Question about Motorola T8500 Two Way Radio
I have 4 of the motorolla T8500, We can't get them to work. They are powered on, but when we hit the button to talk the other person can't hear. Even if we are in 50 yards away
  • Motorola Master
  • 1,654 Answers
It is likely you have the Interference Eliminator Code (aka Private Line or PL) set differently among the 4 radios. Your T8500 has 22 built in frequencies (noted by the BIG number on your screen) and 121 selectable PL codes (noted by the small number below the BIG number on your screen). All four of your radios must match on both numbers to communicate.
Use the menu button until the code starts to flash. Use the + or - button to select the code. Once you have selected the code you can press the PTT button to lock it in; or you can press the menu button to continue programming other features.
You can find a PDF of the user manual at
Posted on Aug 20, 2008
    Problem Solver:
  • 4 Answers
Buy a new Battery Pack KEBT-071, Your Batteries are death.
Try Testing With some Alkaline Batteries.
Posted on Jun 12, 2009
Don't talk to each other
What channel do you have to listen to the weather
Mar 10, 2013 | Motorola T8500 Two Way Radio
T8500 Backlight
Here is a link to the user guide:
I did not find anything mentioned about the backlight function. However, on other TalkAbout models the backlight will automatically illuminate when you press any of the buttons other than the PTT and the musical note, and then the light will remain on for 5 seconds before automatically turning off. I do not know if this is the same on the T8500.
Best regards.
Feb 22, 2013 | Motorola T8500 Two Way Radio
Press to talk button keep turning off and on battery has good charge?
The battery may have a good charge but still be wek, how old is it ?
Nov 13, 2012 | Motorola T8500 Two Way Radio
Two motorola t8550's unable to communicate
1) You did not mention the Qt filter. You might check to see if you have the Qt filter set the same on both radios. This is an additional layer of privacy featured on this radio.
2) Verify you have good working batteries. A bad battery or uncharged battery can cause a no transmit situation.
3) If these do not work, reset your radio back to a basic operation by shutting of the code, Qt filter, call tone, weather alert, Vox/iVox, roger beep, etc. At this point your radio would be operating just on a simple frequency. See if you can communicate with all these special features turned off. If so, slowly add back in the features you desire.
4) If your radios still fails to work and is less than one year old, call the 800 number on the pamphlet, have your serial numbers and radios handy. Your radio if not physically or water damaged is possibly still under warranty.
Most of the time when a set of radios has your problem description, it is the Qt filter, or possible improper use of a special feature such as call tones or iVox. These would be the first things to check.
Best regards.
Mar 09, 2010 | Motorola Talkabout® T8500R Two Way Radio
Motorolla sb4200 standby problem
hit the modem on the side hard it will work try it
Nov 06, 2009 | Arris SURFboard SB4200 Modem
No communication with one of my motorolla T6550 radios
I believe you have a defective microphone in the bad one. Since you have a new warranty, I suggest that you use it and don't wait around.
Jul 05, 2009 | Motorola Talkabout T6550 (7 Channels)...
T8500 no recieve transmit vibrates when PPP is pressed
Try checking the vibra call settings for your vibrating issue. Also, as for the radios not communicating with one another you should check the programming of the frequency, interference eliminator and the Qt filter. All radios must be identical to work together.
Apr 27, 2009 | Motorola T8500 Two Way Radio
We have 4 T8500 - only one can talk, the other 3 only recieve.
Can you tell if the radio is actually transmitting? Is there any sound on the transmitting radio or a light inditcating that it is indeed transmitting? If not maybe the PTT button is malfunctioning. Try to use a microphone plugged into the accessory jack and see if it works. Another option is if you have a radio scanner, search the frequency range while transmitting and see if you pick up that open carrier.
Feb 24, 2009 | Motorola T8500 Two Way Radio
HP Solutions Center can not communicate with HP 3500c Scanner
Had exact same problem. Went to HP site and they said to check "add or remove programs" functions (in control panel) and if there are multiple copies of HP software to download their fix. I checked, had multiple copies, downloaded patch and all worked well again.
Sep 21, 2008 | HP ScanJet 3500C Flatbed Scanner
My radio turns off automatically as soon as I hit the talk button.
i hope it has only the offer to talk or radio on.
even my mobile ve same ll either in radio mode or in talk mode.
both never be activated together
Aug 26, 2008 | Uniden GMR638-2CK (22 Channels) 2-Way...
Motorola T8500  Two Way Radio Logo
395 people viewed this question
Top Motorola Radio Communications Experts
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
