We have a well. It always gave us clear water until the pump broke. Mt husband replaced the pump and ever since the water is brown, rusty dirty. He let water flow out with a garden hose for several days, the problem still exists. Do you think it is the pipes, pump, or are there chemicals to put in the well to clear the problem? Do you have any solutions we could perhaps try? Thank you
    Champion:
  • 254 Answers
Sounds to me like the pump is disturbing the sediment in the bottom of the well when it energizes. You could try placing the pump in perferated sleeve if it is a deep well pump. Or maybe a 5 gallon bucket with perferations cut in it, in case it will not fit in a sleeve.
Posted on Aug 31, 2008
Large dark brown spots appearing after washing
Normally a washer does not cause a staining problem, but If something inside the washer has rusted, it could. I would check your water tank. Drain water from the drain cock at the bottom of the tank, and see how dirty it is. If it is dirty, you need to drain the water until it is almost clear.
Aug 13, 2015 | Frigidaire ATF6000ES Front Load Washer
Somehow water is getting into the hydraulic fluid on the power steering system. this can be seen when taking off the cap on the pump, and checkinig the fluid level. There will be rusty brown water f
replace power steering fluid with new fluid bleed system sound like you have air trapped in the system.replace fluid and bleed system see what happens.
Nov 18, 2013 | Ford Aerostar Cars & Trucks
Overheating , losing water but no leaks can be found.
Recheck the water pipes it might happen that there is a small hole that leaks when the engine runs.
Apr 03, 2013 | 2005 Pontiac Grand Prix
Have a Pentair 7000 water softener, getting brown/gray water in my home! Any suggestions
I think this can also be due to rusty pipes or connections as it is seen to clear off after the initials flow. You can connect an online filter unless the water is confirmed to be hard and needs to be softenend..
Jun 26, 2012 | Washing Machines
Water is greenish brown
run run run that pump 24/7 clean clean that filter check ph first then balance other chems it will take awhile with well water to clear
Jul 14, 2017 | Intex Automatic Salt Water System for ...
Should I replace water pump at the same time as timing chain
Do this always!!!
Not worth the savings of the possibility of another teardown due to a water pump leak.
Most water pumps can outlast the timming belt but not by much.
After they remove the water pump take a look at it and see for yourself.
You will almost see guranteed a rusty blade housing.
Good luck,Gary
Sep 21, 2011 | 2002 Oldsmobile Alero
I get brown stuff coming back into the pool when I turn on the pump in filter mode. This goes on for about 30 seconds and then clears off, but the water remains cloudy even after long period of running...
You have a multi-port valve? There is a 'rinse' mode on the handle. After you back-wash, move the control to 'rinse' and run for 30 seconds or so ... them return it to filter mode. Always shut the pump off enwh changing the valve settings - ALWAYS wait at least 10 seconds when switching the pump from off to on. Always move the handle in a clock-wise direction.
I suggest you run your filter for longer periods each day, maybe even 24 hours until it gets cleared up. Have you removed the metal from your water using a sequestering agent? Use according to package directions. Balance your water. Keep the CL around 5 ppm, the pH at 7.4, the calcuim around 250, the TA at 100. Cyanuric acid should be betrween 60 and 100 but no more. Use "super blue" in your pool according to package directions. Have you checked the Combied Clorine? (The difference between Free CL and Total CL = Combined CL)
Jul 24, 2010 | Hayward SAND FILTER, PRO SERIES
Utomatic washing machine cannot drain the water
see if theres not something clogging the pump on ht e machine
Nov 02, 2008 | Washing Machines
Water Indicator Light constantly on
Sounds like the sensors is dirty, or there is scale or deposits in the bottle. Clean out the bottle with a descaler if it has any scale (white or brown) deposits in it. If it is clear and still a problem, the sensors is inside the bottle holding section. Make sure there is not any fluff or dirt in there by giving it a hoover outand a gentle brush.
Jan 19, 2008 | Zanussi TC7102W Electric Dryer
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
