Question about RCA P52937 52" Rear Projection Television
Won't power up
Will not turn on when you push the power button or use the remote. When you go to plug it in it sparks a little bit. Please I need your help. Thanks you
  • William Tice Sep 22, 2008
    Won't power up , slow ticking noise inside,sparks when plugging in indicating a load from something but no response to power button.
There is a fuse inside, change the fuse.
Posted on Sep 26, 2008
Simply won't turn on. All the power at the plug has current but nothing when you push the on button.
Gary, Could be power supply failure. Links below for trouble shooting your problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Fix Laptop That Won Turn On
Laptop not powering up won turn on Fix Solutions
My laptop won turn on when push the power button
Here What to Do When Your Computer Doesn Turn On
Feb 26, 2016 | Computers & Internet
Murray select hp
Mathieu. It sound like you have overfilled it with oil. Drain most of it out the leave it level. A lawnmower will run better with it not being overfilled. Clean the spark plug and heat it gently to completely remove traces of oil. John
Jul 02, 2013 | Garden
Tv won't turn on
Have you checked whether the power outlet is ok? Have you tried connecting the TV to another power outlet? If so, there is a defect inside and should be handled only by a qualified service technician.
Aug 13, 2012 | Sony KDL-52W5100 TV
Mitsubishi tv won't turn on
did you try new batteries in the remote? if the tv has buttons on the side and one of them being power di you try to push that? did you push tv power or cable power holding the buttons longer? those things might work.
Jun 05, 2012 | Mitsubishi WS-55909 55" Rear Projection...
Lost my remote viper remote starter. Car alarm goes off when open and car won't start. What do i do to disarm the alarm since the car won't start?
Common issue.
Open doorAlarm will be going offLocate the antenna (should be on the windshield)Find the little black push button on the antenna.Turn key to the ON/IGN position (where all lights are on)WITHIN 5 SECONDS push the black button 1 time and release (unless your installer changed the number of pushes it should be 1)Within seconds the alarm will ceaseStart your vehicle.
If any other issues, send me a message.
Aug 25, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Had a question bout my mazda rx8 I was driving it one night it was running fine the next day went out and it won't turn over it takes awhile bit it finally starts and idles real rough and you give it...
Too many possibilities
Won't turn over is one problem -battery,cables,grounds,
starter,solenoid,etc
Idles rough-- vacuum leaks,spark plugs never replaced,
egr valve etc
Worn O2 Sensors
Dirty MAF Sensor
Old Fuel Filter
You have to go into a lot of technical detail & history
on your vehicle, for us to even guess.
May 23, 2011 | 2005 Mazda RX-8
Hi. my philips 150 s4 is too bright and high on contrast. and i can't change it back. when i select the brightness menu says -1 and nothing happends when i push the the buttons. please tell me if i...
it may have menu lock, unplug from wall and leave off for 3 to 4 hours, plug back in after this time and press menu button on remote and power power first and straight afterwards press the menu button.
Jul 16, 2017 | Philips 150S4FB 15" LCD Monitor
Hi my name is robbie. the power will not come on. bofore the power wouldnt come it. it would take a little bit to come on. could u please tell me what i can do to fix it
The first thing to do is to try turning the tv on using the off and on button on television, not remote. If that works ok. Then try remote. If remote, check batteries also. If none of this works, test to be sure there is power coming to the television outlet. Etc. plug in a lamp, etc into same outlet, this will verify the main line power. Hope this helps.
Jan 22, 2011 | iLO LCT32HA36 Television
Tv wont turn on
Hi
Please go to ebay and buy your power supply board:
AKAI LCT3785TA POWER SUPPLY BOARD MLT386X
Oct 02, 2008 | Akai LCT3785TA 37 in. LCD HDTV
Wii controllers
Sounds like the remotes aren't sync'd up with the Wii in a way to turn it on. I had a strange occurrence with ours where only 1 Wiimote (ha!) out of 4 would turn on the Wii with the power button. Try following the instructions to program the Wii to the Wiimotes again and see if that works. Also try holding the power button on the remotes a little bit longer.
I don't recall but you push the red button behind a hidden cover on the front of the Wii and then the button on the Wii controller behind the battery cover.
Dec 31, 2007 | Nintendo Wii Console
RCA P52937 52" Rear Projection Television Logo
27 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
