Question about Samsung RB2155SH Bottom Freezer Refrigerator
Samsung RB195BSSB Fridge is plenty cold, but freezer is at 43 degrees and won't get colder...
I went on the Samsung website and got some troubleshooting tips like unplugging the unit for 1 minute and cleaning out the coils with a vacuum, but I have had no luck in fixing it. Does this sound like a compressor problem? And if not, is it a problem with a sealed component? The samsung warranty is 5 years on sealed components and I don't have the cash to pay for a service call if it is not a sealed system.
I can have a service tech come to my house on Samsungs dime, but I really can't afford any surprises.
Thanks for any info you might be able to give
  • Smitty1121 Aug 20, 2008
    From the Samsung website "sealed components"
    Compressor, evaporator,
    condenser, drier, connecting tubing
    These items are all covered for 5 years.
SOURCE: Samsung side by side fridge/freezer
I bought one of these Samsung fridges a couple of years ago and just as the warranty run out, It started making a noise then the fridge compartment stopped cooling, so I did a web search and found out this is a common fault.I searched the web and found a step by step guide on how to fix on EBAY, under Samsung fridge Fault and it cost me £10.00 Only took me half an hour to fix it and it has worked fine ever since.A1+++ FIX
Posted on Oct 24, 2007
SOURCE: i have a samsung rs2555sl
See http://www.fixya.com/support/t1191678-samsung_rs2555sl_not_cooling_compressor
Posted on Dec 16, 2008
tborn6
  • 700 Answers
SOURCE: samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
Posted on Dec 22, 2008
  • 115 Answers
SOURCE: door ajar alarm ringing and refridgerator not cooling enough
it sounds like either a defrost problem or damper door problem it is very well worth fixxing
Posted on Dec 28, 2008
SOURCE: Samsung RS2556SH
I have a samsung Refrigerator model No. RS2556sh. The Fridge temperature indicator is blinking at 38 degrees. What is the cause for it? How can stop it? Please anwser me through my email: alicezhang90@yahoo.comThanks.
Posted on Jun 10, 2009
Fridge warm, Freezer OK
You will find very good info HERE.
Good Luck.
Mar 03, 2008 | Samsung RS2578BB Side by Side Refrigerator
GE monogram refrigerator too cold
There is a balance between the freezer and fridge. Reduce the freezer temp and see what the fridge temp does. By reduce I
mean make the freezer warmer. If it is set too cold the fridge gets colder.
Nov 25, 2013 | GE Monogram ZISS480DRSS Stainless Steel
Amana fridge is not cold but freezer is working
If freezer is ok and cooling ( 5 degrees or less) one thing you might want to check is that the flow of cold air to refrigerator is not obstructed by the items in your freezer. The ductwork has to be available. Also check the opening of the damper if fridge is not cold enough. And is the fan operating at full speed - are the bearings dirty and slowing it down?
Also check your freezer temp - there are degrees of freezing. Water freezes at 32 degrees but a good freezer should go down to about zero. And the colder your freezer air is the colder your fridge will be.
Sep 21, 2017 | Refrigerators
My Samsung RB195BSSB bottom freezer model has recently developed an issue. The freezer will warm up to 21 degrees and not hold the previous temperature. Fridge is fine. Ice maker may not be making ice...
This sounds like there is a build up of ice on the evaporator. this will block the air flow and allow temperatures to rise.
The problem could be with;
\ the defrost timer
\ defrost heater
A technician can solve this for you
Mar 24, 2011 | Samsung RB1955 Bottom Freezer Refrigerator
Freezer is too cold (-14 degrees) and fridge is too warm (51 degrees). The freezer keeps gettting colder but the fridge part keeps getting warmer.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
The temp sensor for the freezer may be reading the warm air in the fridge so is not cutting the compressor off.
Sep 25, 2009 | GE Profile PDS20MFS Bottom Freezer...
Freezer works great, but fridg. will not get below 50
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 17, 2009 | Maytag MZD2766GES Side by Side...
Freezer is ice cold, fridge won't cool lower than 42*
Sounds like it's not defrosting, so unplug open freezer back panel and use a hair dryer to melt ice from evaporator coil. Your refrigerator has a defrost timer on bottom near floor, but if freezer is frozen we need to defrost it so we can make sure there is not some other problem. Let me know when you are ready, Sea Breeze
Apr 22, 2009 | Refrigerators
Samsung RB2155SH Bottom Freezer Refrigerator Logo
302 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
