Question about ASUS P5VD2-VM SE - Motherboard - micro ATX - P4M890 - LGA775 Socket - UDMA133, Serial ATA-300 ...
PSVD2-VM SE CPU Support
Dear Sir
I have recently bought a new cpu
its intel core 2 Duo E8400
3.0 MHz ,6 L2 Cach, front bus speed 1333
when starting my pc, a warning comes as
eror u mode, press F1
then i press F1 and it contiue with no problem
how can i dtop this from happening, and do u think that my mother is in-compatible with the CPU?
please help
cheers
  • Anonymous Sep 03, 2008
    new bios for p5vd2-vm se. current bios is 0507... cannot support E7200 Core2Duo 2.53.
I had the same problem I flashed the bios with the utility provided with the motherboard and it fixed it for me. Hope this helps.
Posted on Nov 09, 2008
  • 781 Answers
This came up because you changed a major component on M/board
I think you need to reset BIOS to default and go from there checking and changing settings in BIOS one at a time until you have the speed you want etc
Posted on Aug 25, 2008
Im also getting the same problem with that. how to slove that problem
Posted on Nov 17, 2008
I want know intel d 945gcr supports quied core processor or core 2 duo processor?
Support for the following:
Intel Core 2 Duo processor in an LGA775 socket with a 800 MHz system bus
Intel Pentium D processor in an LGA775 socket with an 800 or 533 MHz system bus
Intel Pentium 4 processor in an LGA775 socket with an 800 or 533 MHz system bus
Intel Celeron D processor in an LGA775 socket with a 533 MHz system bus
Aug 14, 2014 | Computers & Internet
Intel core tm duo cpu e4500 motherboard
Intel = Processor (CPU ) manufacturer
Intel Core tm = Trademark. The Intel Core is a Trademark from Intel
CPU stands for Central Processing Unit. Another term used is Microprocessor, or simply - Processor for short.
e4500 is an Intel Core2 Duo processor.
Maximum frequency rate ('Speed') is 2.2GigaHertz.
2MegaByte of L2 Cache. (2MB of L2 Cache)
800MegaHertz Front Side Bus. (800MHz FSB)
Tells me Nothing about the actual motherboard. Look on the motherboard for a Model Number. May be in center of motherboard. May be on edge of motherboard. May be in-between one of the expansion slots, on motherboard.
Post back in a Comment.
Also post what the problem is, in your best description.
Computer does not turn on. (Power Supply does not turn on)
Computer seems to turn on, but get No Signal on monitor, or Sleep Mode on monitor, or Power Saver Mode on monitor.
LED lights light up, and fans spin.
Regards,
joecoolvette
Apr 23, 2013 | Computers & Internet
Cpu up grade
Yes sir.
The eMachines T5082 Desktop PC uses an Intel D102GGC2 motherboard,
http://www.newegg.com/Product/Product.aspx?Item=N82E16813121031
The motherboard chipset is an ATI Radeon Express 200,
http://en.wikipedia.org/wiki/Comparison_of_ATI_Chipsets#Comparison_of_Northbridges_2
Scroll down the chart under the - Model - heading.
ATI Radeon Xpress 200 for Intel.
Processors Supported;
Intel Pentium 4, Intel Core2
If the motherboard chipset will support an Intel Core 2 Duo CPU, it will support an Intel Pentium D.
Plus you can always go to Intel Support, and look, lol!
http://www.intel.com/support/motherboards/desktop/d102ggc2/sb/CS-026580.htm
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_D_microprocessors#.22Presler.22_.2865_nm.29
So what are we talkin' about?
A Intel Pentium D, model 925 or model 930?
Up To a maximum frequency rate ('Speed'), of 3.0GigaHertz
L2 cache of 2 x 2MegaByte (2MB)
FOLLOW Anti-Static Procedures.
THOROUGHLY clean the top of the Processor, and bottom of the Heatsink.
Properly apply fresh, new Thermal Paste.
http://www.hardwaresecrets.com/article/274
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 27, 2013 | E-Machines T5082 PC Desktop
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
Tried installing 4gb memory on to acer aspire 5720z notebook running vista 32bit, they would not be recognised. Have now installed vista business 64 bit & the 2 x 2GB new memory is still not...
  • CPU Section:
  • Microprocessor Full Name:Intel Core 2 Duo processor T5250
  • Microprocessor Manufacturer:Intel
  • Microprocessor Speed (GHz):1.5
  • L2 Cache (KB):2 Mb
  • Frontside Bus (MHz):667
  • Memory:
  • Memory Speed (MHz):667
  • Memory Type:DDR2
  • Memory Size (MB):2048 Mb
  • Max Memory Size:2Gb
  • Hard Disk Drive:
  • Hard Drive Capacity (GB):80 Gb
  • Hard Drive Type:S-ATA
As you can see from my printout from the web site, this laptop doesn't appear to support more than 2Gb of RAM.
Sorry.
Oct 18, 2010 | Acer Aspire 5720 Notebook
Can I upgrade my CPU to an Intel Core 2 duo 1.7
You are basically limited to what was optional on the model. So you can only upgrade to one of the following cpus:
Intel Pentium M 745 (1.8-GHz) with 400-MHz front
side bus (FSB)
Intel Pentium M 735 (1.7-GHz) with 400-MHz FSB
Intel Pentium M 725 (1.6-GHz) with 400-MHz FSB
Intel Pentium M 710 TJ85 (1.4-GHz) with 400-MHz FSB;
operates at a lower temperature than other processors
Intel Celeron M 340 (1.5-GHz) with 400-MHz FSB
Intel Celeron M 330 (1.4-GHz) with 400-MHz FSB
And you are limted to 2gb of ram max on this model.
Apr 12, 2010 | HP Pavilion dv1000 Notebook
Like to upgrade I have DG 965 RY LGA 775 Socket
Hi, your motherboard supports several different kinds of processors. You have a choice of two for the fastest performance. You could go with an Intel Core 2 Duo Processor #E6700 that runs at 2.66 Ghz with a front side bus of 1066 Mhz and 4 Mb L2 cache, or you could go with an Intel Single Core Processor #670 that runs at 3.80 Ghz with an 800 Mhz front side bus and 2Mb L2 cache. The Core 2 would outperform the Single Core, but it is more expensive. Hope this helps! Hal
Jun 03, 2009 | Intel DG965RY Motherboard
Core (TM) 2 duo processor E7300, socket LGA 775, freq. 2.66 GHz, FSB 1066 MHz, L2 Cache 3MB, PCG 06, core 45nm what asus motherboard should i buy
buy any motherboard BUT asus.
asus tech support is rubbish.
i run my system on an ASROCK motherboard.
excellent boards, 2500mhz bus, can handle any cpu, most have 4 ram slots.
Feb 24, 2009 | ASUS LGA775 SOCKET FOR INTEL CORE2...
ASUS P5VD2-VM SE - Motherboard - micro ATX - P4M890 - LGA775 Socket - UDMA133, Serial ATA-300 ...  Logo
2,178 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
