Question about Video Game Consoles & Games
I cant find my wii pointer i tried eveything it migth be my ve my remote or sensor bars falut with is it likely can u give me tips to fix the problem also all the wii remote buttons are working perfectly so what is it. thaks in advance.
MAYBE YOU NEED TO MOVE YOURYOUR SENSOR BAR SOMEWHERE ELSE. PUT IT EVERYWHERE UNTIL YOU HAVE FOUND YOUR POINTER.
Posted on Dec 28, 2008
First player remote not working, so cant play the wii
batteries? paired the handset? sensor bar connected? have you gone through the manual and tried the initial set up again? post more info if you need more pointers/help
Apr 29, 2010 | Nintendo Wii Console
I bought my son a Wii this past Christmas so it's not that old. The Wii remote finger pointer isn't working; however, I can power the remote on and off, use the "A" button, the home button, and use the "+"...
First you need to determine if the problem is your Wiimote, or your Wii's sensor bar.
You can check to see if your Wiimote is transmitting to the bar by looking at it through a digital camera (this allows you to see the infrared light). Turn everything on and view the tip of the remote through the camera, if it lights up: it's working, if it doesn't: you may need a new wiimote.
If it turns out your wiimote is working, then it probably means your sensor bar needs replacement. I think that is more likely (and less expensive)
Mar 29, 2010 | Nintendo Wii Console
Cant get the pointer (hand) to appear on the screen
Make sure your sensor bar is positioned correctly, within line of sight of the wii remote.
Feb 19, 2010 | Nintendo Animal Crossing: Let's Go To The...
Wii remote not pointing
I had that same issue what
I found out is that the wii remote's are fine
the problem is probally your sensor bar
if you can't fix you can buy a new one from nintendo for $10.00 (1-800-255-3700)
hope this helped
Jun 21, 2009 | Nintendo Wii Console
After I turned on the power, The pointer was missing, so I can not select the program or function
There is a simple thing to find out if you need to by a new sensor bar. Becareful when doing this. Take 2 candles and set them apart, about the distance ofthe sensor bar. Your Wii remotes operate off of UV/infared. This is an alternate way to play the game with out having a sensor bar installed. Really cool the first time I did it. Any way if this brings you pointer back then you need to get a new sensor bar. They are only about 5-10 dollars at nintendo.com. If this does not fix the problem then that means that you need a new remote. You can also get that at nintendo.com you could also get them cheaper at game stop or something of that nature.
May 11, 2009 | Nintendo Wii Console
Sensor bar and remotes not working together?
There might be so many reasons, You may visit Wii Fix Guide to know exactly the reason for this problem also this DIY guide will help you fixing the problem without any technical knowldege. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Dec 27, 2008 | Nintendo Wii Console
Problem with wiimote
the problem could be uv light, if its daytime make sure all the blinds are closed no extra lights are on near the sensor bar. if there is a glare on the screen at all it could be reflecting light to the wiimote as well. I've had that problem before myself, if that is not the case try moving closer to the sensor bar, make sure the sensor bar is connected correctly and then go to the system settings menu and calibrate the wii sensor bar and adjust the sensitivity, make sure you are not sitting at a wide angle from the snesor bar either, you can tip the sensor bar left and right in order to allow yourself a wider angle. also avoid using the nyko wireless sensor bar, it has a shorter range than the wired one that somes with the wii, mine came with a wireless on(used) and i just got a wired one and now it works much better. well I hope you find this info at least a little useful.
Feb 15, 2008 | Nintendo Wii Console
Wii sensor bar is acting up
wii snsor is very sensitive has it fell or had any cracks on it. play around woith remote more, maybe it will pick up the pointer, if not available online or in some stores.
Jan 11, 2008 | Nintendo Wii Console
Video Game Consoles & Games Logo
52 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
