Question about LG TRAX Cellular Phone
LG Trax Cell phone
Says charging when not plugged into charger
Received a multimedia video via text message but says it cannot retreive it. what is the problem?
Posted on Aug 28, 2008
Phone it self was shorted inside, was replaced with no questions asked.
Thanks Dan T.
Posted on Aug 24, 2008
Does not get charge,plug in the wall charger and does not work, use the same charger in other lg phone and works perfect.
I think you have to bring it to an LG Service Center or a "Certified" Service Center to look into your phone. I think your charger jack is broken or loose that is why its not charging.
Hope this helps! -jayps
Mar 09, 2011 | LG KC910 Renoir Cell Phone
Lg dare won't charge
Best thing to do is take it to a dealer pref the one you bought it from.Try a new battery, if not try and charge the phone with a different charger.
if its not the battery or charger then its likely to be a phone fault.
I would either request money back or new phone.
Hope it helps.
Dec 16, 2009 | LG Dare VX9700 Cell Phone
Wont charge
Try a car charger. If the car charger works, then it is either
A) Your power outlet
B) Your wall charger Power Supply unit
C) The phone connector on your wall charger.
If it doesn't work on the car charger, then it is most likely your phone charging system or the connection for charging on your phone. Either way, you will most likely need a new phone. Sorry.
Sep 23, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Lg trax phone wet - new problems!
take in for repairs water shorted circuits and components
Jul 09, 2017 | LG TRAX Cellular Phone
My daughter's LG EnV charging port
You can get a charger at factorydirectcellular.com. The link is
http://www.factorydirectcellular.com/home/universal/universal-battery-only-charger.htm
The charger charges the battery independent of the phone. It is the only one I have found and it works GREAT. I had a couple issues at first but the rep, Matt, bent over backwards to resolve them. I would recommend this charger and company to anybody. The charger is a universal charger and will charge other cell phone batteries as well. The only con is that it does take a little longer to charge than using the port.
Sep 06, 2008 | LG enV VX9900 Cellular Phone
Lg mobile battery indicator
Have you tried a different plug? Sounds like the plug might be bad. If you have a car charger, and a house charger, I would try both. IF one charges, and the other one doesnt, you have your answer. If you have trouble with both, then either you have 2 bad plugs, or the socket on your phone might be bad.
Either way, your local phone dealer can check them out in seconds, and some places won't even charge.
Good luck
Feb 03, 2008 | LG KG220 Cellular Phone
LG Trax Phone - headset adaptor
I recently bought a similar adapter for my trax and had the same problem. Taking the plastic cover off of the adapter, I found the following on the back of the 18 pin connecter: a jumper from pin1 to pin 11, a jumper from pin 9 to pin 10. audio l and r wires to pins 14 and 15, common audio wire to pin 18 and unconnected pin at pin17. By accident, I found that if the unconnected pin 17 bent over to touch the wire to pin 14, the headphones started working. So, solder a wire to connect pin 14 to 17 reinsert these pins into the correct slots and you have a working adapter.
Dec 26, 2007 | LG CU500 Cellular Phone
LG TRAX Cellular Phone Logo
93 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
