Question about Canon Office Equipment & Supplies
How do I get Vista Print Driver for my IP 4000? I can't get Easy PhotoPrint to work
  • 137 Answers
You can download Vista drivers and updates for Easy PhotoPrint from Canon's website here.
Bob Headrick, MS MVP Printing/Imaging
Posted on Aug 20, 2008
AirPrint not working
there is a free App from Canon:
"Canon Easy-PhotoPrint" - try it airprint-not-working-50j4ioddfaeyronb2saotemk-4-0.jpg
Feb 12, 2013 | ASUS RT-N13U Wireless Router - 300 Mbps 1...
Cannot install Easy-PhotoPrint EX for Windows Ver 3.2
I think Canon is abandoning EZ photo Print and is now offering EZ Photo Print EX.
Basically same program but more options.You can try that.
If it not available from your model try to get it from a newer model.
I think you are talking about a MP450 .
Jun 19, 2009 | Canon Pixma MP500 All-In-One InkJet...
Won't work on Windows 98
Windows Vista(32bit), Windows Vista(64bit), WindowsXP(32bit), Win2000, WinME, Win9X 21350 KB
Canon PIXMA iP1800 Easy-PhotoPrint Ver.3.7.0 for Windows Vista/Vista64/XP/2000/98/Me
-"Photo Paper Glossy II" has been added to media type. -The problem that the scrolling action using the specific IntelliMouse may not be performed properly has been rectified.
Download / Installation Procedures 1. Click the link, select [ Save ], specify "Save As", then click [ Save ] to download the file. Memo : If you select [ Run ] ( or [ Open ] ) instead of [ Save ], the file will be automatically installed after it is saved. 2. The downloaded file will be saved in the specified place in the self-extracting form ( .exe format ). 3. Double-click the downloaded EXE file to decompress it, then installation will start automatically.
If you have a problem with the 'DOWNLOAD' hyperlink above, go here to download at the bottom of the page.
May 05, 2009 | OEM Systems PIXMA iP1800 Photo Printer
Settings for printing a borderless 8x10 on a canon i9900
Downloaded following program for Vista and was able to print borderless pictures on Canoni9900
Easy-PhotoPrint EX Ver.2.0.3 (Windows Vista/Vista64/XP/2000)
Mar 02, 2009 | Canon i9900 InkJet Photo Printer
IoGEAR printserver GPSU21 with VISTA
Yes, the GPSU21 is tested to work with Vista 32 and 64-bit Operating System. The things you need to do is listed below:
1. There's no need for you to install the CD that came with it, if the MFP Utility is already installed in another computer.
2. Get the IP Address of the GPSU21 from the computer that has the MFP Utility installed.
- Open the MFP Utility > locate TCP/IP at the lower portion of this window and click the plus (+) sign. > get the IP Address.
3. After getting the IP Address of it, go to your Windows Vista computer and ping the IP Address (just to make sure that Vista is seeing the Print Server).
- To ping, follow the steps below:
- Click the start menu and open the MS DOS Command Promt.
- On the black screen, type this "ping (type the IP Address of the print server): just like this
- C:WINDOWS\Desktop\Scott>ping 192.168.x.x and then hit enter.
4. Once you get ping statistics 4 packet sent; 0% loss. Then the Print Serve is communicating with Vista.
5. On you Windows Vista computer, make sure that the printer is working when directly connected to it. Because there could be a possibility that the printer driver is not properly installed that's why the server is not working.
6. On Vista, go to the Control Panel > Printers > Locate the printer icon (the one that is set as you default printer)
7. Right-click on the printer icon and then select properties > go to Ports tab.
8. Click on Add port button > select Standard TCP/IP > click on "New Port" (beside Cancel)
9. Hit next > type the IP Address of the print server. > Next
10. Click on Custom > Settings button
11. For Protocol: select LPR
12. For the Queue Name: type L1 > Click on OK > Finish.
13. Then under the printer properties, you will see the Standard TCP/IP is selected
14. Hit Apply so that the printer name would appear right next to that port > OK
15. Try printing a test page.
NOTE: After following the steps, you should be able to print using your Vista computer. I configured this print server with Vista several times and it does work with Vista.
