Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Lamp replacemrnt OK, where's the access panel to replace the projection bulb? Do I really have to remove the entire lower rear of the housing?
  • robbmurray Aug 20, 2008
    Very nice, thanks!
  • Mitsubishi Master
  • 8,617 Answers
No the lower panel in the front just pops off and the lamp compartment door is behind the lower panel
Posted on Aug 20, 2008
  • Sonny Berry
    Sonny Berry Aug 20, 2008
    Your welcome, have a good day and Thanks glad I could help you
How hard is it to replace the bulb on an HLR6156WX/XAA
Hello
To replace bulb of your Samsung TV; proceedigns are given here:
[1]. Unplug the television and allow it to cool off for at least 30 minutes. The lamps in televisions get very hot and can cause injury if handled too soon after turning off the televisions
[2.] Remove the four screws from the cover of the access panel on the back of the television and pull off the cover.
[3]. Loosen the lamp by removing the security screw from the handle of the lamp. Though the lamp bulb is visible in the middle of the access panel, the handle is to the left of the panel
[4]. Grip the handle of the lamp and pull the lamp out of the access panel. Dispose of the old lamp in a waste receptacle
]5]. Slide the replacement lamp into the television, making sure the tip of the lamp is facing the right side of the unit
[6]. Replace the security screw for the handle of the lamp and reattach the access panel cover with the four screws. The television will not turn on if the access panel cover is not on the television
OK
Mar 20, 2011 | Samsung HLP5685W 56" Rear Projection...
Replace a brake light
COUPE The side marker lights for the SC and SC2 are part of the turn signal/parking light assembly. Refer to the procedure in this section for lamp removal and bulb replacement. Rear Turn Signal, Brake and Parking Lights EXCEPT WAGON
  1. Disconnect the negative battery cable. Fig. 5: Remove the trim panel fasteners - except wagon 84196109.jpg
    Fig. 6: Carefully remove the trim panel - except wagon 84196110.jpg
    Fig. 7: Pull the lamp assembly straight back and out of the opening 84196111.jpg
  2. Remove the trim panel fasteners, then carefully remove the trim panel.
  3. Remove the 2 retaining screws from the side of the lamp assembly, then pull the lamp assembly straight back and out of the opening.
  4. Tilt the assembly downward for access to the sockets, then twist and remove the socket(s) from the lamp assembly. Replace the bulb(s), as necessary.
  5. Installation is the reverse of removal. Fig. 8: Tilt the assembly downward for access to the sockets 84196112.jpg
    Fig. 9: Twist and remove the socket and bulb from the lamp assembly 84196113.jpg
WAGON
  2. Remove the retaining screws from the side of the lamp assembly, then pull the lamp assembly straight back and out of the opening.
  3. Tilt the assembly for access to the sockets, then twist and remove the socket(s) from the lamp assembly. Replace the bulb(s), as necessary.
  4. Installation is the reverse of removal. Fig. 10: Exploded view of the tail lamp assembly - wagon 84196114.gif
High-Mount Brake Light EXCEPT WAGON
  2. Open the trunk for access to the lamps.
  3. Locate the bulbs at the rear underside of the trunk lid. Remove the bulb(s) by twisting, then pulling straight out.
  4. Installation is the reverse of the removal. Fig. 11: Remove the high-mount brake light by twisting its socket 1?4 turn counterclockwise - except wagon 84196115.jpg
WAGON
  2. Raise the liftgate, then remove the wedge blocks from each side of the liftgate assembly.
  3. Remove the lower fasteners from the liftgate lower trim panel, by pushing in the center of each pin approximately 1?8 in. until it clicks, then remove the fastener.
  4. Insert a screwdriver or small prybar into the hole in the lower trim panel (located near the wiper pivot on the pivot hump) so that the tool sits on top of the pivot. Lift up on the tool handle to disengage the trim panel upper clips, then remove the lower trim panel from the vehicle.
  5. Unplug the high-mount brake light wiring harness.
  6. Remove the brake light fasteners, then remove the lamp assembly from the liftgate.
  7. To remove the bulb(s), push slightly on the top edge of the lens and rotate it away from the housing. Remove the bulb(s) from the housing. To install:
  8. In order to prevent the possibility of water leaks into the liftgate, inspect the lamp gasket for damage and replace, if necessary.
