Question about Necchi Sewing Machines
I have a Necchi Alco A709-3C 06906 Made in Japan Engineered by Allyn International. I have the manual and I was able to run the thread through the proper direction ( I Think) and started sewing. I was unable to keep a consistent stitch. The Thread would break or the stitches skipped or it would not want to start threading/ stitching at the beginning of the item. Can anyone please help me. I am disabled and in a whealchair. I am looking for new hobbies and would really like to learn how to sew. Could someone let me know what to do Is there a way to learn online? Could you direct me to some good websites? Learning to sew!!
SOURCE:
louislevel_2
  • 374 Answers
SOURCE: need sewing machince help????
hi;
breaking thread and thread below not hook up by upper thrread, this is due on not properly set up of thread tension,first check bobbins windin35caecd.jpgg see figure.the threads should
be counter clockwise.
the theading on upper set up should prorerly inserted follow figures.7dabcae.jpg
the dial set up tension should start at #3 to # 5
the stitch tension should be set to # 8 to # 12
use trial run for fabrics,diffferent set up in every fabric tru to study before sewing in other fabrics.have a nice day don't forget to rate me.thank s a lot
Posted on May 17, 2009
  • 4 Answers
SOURCE: My lowerlooper thread keeps breaking. I can only
The lowerloop thread kept getting cut by the upperlooper.....I rethreaded the machine in order and then made sure that the lowerlooper thread was UNDER the part of the machine that makes the looks the loopings (silver part that comes to a point on the right side of the needles...sorry I don't know what to call it) and the upperloop was ON TOP of the same part.....it started working great. I actually have very nice tight stitches now.
Posted on Jun 20, 2009
  • 47 Answers
SOURCE: need a manual for necchi-alco model 301
Visit us at www.ifixmachine.com
Posted on Jul 24, 2009
  • 46 Answers
SOURCE: My Evolve serger is skipping stitches while using
First, change the needles making sure to use the el705 needle system. Second, make sure the subsidiary looper is engaged properly (plugging up the upper looper hole). Also make sure the needles are all the way up in the machine. This should do it or it may need to be adjusted but the Evolve is a very, very reliable machine. Hope this helps...
Posted on Nov 27, 2009
Testimonial: "Thanks I am going to try this as soon as I can, but right now occupied with a job with my industrial machine. My only issue may be with the needle."
WonderTech
  • 268 Answers
SOURCE: skipping stitches and upper thread breaking on JCPenney 6600
Here are a few things to try.
* Raise your feed dogs if your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you're sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for woven (or a universal needle for either). And make sure your needle is appropriate for the type of thread you're using.
* Adjust the pressure of your pressure foot, it may be too light for your fabric.
* If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
* Change your needle plate. Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important Note: If you change your needle plate, check to make sure your needle aligns perfectly with this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
I hope this helps.
Posted on Mar 23, 2010
My alco 500 won't sew i don't have a manual so need to know how to thread it
Perhaps this will help. Most machines from the same era thread and operate similarly.
Necchi alco manual
Dec 27, 2016 | Sewing Machines
Need all Manuals for Necchi 3537 Mechanical Sewing Machine
here's the link; http://www.allynint.com/ or contact on; Allyn International Sewing Machine Importer 1075 Santa Fe Drive, Denver, CO 80204 Phone: 1-800-525-9987 Fax: 303-825-5078 E-Mail: necchi@allynint.com Hope this helps :) If you are not in the USA then please ask again and specify where.
Aug 10, 2007 | Necchi 3537 Mechanical Sewing Machine
Can download a manual for free 3537 model??
there are no free manual for a necchi sewing machine that I know of
but incase you want to buy one here is a link for one that's only a little over $10.00 + shipping.
Necchi 3537 Instruction Manual
or you can try the allyn international co, that used to sell them, here is a email address
Allyn International ----phone--303-825-5200
Jul 17, 2014 | Necchi 3537 Mechanical Sewing Machine
Manual for Necchi Alco A-609-1
try these sites some you may have to email about the manual
sewingpartsonline.com
sew4less.com
sewusa.com
sewvacdoctor.com
sewingmanuals.com
a1sewingmachines.com
ebay
May 16, 2012 | Necchi Sewing Machines
Is a Necchi model 575FA any good? I would also love any info on this company! Thanks!
Necchi is imported by Allyn International, I think they're in Denver area.
Their phone number is: 1-800-525-9987
Oct 05, 2009 | Necchi Sewing Machines
Manual fornecchi-alco sewing machine model 301
I have an ALCO 2200. Luckily I have the manual. If some one need the manual, I can photocopy and send it to you, if you do not mind paying the postage. :)
Dec 18, 2008 | Necchi 3101 Mechanical Sewing Machine
Need a manual for necchi-alco model 301
Dec 17, 2008 | Sewing Machines
Sewing Machines Logo
363 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
