Question about Electrolux Dishwashers
Electrolux WT-4 -- C2 error code -- What is it?
  • 3 Answers
Electrolux w60 e the machine show :c2 : when turn on the system con not to do anything . plaese...
Posted on Jul 30, 2009
  • 38 Answers
C2 is Boiler temp too high.
Possible causes include:
Boiler Temp setpoint adjusted above 90C in programming
Boiler relay welded/melted
Boiler water level sensor not functioning correctly
Hope this helps,
Kermit
Posted on Aug 20, 2008
Hi Electrolux cooker 607601 error code 4 f on the top oven when using the grill what does that error code mean. Kind regards
It is good practice to specify model of appliance
(like EOG9330XN).
Probably means temperature range of oven sensor exceeded
(for more than 5 seconds).
Dado
Jan 10, 2015 | Electrolux Ovens
ELECTROLUX WAVE TOUCH GIVING ERROR CODE 4
Hello JOHN, thanks for your post!
From the information you have provided your Electrolux dishwasher is displaying error code 4. "E4" stands for drying damper which means it could be a potential problem with your damper or the main control. I would recommend performing a reset and that could clear any false error codes. To reset your dishwasher flip the household circuit breaker off for roughly ten minutes. If that does not help correct the issue I would recommend having a professional technician out to properly repair it. Good luck. -Matt
Jan 09, 2015 | Electrolux Dishwashers
How to fix c2 error code on 5400
1) For Rheem tankless water heater, C2 11 is usually means bad circuit board.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
2) What is a 5400?
Is this a water heater?
What brand water heater. What type.
Is this gas or electric.
New installation, or older installation that started having problems.
Has required yearly maintenance been done?
Is the unit rated for correct altitude?
Has the water temperature been increased?
3) Add comment and include description of product, and best description of problem for possible assistance.
4) Call service technician.
Dec 30, 2012 | Water Heaters
Nokia c2-02 probulam no sim working. Shows enter code undo
Hi, I think your mobile must be network restricted. You must unlock it. The safest and easiest way to unlock a Nokia C2-02 is to unlock using unlock code. You can get the unlock code for a Nokia C2-02 from www.prounlocking.com/nokia-c2-02/rs8wp9/ at affordable cost with easy unlocking instructions.
Here are the steps for unlocking a Nokia C2-02,
1 - Switch on your Nokia C2-02 without any sim card.
2 - Don't bother as to what is displayed on your Nokia C2-02.
3 - Compose #pw+CODE+1#.
4 - The Nokia C2-02 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia C2-02 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
Sep 27, 2012 | Cell Phones
How do I access the fault codes on an electrolux 1200
I see many posts about Error Codes that aren't in the user manual. Here's what I found: Go to Google and type in "Electrolux Error Codes" and you will find the following site. It details an Electrolux Service Flash that helps with error codes that don't appear in your user manual. Good Hunting!
Customer Error Codes On All Digital Display Frontload Washers - [ Terjemahkan laman ini ]Electrolux Service Flash LN071 02.13.07. NOTE. These customererror codes are not included in the error code chart on the technical data sheet located ...
www.applianceblog.com/...electrolux/886d1212672468-frigidaire-front-load-washer-doesnt-start-frigidaireerrorcodesonalldigitaldisplayfrontloadwasher...
Sep 16, 2012 | Electrolux EW1200i Front Load Washer /...
Nokia C2-01 IMEI Code?
IMEI CODE and Network unlock code are same.You can get the Nokia C2-01 IMEI unlock code at affordable cost at
Onlinegsmunlock.com/nokia-c2-01/rs7wp9/ unlock it easily..To enter the code you can follow the instructions below:
Nokia C2-01 Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Nokia C2-01 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia C2-01 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia C2-01 without any sim card.
2 - Don't bother as to what is displayed on your Nokia C2-01.
4 - The Nokia C2-01 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia C2-01 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
Aug 09, 2012 | Nokia C201 Cell Phone
DISHWASHWER WT 65 EIM:ERROR CODE C8.WHAT DOES IT MEAN?
according to the manual...error code 8 indicates a problem with the control panel. here is the link to this manual...page 21 of the pdf http://manuals.electroluxusa.com/prodinfo_pdf/Kinston/154671101en.pdf
Hope this helps you! PS, this model number in the link may or not be similar to yours I had a problem locating your exact machine..so let me know if it isn't the right one and I'll go look some more. meantime...is there another model number on the inside side of the washer door?
Jun 21, 2012 | Electrolux Dishwashers
I have an AEG Electrolux oven D8800-4 double oven and have ann error code A3, what does this mean?
I hope you mean error code F3. if so then that means a software error and if you disconnect from mains supply then reconnect this should reset the fault if that does not work you may have a damaged circuit board.
Hope I helped.
May 06, 2010 | Electrolux Ovens
Dishwashers Logo
741 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
