Question about KitchenAid Dishwashers
Brand new dishwasher stops mid-way through wash cycle with soap spilled out all over the door. Can't seem to get past the wash cycle to finish the complete wash/dry cycle.
    Problem Solver:
  • 13 Answers
If there is no water in the bottom of machine, see if your water supply is turned off, or check for a loose wire on the water valve, lastly, check if the float is stuck in the up position. That is the overflow protector. If the machine 'thinks' the water level is too high, it will not allow more water into it. The float is in the front left corner, usually under a raised cover, remove that cover and manually raise and lower the float to allow free movement. It should be normally in the down position. Good luck.
Posted on Aug 20, 2008
SOURCE:
I have a whirlpool gu2400 dishwasher. The spring loaded soap dispenser door does not open during the wash cycle to release the soap.
Whirlpool dishwashers use a wax motor or a solinoid to release the door at a specific time during the cycle. So for proper cleaning the soap cup is nessesary . The part isn't that expensive and fairly simple repair.
Dec 30, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
When the dishwasher cycles end, there is still soap suds in the bottom of the dishwasher
Run a empty cycle with a cup of vegitable oil . check mid cycle to see if you should add an extra cup. if you or anyone in your home is washing dishes with soap and then putting them in the dishwasher this will happen
Feb 16, 2013 | Dishwashers
Please help! I just moved into a new house where the Frigidaire dishwasher worked great for 2 weeks. Now, it's leaving hard salt-like granules all over my dishes and not rinsing all the food off. ...
Your dishwasher has clogged water ports.
Start the dishwasher with NO dishes in it.
Once it starts the wash cycle,open the door and pour in 1 quart of WHITE vinegar and resume the wash cycle.
That should clear out the residue.
Change your dishwasher soap to the FINISH brand name for happy clean dishes.
Apr 28, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
Put clothes in washer HOTPOINT modelWML730 started
TURN MACHINE ON TO FINISH CYCLE THEN RE WASH WITH SOAP ETCH,DOOR WILL NOT OPEN MID CYCLE SAFTY LATCH,YOU CAN TURN PROGRAM TO FINAL SPIN TO EMPTY MACHINE AND FINISH PROGRAM THEN DOOR WILL OPEN
Jan 06, 2010 | Washing Machines
Water won't drain, Soap Door open with soap still there and stops running at Plate Warmer cycle
Reset the washer manually. Close the machine, and slowly advance the timer till you here the fill valve start. Then let it do it's thing
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
Soap dispenser doesn't open for wash cycle
I noticed you didn't rate out chat and saw that your problem was posted. I'm happy to continue to help you if you encountered problems or were not happy with the solution in your chat session.
Jul 07, 2008 | Frigidaire FDS251RJ Free-standing...
Dishwasher leaks out front
If pre-rinsing dishes use only 1 or two teaspoons of soap in the main wash cup..do not put soap in the prewash cup. Excess soap can cause oversudsing and cause water to spill over out the bottom of th door. Use rinse-aid for better drying performance
May 29, 2008 | Dishwashers
Soap not dispensed and dishes not washed
water is getting past the gasket during the start up cycle. by the time the door opens, the water has caked up the soap. also, its not clear when in the cycle the door is opening.
try using liquid soap.
also, take a peek just after the machine has finished filling and starts washing to see if the door is opened on the soap disp.
good luck
mark
Dec 19, 2007 | LG 24 in. LDS 5811 Built-in Dishwasher
GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Apr 21, 2007 | GE 24 in. Monogram ZBD6880KSS Stainless...
Dishwashers Logo
126 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Marvin
Marvin
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
