug the power cord from the electrical outlet.
  4. Wait 30 seconds.
  5. Replug the power cord into the electrical outlet.
  6. Reconnect the power cord to the rear of the product.
  7. Press the Power button (c01602202.gif ) to turn on the product.
  • If the installation automatically continues and completes successfully , you do not need to continue troubleshooting.
  • If the installation does not automatically continue , restart the installation process.
  • If the issue persists , continue to the next solution.
THE COMPLETE INFORMATION IS IN THERE, also you can reset the printer
Apr 07, 2010 | HP Photosmart 8250 InkJet Printer
Cant connect with the usb wire
I strongly believe you need a new USB cord for the sciphone. I had similar issue. Replaced and phone was recognized by PC.
Aug 26, 2009 | Dual Electronics CECT P168 Cellular Phone
SG4 Sky Caddy driver
Make sure your cord is plugged into the SkyCaddie with the cord pointing down towards the battery, not going up. It makes sense and it is easier to plug in with the cord going up, but you will eliminate this error if you plug in the cord with the cord going up.
Apr 02, 2009 | SkyGolf SkyCaddie SG4 GPS Receiver
Usb write protect
If you've updated your software and checked the drivers but the issue still persists, try the following things:
  • Unplug the USB device and then plug it back in. Make sure that the connection is snug and installed in the proper direction. Note that USB plugs fit one way only—if you try to plug them in upside-down, it will not insert.
If this does not solve your issue-
  • Unplug all USB devices from the computer. Then start plugging in USB devices one at a time, testing each one to make sure they all work before adding the next. Sometimes two devices will conflict and will work together.
  • Is this a new device that never worked, or is it a device that you've had for a while that suddenly stopped working? If it used to work, think about what changed just before the device stopped working. Did you recently add another new device? Install a new program? Try reverting the computer to the way it was before the device stopped working. If it works again, there is an incompatibility with the device and whatever you added.
  • Unplug all but suspected USB devices. Open System Devices menu-
    • Windows: Right click “My Computer” > Properties > Hardware > Device Manager > USB Serial Bus Controllers
    Under the USB information, you should see the USB devices connected to your system. (Disregard any Host controllers) The name may not be identical to your device (it may say “USB Mass storage device”), but it should have the right number of devices listed.
  • If you have the device plugged into a USB hub or into your keyboard, plug it directly into one of the USB ports on the computer. If it works there, the issue is with the device to which it had been previously connected. The device may need more power than the port provides
  • Try a different computer!
Sep 23, 2008 | Centon Electronics USB 2.0 PCMCIA...
No anything
Flashing amber power button indicates a failure of the power supply.
Jun 14, 2008 | Dell Dimension 4600 PC Desktop
Insignia mp3
Please provide more information on the error message.
You can use Windows Explorer to transfer files to your insignia sport player. First, in the settings on your player, go to Settings, USB Mode, Connection Type and select File & Folder. Then, plug your player in to your USB cable. Windows XP should automatically find your player and make a new drive letter in Windows Explorer. Simply drag and drop your mp3 files from your c drive to the new drive for your player. You'll notice that when you delete the files on your new drive for your player that it doesnt remove them from your player. You'll need to use your player (settings, system, erase internal) to erase internal (and external), but after that when you add new files, they will be added to the player when it does the profiling after you disconnect the USB cable. [email protected]
Dec 21, 2007 | Insignia IN-MP3256 MP3 Player
Fuji FinePix A360 Digital Camera Logo
55 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
