Question about Dryers
I have a four point connector plug how do i esemble the wires
    Genius:
  • 2,920 Answers
The green one goes to the frame of the dryer the white wire goes on the center nut and the red and black can go on either side of the white wire
Posted on Aug 20, 2008
No fire to plugs on kawaliski 19 hp. lesco commercial mower
bad fuse, plug,plug wire,ignition coil,ignition coil wiring,badpick up sensor,faulty cdi,cheers
Jul 07, 2014 | RTO 200cc Full Size Four Wheeler ATV
New PSU doesn't have four point connection
You can still use this power supply but you will need to purchase a 4 to 8 pin connector . you can find them on ebay etc. You can also use two power supplies, one for gfx card one for PC. I use two. To turn on a PSU without it connected to PC ( just to use it as extra power.) You just have to connect the green wire to any black wire with a wire or paper clip. (At your own risk. Set pins first tape off and turn on by plugging into wall) . Good luck.
Nov 29, 2013 | Acer Aspire Computers & Internet
I am trying to install a power supply for my Dell Dimesion 1100 desktop computer
The power supply is held in place by four screws. You will need a philips head (+) screwdriver for the job.
See this diagram as you read the description below.You will be using this diagram to identify different types of connectors... ignore any voltages or wire descriptions/colors that are there.
As for the wires, there are a few different types.
Main Power Connector You will notice a larger connector with 20-24 wires coming out of it. This will connect to the motherboard (and will only plug in one way). Notice there are two different ones on the diagram... one is 20 the other is 24... you probably require the 20 if I was guessing. If there is an extra bit on your connector (to compensate for 24 pin connectors), just ignore it... It will be fine just resting aside the others not plugged into anything.
Peripheral Connectors and Sata connectors
Your hard drives and Cd drives will either use 4-pin (four wires per plug, bout an inch in width) and will only plug in one way, or will use a SATA power cable which is also about an inch wide, will probably be black on the connector, and looks like it has an L shape inside it. These all just snap in place. Make sure each hard drive, and each Cd drive has a power cable going to it. (if there are multiple choices, it makes no difference, as long as everything has power.
If you have an after-market or third party video card (one that you have added or purchased separately) it may require its own power wire... This will (in most cases) be a four wire connector, and will plug into the edge of the video card. If you have not purchased a video card, this wont be a concern, as the default video gets its power from the motherboard its self.
+12v Power Connector
Lastly, there may be an extra power plug that goes to the motherboard (it will be four or six wires and will be arranged into a cube... unlike the hard drive wires which were in-line.) This four-wire square plug (or six wire) will plug into the motherboard somewhere near the processor.
Hope this helps!
Feb 25, 2011 | Dell Dimension 1100 PC Desktop
Xs750 what is the firing order
There is no firing order. Your bike has a coil that fires on both the compression stroke and the exhaust stroke (also called a wasted spark). Therefore either plug wire can go on either cylinder and the bike should run the same.On four cylinder bikes this meant that you could run four plugs using only two coils and two sets of points instead of four coils and four points.If the bike is running poorly try new spark plugs and new spark plug caps first(start with the cheap stuff). Next check the actual coil and pulse pick up or points. You may have to replace the coil only because the wires are cracked shorting.
Jul 25, 2010 | 1979 Yamaha XS 650 SF
Order of the connectors on the X7G-NAGAVI?
OK, you will have four connectors (each one with pink and white wires), there are two set of the connectors, two are above the transformer, two below the transformer. The monitor uses four lamps, two for the top side of the screen, two for the bottom side of h screen. You can plug either one of the pair of the connector to the top group of the connector, same for the bottom group of the connectors.
http://s807.photobucket.com/albums/yy352/budm/Sceptre%20X7G/
May 05, 2010 | Sceptre 17" LCD Monitor
Convert three pin plug to four pin
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Sep 06, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Electrical question regarding speed four
you could try T595.net ... they have lots of smart guys with answers to stuff like this ... at a guess you are looking for a bundle of black wires that goes to a socket/plug under the seat ... the plug will have one or two loops of wire making the ignition circuit ...
If you had a factory alarm fitted it would be plugged directly into this connector
Apr 20, 2009 | 2003 Triumph Speed Four
Using 4 wire plug on 3 wire dryer
YES TAKE THE GROUND WIRE OF THE NEW PLUG AND CONNECT IT TO THE FRAME OF THE DRYER UNDER AN EXISTING SCREW OR USE A SELF TAPPING SCREW THE FOUR WIRE SYSTEM WAS PUT INTO THE CODE MOSTLY TO INSURE GOOD GROUNDING ON MOBILE HOMES AND THE METHOD WILL WOKE FINE AS I HAVE GIVEN YOU
Nov 16, 2008 | GE Dryers
I purchased a new ice maker for model ED5GHGXMQ00 which at this point number four for a 4 year old model. The model that I purchased is 4317943 but it will not come on.I plug the old one back in and it...
check the electrical connection at the end of the connector that plugs into the icemaker module the one with the black white tan and green wires look to see that the ends of the connector are not spread apart
May 09, 2008 | Refrigerators
Dryers Logo
Top Dryers Experts
