Question about Linksys Wireless-N WRT150N Router
Whats my router ip address - Linksys Wireless-N WRT150N Router
  • Linksys Master
  • 6,487 Answers
This routers default ip address is 192.168.1.1 no username and password is admin..
Hope that helps........
Posted on Aug 20, 2008
SOURCE:
What is my ip router?
I don't understand your question? What is your IP address? You can find your IP address using this: http://whatismyipaddress.com/ OR http://kb.iu.edu/data/aapa.html
Dec 29, 2012 | TP-LINK TL-WR740N 150Mbps Wireless Lite N...
My Zonet ZSR4134WE Wireless-N router doesn't connect to live. I've checked the MTU setting and everything. It works perfectly, until it gets to the "Xbox Live" part of the test, then it fails. Please help.
you need to open the ports on your router for xbox ports are TCP 88 UDP 88 UDP 3074 TCP 3074 UDP 53 TCP 53
first connect the xbox to the network and get the ip address (like 192.168.x.x) and then use the computer and login to router setup page and under firewall open these ports for the ip address of xbox . If you find a DMZ there , then enable it for XBOX ip address and reboot the router. ** imp: try to make a static ip address on xbox so when you restart the xbox teh ip address should not change -
to check what is the ip address provided from you router :- go command prompt (start ->run- > type cmd and hit enter) a black screen(command) type ipconfig you will find ip address of computer , so you can set the ip address of xbox like that -but just make the last number different (like ip address on computer 192.168.2.5 then make ip address of xbox to 192.168.2.6) perform this will help .. its all about the ports but be sure with ip address
Oct 01, 2010 | Zonet ZSR4134WE Wireless Router
What is the default ip address for this router to set it up?
To find the IP address, connect your PC to it and at a Command prompt type ipconfig /all. The default gateway will be the IP for the router.
Nov 16, 2009 | Equinox IBG-100/7 Router (990408)
I cant seem to figure out what is the IP address for my MSI RG60SE router.....
By default ip address is 192.168.1.1
or
192.168.0.1
But if your ip is different and if in your router DHCP is enabled then you have to check your computer ip address with which your router is connect.
Go to start menu then type in run "ipconfig /all"
then check gateway ip it is your router ip.
Also you can check your ip wtih phone reciver connect your phone receiver to router with phone line jack.
Then press * so you can listen configuration.
Let me kow if you need more assistanse.
Thanks.
Sep 24, 2009 | Computers & Internet
How to find router fully ip address?
if your PC still working and connecting to the internet thru this router, then open command prmpt, enter "ipconfig" and read the ip address of the default gateway. at most simple home networks, that is your router.
Jun 06, 2009 | EnGenius EOC-3220+ (EOC3220PLUS)
I can not connect to the local area connection.
1. check your network adapter TCP/IP settings if its set into "Obtain as IP address Automatically".
2. if the settings is set as Automatic and your not getting IP address then select "Use the following IP Address"
3. use IP address followed to your router address like if192.168.0.1 in router type 192.168.0.2 or192.168.0.3 justcheck the next address IP in your network.
4. after typing subnet IP will automatically set
5. type the router IP address as your default gateway
6. click OK to save your new settings
hope this will help you
Nov 26, 2008 | NetGear WGR614 Wireless Router
Factory settings for a Linksys RV042
connect your router your computer via LAN cable
click start on windows
click run and type CMD
On the DOS command prompt type IPCONFIG/ALL
look for the gateway address, that is the IP Adress of your router
Feb 11, 2008 | Linksys : RV042 4-Port 10/100 VPN Router...
IP address
Hi tammyhope,
I would guess that your ISP is providing a dynamic IP address for connectivity to the internet. If your router is changing the IP address back to default, I would think that your configuration is not setup properly, to receive a dynamic address, but is set with a static address instead. So what happens is that when you attempt to connect to your ISP your router is resetting. If this is the case then you need to go into the router configuration and set it to recieve a dynamic address from your ISP.
--RoadHawk
Nov 25, 2007 | Belkin (F5D7230-4) Router (587009)
What should be the IP address of the computers connected to the router?
What should be the IP address of the computers connected to the router?The IP address has to be 192.168.2.xx and the command to find out the IP address is ipconfig (Start -> Run -> "cmd" [enter] -> "ipconfig" [enter]).
Feb 19, 2006 | SMC Barricade 7004 Router
Linksys Wireless-N WRT150N Router Logo
396 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
