I have 57 process running in my task manager. Can you please email me with the ones I need to keep running? When I tab on the item a message appears that says I may cause a problem if I stop this process and may/will effect the proformance of the computer. Email address is [email protected] Thanks for your help
Please give more details as to what is happening and when it happens?
If you are saying your computer boots up but there are No Icons on the desktop, then a virus or infection has hidden them or changed some settings.
Click the Ctrl/Alt/Del keys to start the Task Manager. Press and Hold the Ctrl and Alt keys then hit the Del key. When the task manager opens up click the Processes tab. Under the processes tab click the columnar heading Image Name to sort the items running in alphabetical order. Look to see if you see explorer.exe running under the image name. If you do click it one time to highlight it then click the END PROCESS button at the bottom right of the Task Manager Window.
Next click FILE at the very top left corner of the Task Manager Window and select New Task (Run..). When the Create New Task window pops up type in: explorer.exe and press OK. Your desktop icons and start menu should start populating.
Are you saying there are no icons on yourdesktop and the start menu is missing? If so try this: Click Ctrl+Alt+Del to get the task manager to come up. Press andHold each key (Ctrl+Alt) until you hit the Del key, then you can release them.
When the task manager opens up click the Processes tab. You can click theImage Name column to get them in alphabetical order. Look forexplore.exe, if you see it listed click it once to highlight it then click theEnd Process button at the bottom right portion of the task manager window.
Next click File at the very top portion of the task manager window on the leftand select the option New Task (Run). When the Create New Task window openstype: explorer.exe and press OK. Your items will start populating andappearing on the desktop.
Buttons where? Are you saying there are no icons on your desktop and the start menu is missing? If so try this: Click Ctrl+Alt+Del to get the task manager to come up. Press and Hold each key (Ctrl+Alt) until you hit the Del key, then you can release them.
When the task manager opens up click the Processes tab. You can click the Image Name column to get them in alphabetical order. Look for explore.exe, if you see it listed click it once to highlight it then click the End Process button at the bottom right portion of the task manager window.
Next click File at the very top portion of the task manager window on the left and select the option New Task (Run). When the Create New Task window opens type: explorer.exe and press OK. Your items will start populating and appearing on the desktop.
You need to run a virus scan because something might have caused this to happen.
1. Reboot your computer. 2. Press Ctrl+Alt+Del on your keyboard. This will bring up the Windows Security window. Click the "Task Manager" button and then click the "Task Manager" tab. 3. You will see a list of files/applications. These are the applications running in the background on your system, whether they show on your taskbar or not. Any one of these applications could be causing a conflict with the Yahoo! Messenger installation. 4. Click the top item on the list to highlight it. Then hold the "Shift" key down and click the last item on the list. This should highlight the whole list. 5. Click the "End Task" button. This will temporarily close all background applications on your system. 6. Click the "X" in the upper right corner to close the Task Manager window. 7. Install Yahoo! Messenger. You should not experience the same issue that you had before. 8. After Yahoo! Messenger is installed,run registry cleaner reginout also reboot your system. All other background applications will return to their original configurations.
Restart the computer and try to reinstall it, if dont work go to the task manager to find out if iexplorer.exe are running, if yes end the process and try again.
please vote for my solution
If your Email is trying to send as soon as you start Outlook Express, you might try this:
Open Outlook Express and go to the top menu, click TOOLS then under that menu, OPTIONS. Under the GENERAL tab, uncheck the box for "Send and receive messages at startup", then click OK.
Close Outlook Express and start it up again. Hopefully this will allow you to delete the Email. Good luck!
Hi. Just press Ctrl-Alt-Del, select Task Manager Button to open the Windows Task Manager. Go to the Processes tab, look for these image names and terminate (end process) them:
adobeupdater.exe or Adobe_Updater.exe
Close the Windows Task Manager and you're done.
Hope this helps.
