Question about KitchenAid Dishwashers
KitchenAid dishwasher is dead
I have a Kitchenaid dishwasher model KUDS011JBS0. Two days ago whenthe dishwasher was running normally it shut off with no power lightswhat so ever on the front panel. The circuit breaker did not trip andis turned ON. The dishwater is still dead when I push any of thebuttons on the front panel.
I am looking for a service repairmanual so I can troubleshoot the unit but I need to know how it iswired. I don't know if it has an internal fuse or circuit breaker.
Several months ago I had a microwave problem and I found the answer onFixya.com and I have passed that answer on to many other Fixya people. Hopefully I can get help again.
Can you please help me? Thanks very much.
  • 4 more comments
  • Bill Artman Aug 20, 2008
    I have checked the small micro switch with an ohmmeter that is operated by the door latch and the switch is good. I have 123 Volts at the input to what I believe to be the controller board which has 3 Potter & Brumfield relays among other components.
  • Bill Artman Aug 21, 2008
    I wanted to clarify - Regardless of what front panel buttons I push there are no lights on the panel that light even though I have 123 volts at the input of the controller circuit board which is in the right top of the door.
    Thanks!
    Thanks for your suggestions but I still need additional help. The dishwasher front panel has no error codes showing and when I push any button there are no lights showing.
    If I have 123 volts at the input to the controller circuit board but no error codes or lights on the front door panel regardless of the buttons I push what are the chances that the controller circuit board is bad? A new board is about $100 so I would like to pretty sure it is bad before I buy a new board. Is there any troubleshooting that I can do. I am very technically inclined.
  • Bill Artman Aug 23, 2008
    I have located the TCO thermal fuse and tested it with an ohmmeter. The fuse appears to be open and bad. Can you use an ohmmeter to test this fuse?
    Thanks
    The thermal fuse was bad - when I replaced it the dishwasher started working again. I used the Premium Support Service and the Fixya.com experts suggested the fuse and also told me where to locate it on the dishwasher.
  • 157 Answers
Yep, u can use an ohmmeter to test a fuse.
I think uve found the problem .
Good work
Cheers
JigSaw
Posted on Aug 23, 2008
  • 2,334 Answers
Click here to find more troubleshooting info.
Once you get access to the control panel board inspect the solder joints from the relays and connectors if the thermal fuse is good.
Posted on Aug 21, 2008
  • Jaime Hernandez Aug 23, 2008
    You can use the ohmmeter to test the TCO thermal fuses.
    Just for testing purposes you can use any other fuse with the same ratings as the bad one. If the device powers up, remove that fuse and order the proper thermal fuse.
    Good luck.
    Master:
  • 763 Answers
After all suggestions and still experiencing the problem and if your machine is still on warranty then send it back to their shop. they have tools and equipments for replacing some parts of your dishwasher. its better to become safe than risky. hope that helps sir.
CHARCOIS
  • 928 Answers
I cannot find the exact schematic diagram for your dishwasher but most often the power supply input on the unit itself has a fuse attached to it to prevent power surges from burning out the board. You could check that.
  • 1 more comment
  • Thomas Lim
    Thomas Lim Aug 21, 2008
    Your dishwasher does not display anything on the front panel anylonger hence no power input. Most likely its a fuse on the units power supply. If you are not comfortable with working within the unit to check it. I would suggest you take it in for repair or have it serviced in your home. You said you measured your input and it comes out at 123V that means that there is an overload which might have caused a blown fuse
  • Thomas Lim
    Well if power is coming into the board then the board is shot. If there is no power then check the power supply of the unit. A dishwasher is a bit simple there are only 2 things 1 power 2 board the rest are just controlled by the board if there is no power then the problem is with the board and so forth
  • Thomas Lim
    Thomas Lim Aug 23, 2008
    Ok good you can test it with an ohmmeter the guide to the link below is for a multitester but its the ohmmeter function that you need anyhow so just base it on that
    http://www.electronicrepairguide.com/how...
  • 2,071 Answers
WHAT IS WRONG WITH YOUR DISHWASHER?
KitchenAid dishwasher is dead - small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Hope this may help;
Dishwasher motor starts and stops
Hey Bill,
Not professing to be any kind of a dishwasher repairman but I have had a similar issue with the start and stop thing and it turned out to be the timer motor had started to go, and in going it 'burned' a couple of sets of the contacts as well. Check with a local appliance repair centre and see first if they agree with me, and if they have anyone who can rebuild the timer - Typically not too hard to get access to and remove - In my case in Canada, it had to go to Toronto pre-paid but $70 was cheaper then a new dishwasher and it's worked great for years
Feb 09, 2014 | KitchenAid Dishwashers
How do you reset a KitchenAid dishwasher model: KUDE70FXSS4?
Press High Temp Scrub and Dry Heat option buttons in quick succession one after the other for about 6 sec until all the lights come on. Then press Cancel button. This should reset the dishwasher. Press equivalent buttons on the panel if the actual ones above are not there.
Make sure the dishwasher detergent dispenser lid is shut and the dishwasher door is shut before you start the above reset sequence.
Jan 02, 2013 | KitchenAid Dishwashers
Kitchenaid Dishwasher door wont latch
I have a brand new whisper quiet dishwasher model kudk02crbs4 I hook everthing up but the door does not lock what is worng I have no clue what wrong
Apr 14, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
////////////////////my kitchenaid dishwasher lights are flashing
Can you explain the issue in detail - is your dishwasher not working at all, or the buttons continue to be lit up, etc?
First and foremost, check the dooe switch to see if it is functioning properly.
Nov 26, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
KitchenAid Normal light stays on
check to see if its a draining problem,blockage under the sink etc ive not worked on this brand before.hope this helps.Ian
Mar 19, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Issues with dish washer (kitchenaid)
Really hard to say. Maybe find a deal on both on eBay.
Nov 05, 2017 | KitchenAid Dishwashers
Dishwashers Logo
710 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
