Televison & Video Logo
Posted on Jun 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a multi disc DVD player, When I tried to eject a disc, the caddie opened, however the disc did not come out. How do I get it out of the machine without damaging the machine or the disc?
Joseph Hoffmann
Level 3:
President:
  • Master 1,756 Answers
  • Posted on Jun 14, 2011
Joseph Hoffmann
Master
Level 3:
President:
Answers
1756
Questions
Helped
409547
Points
4988
Hi, Give more detail please. Does it have 5 disc changer on a rotating drawer or does it have cartridge. You may have to open metal cover to retrive the disc. Good luck.
WILL NOT EJECT DISC
What is the model number of your DVD player? You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
FOR SONY PLAYER's
This issue may occur if the disc is damaged or if the disc was not inserted properly into the Blu-ray Disc® player. Follow the steps below to open the disc tray and eject the disc.
  1. Turn off the Blu-ray Disc player.
  2. Disconnect the power cord (mains lead) or AC adapter.
  3. Allow the disc player to remain without power for 30 seconds.
  4. While pressing the OPEN/CLOSE button located on the front of the disc player, reconnect the power cord.
    IMPORTANT: For some Blu-ray Disc Home Theater models it is necessary to press and hold the OPEN/CLOSE andPLAY buttons simultaneously, then reconnect the power cord.
    NOTE: This step may require the assistance of a second person.
  5. After reconnecting the power cord, when the tray opens, release the OPEN/CLOSE button.
  6. Remove the disc.
  7. If necessary, disconnect and then reconnect the power cord to recover the player.
Dvd read stuck canot open dvd canot eject dvd canot play dvd
if the disc was not installed in the plate fully and partly out in the front sometimes it gets stuck and u have to unscrew your dvd player andtake out the disc and it should work perfectly fine afterwards
What dvd players do the mini dvd-rw discs play on?
Hello sir/ma'am good day, all dvd players has this small circle on the center of the tray, where you play the mini dvd disk. eject your dvd tray to see. hope this helps. thanks
2helpful
2answers
My LG multi dvd writer lightscribe tray wont open. the green light is steady. no matter how many times i try to eject the tray ang it wont open. there is dvd+r inside.
use a unfolded paperclip and insert it into a small hole below the disc tray. This is the manual eject port. Stick it straight in and push, a little bit of pressure will be needed.
DVD disappeared in DVD Player after viewing movie
Get the dummy cd disc, put a blue tac on it. Insert it. Then after few seconds, eject it. Your dvd disc should stick with it when they came out. It worked for me and hope it will work for you.
3helpful
2answers
Sony DVP-NC85H Multi-disc DVD Tray locked
Look on the bottom of the unit. There is a hole with the letters ex and op. Shine a light in the hole and you will see a white plastic object with a slot for a slot screwdriver. You can turn this either way but be careful. If you feel resistance and the object does not turn, turn the other direction and the unit will open. Remember if the disc loaded the clamping of the disc is in place so you must turn it the proper way to let the current disc loose hence the op and the ex. Op is open. Ex is exchange.
JC
3answers
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
2answers
Need help! DVD tray won't open
soundsa as though there is a draw drive problem and that could be a motor or as simple as a belt?? are you sure tjhat the eject button works properly as I found out on these denons that the eject switch or push button wont make contact with the switch behind it because the Printed cuircut board shifted??
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
