Question about Linksys BEFW11S4 802.11b Wireless Router/Switch + WMP11 PCI Card (BEFW11S4 + WMP11)
I have fa linksys router model BEFW11S4. I NEED THE PIN NUMBER, WHERE CAN I FIND IT? I DON'T HAVE THE MANUAL OR CD OR BOX. PLEASE HELP
Should be on the White sticker on the bottom. If you need to login to the router to change settings You need to access the router setup page by typing 192.168.1.1 on the address bar of a computer that is working with the router , then it will be asking you for a username and password , just leave the username blank and password is admin.
If you need to connect wirelessly to the router but there is a password you don't now you need to hard reset it: unplug it and hold the button on the back that says reset for 30 secs and plug it back in then connect. you must use a cord connection first to login to turn on wireless.
Posted on Jun 14, 2011
SOURCE:
Linksys wireless b broadband router driver
if you want to download the cd driver for linksys router then you need to go to linksys official site .
Jan 05, 2012 | Linksys BEFW11S4 802.11b Wireless...
I am not sure where I can find the four to eight digit pin for my linksys model router, as I have tried everything listed under the router itself.
For that press RESET button of your router for 10 seconds then it will automatic restart and reset. then connect router to computer lan port with lan cable. then you can access it with default ip addresshttp;//192.168.1.1 or http://192.168.1.2 Type user as 'admin" and password as "admin" or "1234" or "password" or blank then you can see configuration page of router. Then click on wireless->security then note down the password.It's your password to connect wireless.
Let me know if you need further assistance. thanks for using fixYa.
Sep 18, 2011 | Linksys BEFW11S4 802.11b Wireless...
I've forgotten my security password for the wireless and want to allow another computer access. as i'm not very technical is it difficult to reset andstart again?i don't want to be without the...
If you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings.
To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
Once your router is hard reset, you will need to login and configure it again.
To reconfigure your LinkSys, connect a PC to one of it'sEthernet ports, load a web browser, and go to the URLhttp://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
LinkSys Default Password
On older LinkSys routers, the default username is blank and the default password is "admin." While newer models, both the default username and the default password are set to "admin."
Once you go past the login screen, you should be able to reconfigure the LinkSys router.
Here are some of LinkSys Router models along with its Default usernames:
Linksys EtherFast Cable/DSL Ethernet routers: Administrator
Linksys WRT54G, BEFW11S4: admin
Linksys Comcast routers: comcast
All other Linksys routers: {none}
Here are some of LinkSys Router models along with its Default passwords:
Linksys Comcast routers: 1234
Linksys BEFW11S4: {none}
All other Linksys routers: admin
For those [none] username/password entries listed above, no name or password is required. Just skip or press the Enter/Return key when prompted for those settings.
Jul 18, 2011 | Zyxel (91-004-361002) Wireless Router
Need manuel for linksys model befw11s4 router
YOu can go to this link for manual guide:
http://www.scribd.com/doc/202195/Linksys-BEFW11S4-WirelessB-CableDSL-Router-Manual
or
http://www.retrevo.com/support/Linksys-BEFW11S4-Wireless-Routers-manual/id/420ag807/t/2/
>you can download the manual free
May 22, 2011 | Computers & Internet
I have a linksys befw11s4 router, and a verizon 6100G modem. I'm so confused I did what i had to do to get the router and modem activated and logged on to my router "192.168.1.1" then...
You will need to get the right User ID and Password before proceeding.
Also make your Verizon 6100G LAN port is connected to your BEFW11S4 WAN port.
May 09, 2011 | Linksys BEFW11S4 802.11b Wireless...
Again
Did you get my other reply?... about disabling you wireless care and har wiring your computer to YOUR linksys? I posted it this afternoon.
Mar 11, 2008 | Linksys BEFW11S4 802.11b Wireless...
Linksys BEFW11S4-RM 4 port wireless router
This is an old router. Look at the power light. You must have a STEADY power light. RESET the BEFW11s4 by pushing the reset button for 30seconds. Unplug the power of the BEFW11s4 for 30 seconds. Connect pc to port 2 or 3. pc should get an ip of 192.168.1.x. If you are getting this ip that means that the pc is already detecting the router.
Good Day
Mar 06, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Internet connection problems using the BEFW11S4
If you are having problems connecting to the Internet, follow the following steps: 1. Internet service: Check with your Internet Service Provider to make sure that service is active. You usually can determine a good link to the service if you can bypass the BEFW11S4, plug directly into the ISP modem unit, and get a good connection. This will narrow the issue down to either the service, or the router. 2. Network cables: Verify that the network cables that connect the network together are plugged into the current ports as they should (modem into the WAN/Internet port, computers into 1, 2, 3, or 4). Also try to change some or all of the network cables that attach to devices coming from the BEFW11S4. You may have bad cables. 3. Router configuration: Your router may not be configured to use your Internet service properly. While plugged into your provider?s modem and able to get online, run the bundled Router Setup Wizard CD-ROM program that came with your router. This will configure the router automatically for you. Note: this program must be executed on the main computer when plugged directly into the providers modem unit and able to get on the Internet 4. Manual configuration: If the Setup Wizard CD-ROM from Step 2 fails to configure your router, you may need a manual configuration. While plugged into the provider modem unit and able to get online, visit http://kb.linksys.com, and search for the name of your Internet service provider for detailed instructions on manual configurations. 5. Router firmware: Upgrade your router to the latest firmware version. Please go to http://www.linksys.com/download to download the latest version of firmware for your product. After the upgrade, be sure to reset the router, by holding in the router?s reset button for 30 seconds and reconfiguring it for use with your service (Step 3 or Step 4). 6. Malfunctioning equipment: You may have a faulty network adapter, or a bad router. Please contact Linksys Technical Support for further assistance.
Feb 16, 2006 | Linksys BEFW11S4 802.11b Wireless...
Configuring the BEFW11S4 for the first time
To configure your router to share your Internet service, please follow the steps below: 1. Check with your Internet Service Provider to make sure that service is active. You usually can determine a good link to the service if you can bypass the BEFW11S4, plug directly into the ISP modem unit, and get a good connection. 2. While plugged into your provider?s modem and able to get online, run the bundled Router Setup Wizard CD-ROM program that came with your router. This will configure the router automatically for you. 3. If the Setup Wizard CD-ROM from Step 2 fails to configure your router, you may need a manual configuration. While plugged into the provider modem unit and able to get online (Step 1), visit http://kb.linksys.com, and search for the name of your Internet service provider for detailed instructions on manual configurations. 4. Once one computer is able to access the Internet through the router, the router will then be configured. Other machines can now connect to the router without re-configuring it a second time. 5. If you are still having difficulties setting up your router, please contact Linksys Technical Support so that we may further assist you.
Linksys BEFW11S4 802.11b Wireless Router/Switch + WMP11 PCI Card (BEFW11S4 + WMP11) Logo
353 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
