Question about Philips 50P8341 50" Rear Projection Television
The color is red and green, and theres two pictures on the screen, one red and the other green. how do you fix that?
Same as above. The red and green are off and making two pictures.
Maybe its broken cuz you should support your kids instead of buying stupid televisions jeremy john zaske in willmar mn.
Posted on Sep 16, 2008
  • Philips Master
  • 8,617 Answers
You need to replace both convergence ICs they are STK392-110 you can get replacement ICs at the following link with free installation instructions.
http://servicemanuals.vstore.ca/
Posted on Aug 20, 2008
I saw an answer up above regarding the green hue on the projector, is there anyway to remedy this problem? This is really annoying to me and I would like to fix the issue. Thanks,
Three LCD block in the Panasonic projector PT-L735 green,blue and red and two polarizer use with each LCD (as show in picture below) when polarizers faded due to age or any other reason then screen show the color. In your cause the green polarizers faded and need to be replaced good_help_9.png
Jan 08, 2011 | Panasonic PT L735U Multimedia Projector
The color there is red above a letter and green
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 18, 2010 | Philips 60P8341 60" Rear Projection...
Picture is not focused, color is off. When we
this sounds like the convergence ic's need to be replaced that should fix the problem
Jan 25, 2010 | Hitachi 57F500 57" Rear Projection...
The color on the screen is green when I watch movies. How do I fix this problem?
Good day sir, your inquiry about the green lcd screen can be caused by several things. 1. The monitor/tv produces 3 colors, red green and blue, the tv mixes these three colors to produce the picture. a loss of red and blue produces this green screen. so check the cable, specially the red and blue jack of the component inputs, and the red and blue cable. 2. there may be loose contact on the signal cable. try using the video input instead of the component input. 3. the dvd player may have the problem, check the player component out jack. a loose jack port can cause these problem. hope this may help. thanks
Jul 20, 2009 | Toshiba 32AV502U 31.5 in. LCD HDTV
Double picture & color problem
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 22, 2009 | Sony KP-53XBR45 53" Rear Projection...
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
Red , Green And Blue.
Heres the best way to set a phillips screen controls. Go into the picture controls and set picture or contrast to roughly 75%, then set brightness to 50% and then set the color level completely off. Then adjust the screen with the 3 color controls untill you recieve the best black and white picture as possible. If you are unable to achieve a good black and white picture change the coolant in the green and blue tubes. But if you can get a good black and white picture stop there then turn your color level back up and the picture should be correct. Let me know if you need further assistance.
May 22, 2008 | Televison & Video
Yellow Haze Center Screen
The blue filter is burnt out. A very common problem in Zenith DLPs. There are 3 color filters, 1 blue (a pinkish color), 1 green (a grayish brown) and 1 red (it is red) they give you your colors for you picture. This is a simple fix.
Mar 19, 2008 | Zenith E44W46LCD 44" Rear Projection...
I have 47 inch with double color in picture, reds and green
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
convergence amp ic bad
Oct 14, 2007 | Samsung HCL552W 55" Rear Projection...
Toshiba 43H70 HD Projection TV
this is a convergence failure, there are hundreds of posts about it on this website you should be able to find everything you need
May 23, 2007 | Toshiba 43H70 43" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
46 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
