Question about D-Link DI-704P Router
Dlink router i believe it just needs to be reset. what is the proper procedure? thanks
  • D-Link Master
  • 6,487 Answers
To reset this just press and hold the reset button for about 15 seconds then after that unplug the power and plug it back in...
Hope that helps.....
Posted on Aug 20, 2008
DLink password
To perform a reset, please follow steps below:
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset.
Step 2 Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults.
Note: The factory defaults username is admin, and there is no password.
Mar 28, 2012 | Computers & Internet
I lost my Dlink wireless router Setup CD where can i download the setup software ? Dlink wireless router N150 model: DIR - 601 thanks
Hello frederika_ra,
Go here: http://www.dlink.com/dir-601
Click "Support Resources" and everything you need should be there. I do not believe they allow a download of the software but you can use the manual to setup the router.
Hope this helps!
Jul 05, 2011 | Computers & Internet
A few months ago someone was getting into my router & downloading movies, I assume. Had a tech help me put in a password to secure it. Forgot the password & now can't use my ipod touch at home. Any...
Yes there is.. BUT you'll have to set up the security again... Fortunately DLink has a handy setup wizard which you can access here.. http://support.dlink.com/emulators/di514_revc/h_wizard.html
This will work right on your browser. You might want to test that it works on your system before wiping the router. (Just start it up then cancel if it starts)
Find the recessed reset button on back of the router close to the power input. Press and hold it with paper clip or pen tip for 10 - 15 seconds. This will restore it to factory settings.
You should use a wired connection to access the internet after that, no password. Go to the link above and use the online wizard to setup the router with encrytion and new password.
If it all orks wout for you kindly give me a rating. Thanks.
Jan 29, 2011 | D-Link DI 514 Wireless Router (DI-514)
My router is not working. I have a dlink DIR-615 model. How can i reset it?
Inorder to reset the Dlink router , please follow this steps
Thanks & Regards,
Prema.
Jan 06, 2011 | D-Link Computers & Internet
Dir-300 dlink router asking to reset to factory after installatio
there's an easy way to reset your router back to its factory setting... inspect the physical appearance of your router... there should be s small hole.... inside that small hole is a reset button
How to reset? ..... while the router is on...Using a small pointing object, much better if you use a paper clip..... insert the paper clip to the hole... press and hold the reset button for 10 seconds...
That's it your router will restart itself and the settings is back to its factory settings...
Hope that help you..
Much appreciated if you rate this help... thanks
May 22, 2010 | D-Link DIR-300 Wireless Router
Cant reset dlink, laptop wont pick up signal
In you dlink have a reset button, press that button up to 20 sec and then release that, your router will be reseted.
Mar 31, 2010 | Computers & Internet
Lost my WEP log in code. Have no idea what it is. What can I do? Thanks!!!!!!!!!!!
You need to reset your router.
I believe that you can do this by pressing and holding the reset button (You may need a paperclip to do this) for 30 seconds. the power LED will start to blink, and then it will reboot with the defaults. You should be able to connect to it with 192.168.1.1. The default password is likely "password".
Aug 03, 2009 | D-Link AirPlus DI-524 Wireless Router
Router not working
TRY LOCATING VERY TINY HOLE ON THE REAR OF THE DLINK ROUTER. USE BALL POINT PEN AND PRESS GENTLY THE BUTTON INSIDE FOR ABOUT 20 SECONDS AND THEN TRY AGAIN.
May 27, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
I was trying to install my new Di 524 and forget the keys
From the DLink website:
Reset to default settings print.gif The following reset procedure will completely restore the default settings on the router including your password.
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the router powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The device is now at factory defaults.
The default username is admin and leave the password blank.
http://support.dlink.com/supportfaq/
Mar 24, 2009 | D-Link AirPlus DI-524 Wireless Router
I can not aces in my ruter i frogoth my user name end pasword please help me
My name is Armymason, I have the solution to your problem. You need to reset the Router http://office.manualsonline.com/manuals/mfg/dlink_systems/di514_1.html here is the manual in it should explain how to do a hard reset. I believe for that model you need to have it unplugged and use a pin to hold in the reset button, while holding the reset plug in the router and wait 5 seconds before releasing the reset button. Now it should be set back to factory and all you have to do is enter in the default user name and password. Of course doing this you will have to reset all your settings.
If this solution isnt satisfactory, I suggest using our Premium service.
Thanks,
Armymason
Feb 24, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
D-Link DI-704P Router Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
