Fluttering of proper colors as TV warms up. Problem was previously resolved by adding cooling fan to circuit board that holds the color wheel (the set is a Gateway 56"). It now deteriorates as the set warms up. New color engine board costs over one thousand dollars. Which component(s) on the board need to be replaced?
    Genius:
  • 1,665 Answers
    Scholar:
  • 93 Answers
You need to check the color wheel on the circuit board if it is integrated then need to replace the circuit board as this issue is with the color wheel and after replacing the the new Cooling fan was able to work and keep it cool but the issue was still there.
try replacing the Color wheel now or the circuit board
Regards
http://MyTechGuru.US
Posted on Aug 20, 2008
    Scholar:
  • 163 Answers
Usually electrolytic capacitors cause some mulfunctions
SOURCE:
My hln5065w started making a loud noise like a fan noise upon startup recently. The color is fine (I've read the color wheel w/loud noise problems). It has been doing this for the past week, previously...
The loud noises came from the tv with a colors wheel design in it have to be replaced every few years,because the spinning of the colors wheel disc are spinning in very high speed in RPM to have it colors for the tv to operate correctly,the humming,loud motors noises and eventually the effect of the tv colors.The colors wheel disc are worn out and spinning hitting it axes motor,the colors wheel must be replaced to solved this problems.
Jul 21, 2011 | Samsung HLN5065W 50" Rear Projection...
Check Fan No. 2 Error Message
The DMD board you installed is bad. It senses the detection line from the fan and generates the error code. Try installing the old DMD board.
Mar 15, 2010 | Samsung HL-S5086W 50" HDTV
TV MAKES A HUMMING NOICE WHEN TV IS ON, WHEN TOUCHING THE BACK OF TV WHERE NOISE COMING FROM IT IS VERY HOT. IT WILL THEN GET LOUDER AND EVENTUALLY CUT OFF TV. TV WILL COME BACK ON AFTER IT COOLS OFF. WHAT...
It is either the color wheel or a fan. To isolate the color wheel, remove the back cover and make sure you put the lamp door back on so that the door interlock switch is activated. Turn the set on and get the picture and humming noise going. Just to left of the rear fan there are some wires. One is a really flat brown or rust colored ribbon cable that plugs in to a board on the left of the wires. This is the color wheel ribbon. When you unplug it the set will keep going for a moment or two but if the noise stops, you will know it is the color wheel. Don't be alarmed because the set shuts off with this ribbon disconnected. Just let all the fans stop (for proper cooling) and then unplug the set for 5-10 minutes. If the humming did not stop you have a bad fan motor. Plug the little ribbon back in while you have the set uplugged. Plug the set back in and turn it back on and try to isolate which fan it is, if it is a fan. If you determine it is a color wheel, the light engine will have to be replaced as Toshiba does not offer just the color wheel. If it is a fan, those can be replaced. I hope this helps. Let me know what you find and thanks for using fixya.
Nov 23, 2009 | Toshiba 62HM95 62" HDTV
Mitsubishi WD 62827 pictures flashes colors
TAKE THE BACK OFF AND LEAVE IT OFF . NOW TRY IT. IT WORKED FOR ME STRANGE BUT IT WORKED
Apr 27, 2009 | Mitsubishi WD-62827 62" Television
Tv makes a noise
This is definitely the color wheel. It is not the same thing as the cooling fans. The color wheel is buried; even if you took the back off the set you cannot even see it. It's a pretty pricey repair.
Mar 30, 2009 | Televison & Video
Cooling fan is loud . I'm going to replace the lamp in the unit because all 3 lamps are blinking on the front panel. Unit shuts down but I'm wondering if there is a seperate cooling fan in the back of the...
That's probably the Color Wheel you are hearing. When you turn the set on the color wheel has to run, one of the several things that has to happen for the set to come on. The color wheel sends a signal back to the control circuit to tell it it's running. If these sets fail to light the lamp they will shut off and try again, that's why you hear the color wheel start then wind down then start again. The set should try three times before it decides it's not going to be able to turn on.
One way you can tell the difference in the fan sound and color wheel sound is if you can get the set on, let it run for a little while so it gets warm, then when you turn it off the color wheel will start winding down but the fans will continue to run for a minute or two.
Mar 25, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Cooling fan buzzing
Yes,don't do it yourself,and you need to have repair tech. asap,cause if the cooling fan is not working properly,that could trigger other parts in the tv to be malfunction.
Hurry,just it fix!
solutiondoct
Nov 01, 2008 | Samsung HL-R6167W 61" HDTV
Samsung HLP4663W color wheel replacement
When I removed the jumper wire the screen color problems I experienced after changing the color wheel were fixed completely. I did not need to reset the CCA values (which came with my color wheel, on a separate sticker). If you have a black bracket blocking access to the jumper wire, as I did, you can access the jumper wire by removing the fan shown just to the left of the yellow and white sticker; there are two screws attaching the fan to the chassis below it. Next, remove the two screws that hold the silver clamshell (the housing for the circuit board) halves together. These screws are right behind where the fan just was, on either side of the protruding fins. They each have a spring under the screw head. You can then pull the visible half of the silver housing forward (with the bracket attached). You will then have access to the entire circuit board. Look for CN810 - it is located right behind where that bracket just was when it was all put together. Pull the tiny black plastic part (that has the jumper wire) off of the pins. Then reassemble the housing and put the fan back on.
Jan 27, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Toshiba dlp
The light engine part number is 234054 and cost $456.00
Dec 20, 2007 | Toshiba 46HM95 46" HDTV
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Ekse