  9. If removed, install the bulb(s) by inserting the bottom edge of the lens into the housing and snapping it into place.
  10. Position the lamp into the liftgate and tighten the fasteners to 35 inch lbs. (4 Nm).
  11. Connect the wiring harness to the lamp assembly.
  12. Align the upper clips on the lower trim panel to the liftgate slots, then install the panel by pushing at the clip locations.
  13. Reset the trim panel push-in fasteners by spreading the center pin tabs and moving the pin so that it sits approximately 1?4 in. out of the fastener. Insert the fasteners into the bottom of the trim panel and push the center pin until flush.
  14. Install the liftgate wedge blocks.
  15. Connect the negative battery cable and check for proper lamp operation. Fig. 12: Removing the liftgate lower trim panel assembly - wagon 84196116.gif
    Fig. 13: Exploded view of the high-mount brake light bulb and lens assembly - wagon 84196117.gif
Nov 04, 2010 | 1998 Saturn SL
I need to replace rear tail light bulbs on 1996 Saturn SL1
WAGON
WAGON
Reverse Light EXCEPT 1991-96 COUPE For the Saturn wagons and sedans, the reverse lamp is part of the rear turn signal, brake and parking light assembly. Refer to the procedure in this section for lamp removal and bulb replacement. 1991-96 COUPE
  2. Reach behind the bumper bar and disconnect the harness and socket from the reverse lamp. Remove the bulb from the socket.
  3. If necessary, unfasten the retaining nuts and remove the lamp from the bumper bar.
  4. Installation is the reverse of the removal. Fig. 14: Exploded view of the reverse lamp mounting - 1991-96 coupe 84196118.gif
Oct 23, 2010 | 1996 Saturn SL
Where is the bulb loacated on kdf42we655
Bulb/ lamp is located under front lower panel that need to be removed. There are two thumb screws on lower corners of front screen if you see tv from rear, remove these screws and take off lower front panel, you will see lamp cover, remove it to see lamp.
Lamp replacement procedure is written in user manual with exploded views. Click Sony Support to download free copy of user manual of KDF-42WE655 for more details.
Jun 21, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Need to change dlp bulb...where is the housing? do i have to take entire back of tv off? obviously, i'm missing something. thanks.
Just pull off the lower front panel it just pops off the one under the screen. Then the lamp door is on the left behind the panel you poped off.
Jan 02, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Replacing bulb
on the lower right hand side just below the model and serial number is the access panel for the bulb housing. remove the screws to the panel and housing. *remember* when replacing the bulb !!!DO NOT!!! touch the new bulb with your bare fingers. get some rubber or latex gloves
Sep 02, 2009 | Zenith E44W46LCD 44" Rear Projection...
I need to know how to replace the lamp unit. How
remove rear panel, you will see a box with door on it. You can open the door and have access to the bulb.
May 15, 2009 | Panasonic PT-61LCX70 61" HDTV
Lamp out ...
remove front panel under screen, rove screws from lamp access panel cover. then remove the screws from the lamp assembly housing pull lamp housing straight out. install new lamp in the housing and slide the cartridge back into set replace screws and access panel cover.
Apr 09, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Replacing bulb
Looking at the screen, the lower part of the TV there is about a 6-7 inch band and following that aroundto the back edge you'll find the retainig screws. Remove the screws and pry the band off the botton portion of the Tv.
About center you'll see the lamp cover. Remove it and take a hex key to remove the tension screw inside and slide out the lamp housing.
You can purchase a new lamp and housing or replace just the lamp at a less expensive cost. We use LampSource, good quality and reasonable price. http://www.dlplampsource.com
Reverse the steps to install and replace lower cover. Don't forget to go into your menu and reset your lamp hours to zero and you're done...
Bill
Nov 25, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Zenith E44W46LCD Lamp Access Door Location
I found the location to get at the lamp. If you are loking at the front of the TV there is a small panel at the bottom of the right end. Two screws, remove panel, two screws inside and a small handle that lifts so you can slide the unit out. 4 screws on top of the cage that the lamp sits in, carefully slide up the silver bracket holding the bulb, be careful the edges are sharp. Remove the bulb from bracket and remove the 2 cables attached to the bulb. Now just do the same but in reverse. Make sure you wear plastic gloves that should be provided because if your fingers touch the lense you could be out the price of the lamp.
Aug 31, 2007 | Zenith E44W46LCD 44" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
