Question about Motorola Mobility HS850 Consumer Headset
People can hear me hs850
My bluetooth connects and yet when I try voice activation or when I'm on a phone call people can't hear me
Try re - pairing the headset with your phone. Delete the older paired profile from your phone before re pairing.
Good luck
Posted on Aug 26, 2008
Can't hear anything in my bluetooth headset, mic is working
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.php
Jan 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
Bluetooth not working
Make sure you have connected the bluetooth correctly, if you have and it still doesent work, your phones bluetooth capabilitys my be Gliching or broken. Also make sure you turn the volume All the way up.
Dec 24, 2008 | Motorola Mobility HS850 Consumer Headset
Bluetooth head set
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select HS850 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Sep 22, 2008 | Motorola Mobility Universal Wireless...
Problems with my motorola hs850
Set your volume to mid range. If it continues you'll need to return it or exchange it. The voice pickup sencer in the bluetooth is defective. Or the phone needs an upgrade.
Jan 27, 2008 | Motorola Mobility Bluetooth Hands Free...
Motorola HS850 Headset gone silent
I bought a new HS850 and guess what, I got this hearing problem on the very first day ...phew ! I did the pairing with my Motorola A1200 phone and it worked for once, even the sound was coming in the earpiece and then I put it to charge for the first time and once done, I again started it up and it got connected with the phone and after that there was no sound in the ear piece. I was going nuts....about what could be the problem.
So i decided to delete the earlier paired profile from my phone and do the pairing again and guess what...It Worked....:) So you can try that out too....
Dec 06, 2007 | Motorola Mobility HS850 Consumer Headset
Bluetooth
hello iam having trouble activating my bluetooth
Nov 03, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Motorola HS 850 Mic is not working.
perhaps it is in "mute mode" which can be activated on the headset itself by simultaneously pressing both the up and down volume buttons. Also, have you tried deleting the device from the phone you are using before you pair it up again? finally is there any firmware/software update available for the phone? This can be the case frequently with bluetooth problems with Blackberry devices (I know this from painful experience with this same headset). Good luck.
Aug 21, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola HS850 Bluetooth headset
no u need to take it to phone manufactuer
Jun 28, 2007 | Motorola Mobility HS850 Consumer Headset
Echo in hs850 headset
You did not say what phone you are using but I found that this problem went away for me when I changed a setting on my blackberry. I turned "encryption" off in the bluetooth settings on my blackberry 7100t and solved the echo problem. Alternatively, there might be a "compression" setting also. This one made no difference for me but might for you on your device. Also, make sure any firmware or software updates for your phone have been applied. On blackberry devices you do this via a PC. On cell phones it usually involves a reset or update from some buried menu options or call to their tech support. good luck.
Jun 05, 2007 | Motorola Mobility HS850 Consumer Headset
Unable to have my voice heard
Delete the paired headset,switch off the phone and try pairing again.If its still not working then it could be that your mic is gone DEAD.
Apr 24, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility HS850 Consumer Headset Logo
60 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
