Question about La Pavoni "PROFESSIONAL Chrome" 16Cup
La Pavoni Professional, Chrome, 16 cup capacity Europiccola
Any know how to remove the clear plastic cover ( lens ) that surrounds the sight glass It needs cleaning?? Thanks,
tervezo
  • 515 Answers
You have to take a screwdriver and try to bend up the platic, be careful so you not break it.
Posted on Aug 20, 2008
Dissasembling Europiccola Pavoni
The boiler is tightened down via a big brass or plasitc ring which is threaded look on the page linked below
Apr 12, 2014 | La Pavoni Europiccola EPC-8 Espresso...
Dissasembling Pavoni Europiccola
Try looking at this site its really good helped me do various repairs to my La Pavoni Pro
http://www.francescoceccarelli.eu/lapavoni_faidate_eng.htm
all the best P
There is water leakage on my La Pavoni Europiccola machine
I am a domestic coffee machine engineer based in Glasgow, Scotland and i service, repair and refurbish these machines on a daily basis. You will probably find that the gaskets which are holding the sightglass in place are completely solid and resemble a hard plastic like gasket. There will definately be gaskets there as if not the sightglass would rattle about and the water would pour straight out. It depends on which sight glass nuts you have but if they are the clear plastic nuts you will find either black, white or clear gaskets underneath and if the nuts are metal then you should see brass washers first and then the gaskets underneath the washers. These are easily replaced and can be purchased from our website www.theespressoshop.co.uk I hope this helps and if you have any further questions or queries then please do not hesitate to get in touch at domesticespresso@live.com
Apr 05, 2010 | La Pavoni Europiccola EPC-8 Espresso...
On a La Pavoni europicola which way do the piston seals get installed, both the same way or opposite to each other?
Normally on lever machines the top seal sits with the cup area(slash in gasket) facing up and the bottom facing down.
May 16, 2009 | La Pavoni Europiccola EPC-8 Espresso...
First Cup Is Cold From La Pavoni Europiccola
If the machine works great after the first cup then it is possible that the heat for your first espresso went to heating the portafilter or the cup used to brew into, try warming the portafilter first by running some hot water through it first.
Apr 09, 2009 | La Pavoni Europiccola EPC-8 Espresso...
Hi there, Where can i buy a replacement heating element for the Europiccola Copper-Brass Espresso machine? V220 W1000
Hi there
I supply all La Pavoni spare parts and dispatch all over the world. Go to www.theespressoshop.co.uk and click on the la pavoni machine on the right to access the full parts list. We have all variations of the elements.
All the best
LaPavoniBoy
Feb 22, 2009 | La Pavoni Europiccola EPC-8 Espresso...
Adding pressure gauge to Pavoni Europiccola
  1. in the boiler water is heated and presured up to 1.5 bar
  2. when water gets in lever and non return valve closes becouse you press the lever down, your energy is used to get high pressure, it should be frpm 7 up to 9 bar.
  3. SOLUTION==if you search way for modifying, you must consider that you must pump directly to group, not to boiler. in this case water will be cold (becouse comes from pump). you will need boiler in boiler to heat the water wich comes from pump before it gets to group. this is bit more complicated than you thought may bee but it is only solution.
Feb 20, 2009 | La Pavoni Europiccola EPC-8 Espresso...
La Pavoni "PROFESSIONAL Chrome" 16Cup Logo
225 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