Feb 19, 2009 | IOGear GPSU21 Print Server
I need to download the start up disk or whatever I need to setup my printer again. I had it disconnected but now that it's reconnected I cannot find the start up disk that it's asking for. It's a PIXMA iP...
Hi sarafian -
Here is a website address that has the drivers for your specific Canon printer.
You can go ahead and click on the link that says Download Canon PIXMA iP6210D Easy-PhotoPrint v.3.61 driver. Just a heads up that I would not connect the printer to the computer until it asks you to during the driver installation.
Hope that helps,
Take care,
Nov 15, 2008 | Canon Office Equipment & Supplies
Canon i250 printer will not work with window vista os
The Vista add-on module driver (whatever THAT means!) can be found here. Have you tried downloading this Vista driver already?
Hope this helps :)
Oct 06, 2008 | Canon Office Equipment & Supplies
My vista laptops find my belkin router, but i am unable to print with the belkin print server. Both work perfect with my XP pro home compuer. Have changed ip/tcp address acording to belkin website but with...
Is the printer driver installed on the vista machine? You might need to install the driver as if it was local, then create a virtual tcp/ip port to print to, and reassign the printer to the tcp/ip port.
Sep 16, 2008 | Office Equipment & Supplies
I have just got a Canon Pixma iP4500 but as I use a Mac with leopard OS X 10.5.4 I have had great difficulty with the Easy-PhotoPrint EX that I had to download. When I want to select a photo to print only...
Mac OS X v10.5 Compatibility For Mac OS X v10.5 compatibility, see below:
<Supported models>
BJC-2100, BJC-8200, BJC-85, DS700, DS810, i250, i320, i350, i450, i455, i470D, i475D, i550, i560, i70, i80, i850, i860, i900D, i9100, i950, i960, i9900, iP1500, iP1600, iP1700, iP1800, iP2000, iP2600, iP3000, iP3300, iP3500, iP4000, iP4000R, iP4200, iP4300, iP4500, iP5000, iP5200, iP5200R, iP6000D, iP6210D, iP6220D, iP6310D, iP6600D, iP6700D, iP8500, iP90, iP90v, mini260, mini320, Pro9000, Pro9500, S200, S300, S330, S400, S450, S500, S520, S530D, S600, S630, S750, S800, S820, S820D, S830D, S900, S9000
<Supported software>
- Printer driver
- Memory Card Utility
- Network Tool
- Setup Utility
- Easy-PhotoPrint
- Easy-PhotoPrint Pro
- Color Management Tool Pro
- Easy-PhotoPrint EX
To use with Mac OS X v10.5, download the latest version of the software from the Canon Web site.
For Easy-PhotoPrint and Easy-PhotoPrint Pro, use the counter-measured version available for download.
The following models, the printer driver is included in the OS.
BJC-2100, BJC-8200, BJC-85, DS700, DS810, i250, i320, i350, i450, i455, i470D, i475D, i550, i560, i70, i80, i850, i860, i900D, i9100, i950, i960, i9900, iP1500, iP1600, iP1700, iP1800, iP2000, iP3000, iP3300, iP4000, iP4000R, iP4200, iP4300, iP5000, iP5200, iP5200R, iP6000D, iP6210D, iP6220D, iP6310D, iP6600D, iP6700D, iP8500, iP90, iP90v, mini260, Pro9000, Pro9500, S200, S300, S330, S400, S450, S500, S520, S530D, S600, S630, S750, S800, S820, S820D, S830D, S900, S9000
Jul 17, 2008 | Canon Office Equipment & Supplies
Pixma MP530 Printer Driver
You might have installed a wrong drivers here is link for drivers.
Please select an appropriate driver from the list that opens through this link.
Click here
Nov 27, 2007 | Canon PIXMA MP530 All-In-One InkJet...
old marine
old marine
