Question about Janome Memory Craft 9000 Computerized Sewing Machine
Pfaff 1212 i can't pick up thread from my bobbin. I've threaded and re-threaded the bobbin but i can't figure it out.
  • 35 Answers
Check your needle and make sure that you put it in the right way. You should have the flat side of it to the back.
Posted on Mar 19, 2010
Check that the needle is in correctly.
Posted on Aug 28, 2008
My Pfaff synchrotronic 1229 will not pick up the bobbin thread. It was sewing fine, I stopped to put in new bobbin and now it wont pick the thread up! Grrrrr...
Um, quite possibly something to do with the bobbin you installed. Check that it was loaded correctly. You might also try a different bobbin and different thread--could be something defective with that particular bobbin. Try a brand new needle, just in case. If still issues, then may consider taking it for service.
Jan 20, 2018 | PfaFF Sewing Machines
Pfaff quilting machine bobbin stuck
Is there is a wad of thread that is holding the bobbin captive? If so, you'll need to use small scissors and tweezers to snip away and pull out the threads. Patience!
If the bobbin is actually stuck in the bobbin case, it could be because it is the incorrect bobbin for the machine or the bobbin was over-filled with thread. You may just need to use force to remove the bobbin. It may damage the bobbin and, possibly, the bobbin case. They are both replaceable. Or you can pick up an additional bobbin case and bobbin and try the new ones in your machine.
Mar 10, 2017 | PfaFF Sewing Machines
Pfaff 1196, needle won't pick up bobbin thread. Can I fix that?
First, be sure you install a brand new needle. Old, damaged needles frequently will not pick up the bobbin thread. If not that, then the machine is out of time. Search the internet for sites and videos discussing sewing machine timing or take it for service.
Dec 18, 2016 | PfaFF Sewing Machines
I have a pfaff 2040 and when the needle goes down to pick up the bobbin thread the main thread wraps around the bobbin housing and jams. Doesnt grab the bobbin thread. How can I fix this?
Be sure to use a brand new needle because a bent needle could miss the bobbin thread.
Search the internet for sites and videos relating to sewing machine timing or take it for service.
Dec 02, 2016 | PfaFF Tiptronic 2040
My Pfaff grand quilter 1200 keeps bunching up the top thread on the bottom side of my quilts. I've replace the needle and thread. It won't pick up the bobbin thread. Could this be a timing problem?
Remove the thread from the machine. (Always raise the presser foot and pull the thread up, NEVER down!).
Install a brand new needle.
ALWAYS RAISE the presser foot when threading.
Rethread from the beginning and verify the thread pathway is correct.
Set the upper tension to midway between High & Low numbers--you may need to tweak this for your particular machine, but this is a standard starting point.
Confirm the bobbin is loaded and threaded correctly in the bobbin case.
Begin sewing slowly. It helps if you begin sewing with the needle in the uppermost position.
Test on medium weight woven cotton.
If it is still not picking up the bobbin thread, then it most likely is a timing problem. You can search the internet for web sites and videos regarding sewing machine timing or take it for service.
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
What causes Bird Nests Superior Threads
Nov 21, 2016 | PfaFF Sewing Machines
Hi I ahve a Bernina H70 model and I've been working for hours trying to thread the bobbin so the top thread picks up the bobbin thread...help!
make sure the presser foot is at it's hightest position, then thread the top
of the machine
change the needle
make sure the bobbin is not over full
that it is turned the right way in the bobbin case
if none of these suggestions work,,it is also possible that the machne is
out of time & needs to be checked at a repair shop
here's a link for a manual
http://www.bernina.com/getdoc/4a3fb7af-a8d3-488a-a76a-0147415042a7/Bernette_50_60_70_75_manual
Sep 07, 2012 | Sewing Machines
Manual Pfaff 1212
is there thread involved in the bobbin being stuck?
Apr 05, 2012 | PfaFF Sewing Machines
Hello! My reliable 1222 has hit a snag. When try to sew, the top thread is not being picked up by the bobbin thread. How can I fix it? Pavla
try changing the needle
clean under the needle plate & in bobbin area for loose threads & lint
try rethreading the machine top & bobbin, make sure to get every thread guide
make sure the bobbin is inserted correctly in the bobbin case
Mar 11, 2012 | PfaFF Sewing Machines
Needle will not pick up thread from bobbin
Was the old needle picking up the bobbin thread ok? If it was, then there's nothing wrong with the machine. Check that the needle is inserted correctly--there's a flat side on the shank of the needle and where that goes varies widely by machine. Then check that it's threaded properly.
(I once had my needle in backwards and threaded wrong--took the machine to the shop cause I was sure my baby was broken. Cost me $85.00 to find out that on that particular machine the flat side of the needle faces left!)
Let me know if this helps!
Robbie
Jan 24, 2010 | PfaFF Sewing Machines
Janome Memory Craft 9000 Computerized Sewing Machine Logo
288 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
