Question about Olevia LT27HVX 27 in. LCD Television
Says no signal when switched to hdmi when there is one.
I just hooked an hmdi cable to me tv from my cable box. When I swith to the hdmi input it says no signal when I can clearly see the picture coming from my cable box and then after a few seconds it just turns to black. Anyone have any idea what is happening? I hooked up my olevia 232t12 to my cable box and switched the tv to the hdmi source and the tv reads no signal. I bought a new hdmi cable and switched out my cable box as well and still no signal. I have tried to get a firmware update for the tv at the olevia site, but there is no update available. I'm begining to think its the tv.
  • 2 more comments
  • Anonymous Sep 24, 2008
    I have the same problem with no signal on the HDMI port on two 232-T12 TVs with Motorola HD cable boxes (1 Verizon and 1 Comcast). I have been trying to work this out with Olevia for the past 6 months but have made zero progress.
  • Anonymous Mar 25, 2014
    The HDMI says "there is no signal". We have tried this ps3 with another tv and HDMI cable and that works.
  • Anonymous Mar 28, 2014
    i moved my tv and unplugged my laptop and hdmi cable, since i put everything back it just keeps saying no signal
  • Anonymous Mar 30, 2014
    Was watching TV. Granddaughter hit one of the buttons, now TV does not recognize cable box. Cable box is working.
I had this issue as well, updating the firmware resolved the issue.
Posted on Nov 08, 2008
Have the same problem with a 532H - but here is what I did to resolve the issue:
1) Click your Menu button on the TV remote.
2) Go to Screen (click the right button)
3) Go to Main Picture Source (click the right button)
4) Select HDMI (click the Menu button when done)
Posted on Oct 13, 2008
Hmdi to rac
No. HDMI cables use the RGB and sync on separate connection pins on the cable. RCA cables use the whole composite picture TV signal on the cable.
Jul 29, 2016 | Video Game Consoles & Games
My cable box is hooked up but no signal can u tell me whats wrong
If you hookup your TV directly to the coaxial cable, bypassing the cable-box, do you get a few channels? If so, then the coaxial cable is carrying a signal, which is good.
How are you hooking the output from the cable-box to the input(s) on the TV? Coaxial output port on box to coaxial input port on TV?
Red/blue/green "component" outputs on box to matching inputs on TV? Red/White audio outputs on box to red/white inputs on TV? HMDI output from box to HDMI input on TV?
You have to "tell" the TV which of the inputs:
* coaxial (with TV set to Channel 3 or 4)
* component
* HDMI
to "listen" to.
Oct 24, 2014 | Samsung PN60E6500 60-inch 3D Plasma TV
How do i hook a bluray player up only with hmdi cable to a older tv without hmdi hookup?
Just buy an HDMI to AV converter box. It will converter the HDMI to Composite video. If your TV have Component video input then its better to buy HDMI to Component video cable. component video quality is better than composite. Its have resolution up to 1080i.
Electronics Equipment Repair Center
Oct 06, 2014 | Sanyo Televison & Video
What channel does the tv need to be on for the hmdi cable to get a signal?
It's not a channel. You should select the input to TV to HDMI. Refer its user manual, please.
Electro help
Sep 21, 2014 | GPX KCL8807DT TV/DVD Combo
How do you hook hmdi cable up to Mitsubishi hdtv wd62528?
Must select correct input, on your model the input used is not "labeled" HDMI, look in your user manual.
Feb 16, 2012 | Mitsubishi Televison & Video
Hooked up ps3 using hmdi cable worked not working now using the
mpc heesman1 might be right...
However. I´m inclined to think that you did change the input on your TV. So your problem is another, this is what you have to to to reset:
1. Unplug the HDMI cable from both the TV and PS3.
2. Plug in the AV MULTI OUT cable (the red, white, yellow one provided along with the system) to both your PS3 and TV.
3. Set the TV input to the correct one and turn it on.
4. turn on the PS3 with the front button but DON´T release it, keep your finger on it, until you hear a second beep, thats when you release the button, the PS3 will start to identify what it´s connected to and will display it on your TV.
Hope it helps.
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
Toshiba 40XV645U - No picture on HDMI 1 when TV is turned on
I assume that you have set the input source selction as in Page 32 and HDMI 1 is solid and and not grayed out. If so check the Preferences menu and see if there is an option for power on set up.
Also look at page 51 about HDMI feature settings. I assume you turn the cable box on first before turning the TV on.
Dec 19, 2009 | Computers & Internet
No signal
Try changing the order you turn on your TV and cable box, don't switch both together. The TV will likely skip the HDMI inputs if there is no signal there. Alternative you can change the TV's source after the cable box is on and that should allow it to not skip the HDMIs. You don't have HDMI to DVI adapter(s) in the line, do you? -Ken
Jul 30, 2009 | Televison & Video
My best guess would be that the resolution settings on your reciever are set too high(It's putting out an HD signal the TV can't display) Plug in through Composite or component the the box and resolve this through you Cable box's menu, then reconnect the HDMI cable.
Dec 23, 2006 | Olevia LT27HVX 27 in. LCD Television
Olevia LT27HVX 27 in. LCD Television Logo
1,456 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
