Question about Panasonic DVD-LS50 Portable DVD Player
CODE: HO2 Good day, My unit says reading whenever i insert a CD and then the unit will prompt CODE: HO2. What shall I do since the unit is useless right now. Thank you
    Problem Solver:
  • 11 Answers
I think the problem is an accumulation of dust. try cleaning it out with a can of compressed air, or if you dont have that, by blowing on the lens gently.
Posted on Aug 20, 2008
SOURCE:
Nokia c2-02 restriction code ( qaisar mehmood )
I have a problem on my nokia C2-02, whenever i insert sim on phone, phone ask for restriction code, but i do not know what is the restriction code number of this mobile, so shall you please send me the code, my email, [email protected], with thanks Zubair Achakzai.
Feb 29, 2012 | Cell Phones
After i insert DVD it reads then say HO2 then STOP= how do i fix this
You will need to get a can of the compressed air or use an air compressor if you have one. Then remove the housing cover if you can and use the compressed air to blow out any dust and debris inside the unit. Also blow air into the inside of the dvd tray. This has been the common fix for the HO2 error on your DVD player. You could also use a DVD lens cleaning kit.
Nov 02, 2009 | Panasonic DVD-RV31 DVD Player
Error with Dual Head Unit
your lazor might be dirty or bad. try a disk cleaner.
Aug 19, 2009 | Car Audio & Video
Can my cd /dvd player write too?
You can also verify the users manual. Mostly you can see some code in the CD-ROM like: DVD-RW= Can write CD and DVD DVD-R= Can only read DVD's CD-R= Can only read cd's. CD-RW- Can write CD's only.
Jun 10, 2009 | Computers & Internet
Can't read CD but can read DVD
This is not uncommon. I have seen it often. It is a sign that the unit is about to fail, and needs to be replaced.
I don't know where you are, but around where I live, these dual layer DVD RW drives retail for less than 30 dollars. They usually come with software and are not difficult to install.
Beware of ESD, however, whenever you are working on the inside of a pc. ESD (electo static discharge) can destroy the insides of your machine without you knowing it until it's too late.
good luck
tony
May 20, 2009 | Sony (DWQ30AB2) DVD RW Dual Layer Burner
Panasonic sa ht640 5 disc dvd
Ho2?I guess the unit is so thirsty,it forgot the right questions H20!!??Just kidding!
Always back to basic,put a CD music disc in first and see the it works?If not,don't bother to check your DVD,should return it or find an A/V repair guy to fix it!
Here is the number-408-806-8766(David Bustillos)
Audio/Video troubleshooting expert(650-346-7607)
Joe
Feb 02, 2008 | Panasonic REGION FREE SCHT700 5 Disc DVD...
CD /DVD burner not identifying the disc
Hi
Type of media settings might be the issue but making a change for standard CD/DVD recording (it affects reading too) Issue can be resolved. Right click on the CD/DVD drive (Usually D or E drive ) click on properties and select and choose the recording option. Click the enable CD recording for this drive option
Click on apply and OK. Try again. You may try after reboot the computer. If issue persist please post so we can think about some alternate solutions.
Good Luck
Jan 24, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Invalid disc prompt,whenever i install a disc
This is a dedicated audio recorder. Therefore, you must use dedicated audio discs (not data discs). You can tell the difference as audio discs specify the recording time (usually 80mins) instead of data capacity (usually 700MB).
When you have the right disc inserted, press the record button & it will go into record standby, ready to record. First, set a level, then press record again, and you are recording.
Jan 09, 2008 | KLH CDR2000 2-Disc CD Recorder
CD playback skips back and forth
Did it just stop working one day, or did you move it, use it differently, etc?
Sounds like your reader/tray might be bad, but could also be a faulty circuit which may have shorted out. If your handy with a multimeter, you might be able to trouble shoot it. Make sure there is nothing lodge in there, and when you opened it up, did you see any broken pieces from the tray? Sometimes the teeth on the gears crack and break off, so check that also. You can't miss the gears, this is what allows the CD to move in/out of the unit.
- TWEAK A/V LAB
Nov 22, 2007 | Pioneer CDJ-100 Turntable
Panasonic DVD-LS50 Portable DVD Player Logo
296 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
