Question about OKI MICROLINE 320 Turbo Matrix Printer
Printing The printer will print about half a page then will stop. If you hit the power button it will finish the page. Printing more then one page it will do the same thing over and over again. Thanks for any Help
  • OKI Master
  • 5,568 Answers
It sounds like the 'form length' is misset.
Check the initial setup settings.
Posted on Aug 26, 2008
Prints half page
Printing half a page with an Inkjet machine is not normally a computer issue. So windows 10 would not normally have any effect on the printing for a printer that has been accepted by the Windows 10 Operating System. If there was an issue in the software it would be printing gibberish or not printing at all.
Printing half a page is quite possably something stuck in the printer stopping the ink from getting to that half a page if it is printing down once side but not the other.
Printing half a page being that the top half is printed but not the bottom half (Or the other way around) it could be an air bubble in the feed line which can be cleared with a printhead clean or two.
Printing half a line rather than a full line such as the top half of each letter is clear but the bottom half of each letter is not visable is a blocked printhead. A couple of printhead cleans can also fix this.
Also check to see if the printer is not confused and actually has empty cartridges even if the printer thinks they are full. Brother printers can easily get confused about ink levels. If the cartridges are actually empty, replace them and away it should go again.
Hope that helps
Mar 09, 2016 | Brother MFC-490cw All-In-One Inkjet...
Waht is calibration
firstly power off
then
while feed button press, power on
wait printing test page then release feed button
wait stop printing then power off .
now start nor mal power on
calibration now finish
Jun 11, 2014 | Argox OS-204 Thermal Label Printer
Waht is calibration key
Firstly power off
then
Samsung clp-315 printer stops printing after half page
You'll probably have to replace the exit sensor (lots of people have this problem). Go to YouTube and watch this video: 5fJHykzkfww
You can get the part on eBay for about $10 and it's a fairly simple 15 minute fix.
Sep 22, 2009 | Samsung CLP 315 Laser Printer
When printing multiple pages it prints 1 and & stops & no more
Go to Kodak's site and download and install the firmware upgrade for the printer. Follow all instructions on their site for doing this. There are some printers that have this known issue and apparently is fixed by firmware updates. Also uninstall the printer driver (after successfullly doing the firmware update) and reinstall it. Reboot the computer after reinstalling the printer driver.
Mar 19, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Samsung printer ML-1450. When the first page is being printed, paper stop at half-way. Open the lid and close it again, it finishes printing the first page and spills out a blank page as well. This problem...
my printer not work in win xp and also in dos i send data to printer but first line of first page come true after that print another text that havent any meaning what can i do?
Oct 14, 2008 | Office Equipment & Supplies
HP Deskjet F300 All-in-One series. Had been printing well,and then just stopped when half way thru a page. I turned it off for a couple of minutes,then on again, it finished printing the page, and will now...
Hello ,
We will start with a reset . Pull out the power cable from both ends.Let the cable stay isolated for 20 seconds . Then follow the steps below -
a. put the power cable to the wall socket first
b. press and hold the power and paper type button together and insert the power cable ...... do not release the buttons till all the light flash together - leave the buttons.
c. let the alignment continue if it does....
d. see if the printer is steady and perfect
******* If the printer does not turn on at all then try connecting to the different wall socket / connection....otherwise this printer needs servicing.
Apr 12, 2008 | Office Equipment & Supplies
Trouble with changing the size of letter
Press the select button so light would go off than press 2 buttons marked menu than press print,this will print out the menu settings .When done press the group button till rear group prints than press item till page lenght prints,now press the set button till the desired page length is reached,than press exit button to save setting and exit from menu.Power off the printer then power back on should be ok .Hope this helps.
dezzi
Feb 04, 2008 | OKI Pacemark 3410 Matrix Printer
Last page of printing stops 3/4 through the page.
Try cleaning your heads with appropriate solution. Then, cancel all print jobs. Try again. If it does the same i would turn it off, inplug all the cables, replug all and turn on. Try again. If still no good, completely unistall printer then reinstall it. Try once more. Good luck
Jan 16, 2007 | HP PSC 2175 All-In-One InkJet Printer
OKI MICROLINE 320 Turbo Matrix Printer Logo
323 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
