Question about HP Photosmart 735 Digital Camera
Camera will not format new 2 GB card
HP Photosmart 735 camera
  • 1 more comment
  • maxwellhouse Sep 01, 2008
    Tried formatting on Computer, but when i put the card back in the camara it still says unable to format
  • ghobbs1 Nov 23, 2008
    get a message that card needs formatting, then when try to format get another message saying card is corrupted. Tried with several new cards.
  • Anonymous Jan 26, 2009
    i have the same problem. when i try to format camera says "unable to format"
Use Panasonic SDFormatter from
http://www.sdcard.org/consumers/formatter
Select FULL format and format size adjustment ON. Then the card is working!
Posted on May 13, 2009
Maximum capacity of camera is 512mg. I have the same problem
Posted on Nov 05, 2008
  • HP Master
  • 5,569 Answers
Try formatting it via your PC if equipped with a card drive.
Posted on Aug 20, 2008
SOURCE:
Troubleshooting hp photosmart camera
Go into your menu options and format the card. If that does not work then you may have a defective card
Aug 27, 2014 | HP Photosmart 735 Digital Camera
It's did not take memary card. it's sey's format the memary. I reformat memary but same problem and after chenge new memary displyed same problem. it's can fix??
The 4GB card is an SDHC card and will not work in the 735. The 2GB card should format in the camera. Make sure it's not write-protected. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 28, 2012 | HP Photosmart 735 Digital Camera
Can't format a 2 GB sandisk chip !
try to see if it isn't locked if it is a SD card than it has a slide on a side..and the lock will prevent any delete or add activity ..including formatting ..
if it is another kind ..just insert it in a computer and see the properties not to be locked..or set to read only ..than in the my computer folder right click on it ..and format it in Fat ..after that insert it in the camera and try to format it again there ..
May 31, 2010 | HP Photosmart 735 Digital Camera
How do I upgrade my camera to use SDHC Card?
Sorry, there's nothing you can do. I think you should give serious consideration to upgrading to a new camera with wonderful features that I'm sure you'll love.
Mar 12, 2010 | HP Photosmart 735 Digital Camera
I have an HP 735. How can I empty the digital card
There are three ways to empty your memory card of your digital camera:
1. if you have a PC or Laptop, you can use your card reader and your file browser to either delete all of the folders or you can choose to format your memory card.
2. you can also erase each picture by deleting them one by one by using the erase command on your digital camera but this is to tedious a task.
3. the best way to empty your card reader is to go to the menu options of your digital camera, go to format memory card. it is also advisable to format your memory card periodically to remove any traces of bad sector or any viruses acquired in photo studios or any computer during picture downloads.
Jan 13, 2010 | HP Photosmart 735 Digital Camera
Formating SD card
You can do the steps indicated in this manual:
Hope this helps you. Please let me know.
Sep 22, 2009 | HP Photosmart 735 Digital Camera
Can not formate my new 4GB SD Card...
The 735 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in devices not designed for them. You need to use SD cards, 2GB and smaller.
Aug 15, 2009 | HP Photosmart 735 Digital Camera
Can't format 2 GB sd card for HP 735 camera
Make sure the SD card is unlocked. There's a tiny switch on the side. Put it into the camera. Under storage, when you select the card, also select format.
Mar 13, 2009 | HP Photosmart 735 Digital Camera
HP Photosmart 735 Digital Camera Logo
277 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
