Question about Miele Vacuums
Miele Deluxe 5247i Air Clean Plus Canniter
The hose is clogged. No one is admitting to clogging it so I don't know what is up there. I tried a coat hangar but it wouldn't go far enough and the attachment at the end of the hose is angled. Can the end attachments be taken off? Any suggestions?
  • 89 Answers
Most vacuum hoses are made so you screw off the end attachment not real familiar with your model but pretty sure you can do that then just disattatch from canister and run broom handle through it hope this helps
Posted on Aug 20, 2008
Oreck BU 10010 air passage blocked
If the clog is not at the nozzle just behind the roller brush you may need to disconnect the hose and clean it out. If you are careful not to puncture the hose try a coat hanger.
Nov 14, 2013 | Oreck Touch Bagless Upright Vacuum,...
Clogged miele hose
If you can safely remove the whole hose the best way is with compressed air or I sometimes use a long flexible wire to pull it out.
The hard plastic on the ends is pressed on and not intended to be removed, careful with that.
Dec 11, 2012 | Miele Vacuums
The air turbo head for my miele flamenco II S251i spins but doesn't have suction
Check all the filters as well. We have dogs and the hair clogs up the filters. We take a air hose threw our vacuum once a month and it works like new again without replacing anything
Jun 07, 2012 | Miele Vacuums
I misplaced manual for Bissell Bagless Cleanview II, nothing being picked up in the plastic bin, where to I look for clog other than bottom of hose near bottom plate please?
Recline the vacuum fully to the floor when looking for clogs in the lower hose. You can run a broom stick through the upper hose to remove any clog. Also, check the brush to make sure there is no obstruction. Lastly, make sure all 3 filters are clean and clear because if they are dirty that can restrict air flow drastically. You can purchase filters at www.bissell.com
May 29, 2011 | Bissell Cleanview Helix Deluxe Bagless...
The vacuum seems to have lost a lot of suction power and it is only a month old. Seems like there is a clog or something, all filters are cleaned and after a vacuuming session, nothing is in the...
sounds like there is blockage in the suction hose -- lay the machine down and remove the lower floor plate and clean out the hose area where it bends down to the floor unit ( use a wire coat hanger to fish out the blockage ). also check the main hose for any obstructions.
c...
Feb 17, 2011 | Bissell Cleanview Helix Deluxe Bagless...
Warning light on, vacuum will not turn on
Your machine is clogged ... probably in the hose.
ASSURE the air path is clear and the filters are clean before yhou proceed.
Let me know how you make out on this.
a
Sep 23, 2009 | Miele S558 Red Velvet Bagged Canister...
Mine is a new upright Meile power plus. When I have it
Sounds like you have a clog. There are screws in the back of the vacuum that you can undo and find the clog. If you need assistance or if that doesn't solve the problem.
http://miele.com/locator/locator_new.asp?nav=800&snav=800&tnav=800&oT=7
^this will help you find an authorized Miele repairshop.. you can also call them at (888) 785-2828
Aug 31, 2009 | Miele Powerhouse Plus Bagged Upright...
I have a Dirt Devil Vision and when I put a clean canister back in place the suction at the bottom of the filter clogs up and very rarely go into the canister. Also where the air blows out of the motor, I...
yes your intake hose is clogged thats the clear hose you can see it on the bottom from the back.disconnect the upper hose from your intake hose and try to push a coat hanger through with the end of the coat hangers end bent till its rounded so you don't puncture the intake hose
Jan 05, 2009 | Dirt Devil M086700 Vision Bagless Upright...
Cluged vacume hose, new carpet
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=689534
Generic problem for all Vacuums
Clogged vacuum hose, new carpet
Posted by dpatricksr70 on Jun 20, 2008
Clogged vacuum hose, new carpet, have been through two vacuums already.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. When vacuuming it is a good idea to give your vacuum a burst of air once in a while to clear the hose and push the dust and dirt into the bag, simply just lift up on the powerhead or vacuum hose and give it a burst of air every 5 or 10 minutes. Also, we you like to know the brand name and model # of the vacuum. Some of the ways are to use a round metal ball or marble to see where the clog is in the hose and then you can use such things as the end of a broom handle, or you can use a wire coat hanger and bend the end to make a little hook and then try to grab the clog and say fish it out – or if you have another canister or shop vac you can tune on both canisters and try to pull the clog apart and sometimes that works as well – just be careful so that you do not puncture the electric hose because they are expensive in the area of $100.00 or more in some cases. If you need further assistance please feel free to contact your local vacuum cleaner dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 20, 2008 | Vacuums
My Miele cat & dog
Will it power up without the hose attached? If it does then you have a clogged hose. If not, there is a circuit board by the motor that may be bad.
Mar 22, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Vacuums Logo
268 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
