Question about Toshiba TZ50V61 50" Rear Projection Television
Problem Someone gave me a 50 in Toshiba TZ5061 Projection TV, it worked fine for him but I got it home, plugged it up and it stays on for about 10 seconds and powers off and the red power light just flashes. I try another outlet with the same results. What could be the problem?
  • valkanizer Feb 26, 2009
    Same thing. . .tv just went black, "power on" indicator light flashes. Unplugged, replugged. . .nothing. Are these tv's worth fixing? Really like to picture and dimensions. It's 9 yrs. old. Didn't really get used much until the last 2 years.
With my projection tv , i have a Mitsubishi dlp, the screen went black and a red light flashed it was the bulb that had to replaced i dont know if that maybe your problem.
Posted on Aug 20, 2008
I have on Sony KDF55E2000. 55 inch projection. Power wont stay on
It is clear symptom that lamp is near to end of its wroking life and tv needs lamp replacement.
Please replace lamp in tv to get it back in business. Lamp replacement procedure would be written in user manual and its easy.
Please buy Sony original lamp for good picture.
Let me know if you have additional question.
Thanks.
Apr 17, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
No sound
More than likely you need to go into your menu settings. Check to ensure that your TV speakers are enabled. The previous owners may had it hooked to theater system
Oct 20, 2009 | Toshiba TP50G60 50" Rear Projection...
1999 toshiba rear projection tv blinking red light after moving
this might be a tube leak check for fluid on the necks of the tubes with your hand. if none you might have a faulty protect chip- common-
forgot the exact location but it's on the main board, it's a 16 pin chip as i remember and it is a quad op amp. if you hold your finger across the pins underside it will turn on and stay on as long as your finger is there, if so replace the chip
Dec 25, 2008 | Toshiba 50H81 50" Rear Projection...
Mitsubishi vs-50609 wont stay powered on
Hello nicolastran,
I gave this advice to someone with this same problem so here it is again:
It sounds like your shutdown circuit is being activated. This is due to excess current being drawn. This usually happens in the High Voltage section of the TV or one of the deflection stages. Due to the nature of this problem I would suggest that you take it to a local TV repair shop or have a TV repair person come out and take a look at the issue. The HV section is dangerous and should be dealt with by a qualified TV repair technician.
Thank you,
I hope this helps
Shuttle83
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Toshiba HD Projection TV
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Feb 26, 2008 | Toshiba 50HX70 50" Rear Projection...
The tv turns on but no picture.
Mine did the same but no picture, just sound every few seconds for 1-2 seconds. I unplugged from the wall for 10 seconds and plugged back in, works fine now.
Jan 12, 2008 | Hitachi 60UX54B/55K 60" Rear Projection...
Issues with picture after moving Toshiba 50HX81 - picture is bad
i would check for loose connections by the convergence amp ics
Dec 25, 2007 | Toshiba 50HX81 50" Rear Projection...
Toshiba TZ50V61 50" Rear Projection Television Logo
405 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
