Question about Hauck Infinity Stroller
In need of a spare wheel
The rear wheel rim is damaged beyond repair so i need to replace it. please tell me where to order the new rim from. thank you.
  • Anonymous Jan 05, 2009
    I have the Hauck Infinity Rockstar Baby stroller. One of the rear
    wheels has had a slow leak since we received it. I would like to
    buy a new wheel .
you can order spare parts directly from their UK headquarters in Wrexham. The number is 08708406727 - good luck!
Posted on Nov 11, 2008
Hi, I have a similar problem. After a long haul plane trip, we found out that one of the rear wheels had been forced inwards and the axled crooked. I found this website where spare parts can be bought www.strollers.com
Posted on Aug 24, 2008
Why does my rear passenger wheel in my 1992 ranger still wobbel really bad even after replacing the rim and tire with brand new ones? What could the problem be i need help pleaseeeee!!!
You need to remove and refit wheel as it sounds as if it has not reseated properly.if it has been fitted correctly and all nuts tightened then any further wobble is either due to wheel balance ,,,, or due to compromised structure supporting wheel which need to be checked immediately..i.e. Drive shaft ....axle.....wheel bearing etc.
Feb 19, 2015 | Cars & Trucks
I have a honda c-rv 97 and it produces grinding sound on the rear left wheel. When I jacked the wheel and tried to remove it, rhe rim got stucket with the wheel drum so I used a piece of timber to hit the...
Most likely your rear brake shoes are worn down far beyond the min limits and you now have metal to metal contact, which causes the grinding noise, overheating and poor braking. You most likely will need to replace the drums. The other rear wheel will probably be the same.
Feb 05, 2015 | Honda Cars & Trucks
Mavic Crossmax SLR rim split. I want to order a new rim for the rear wheel. How do I go about it?
Either trust your local shop, or call one of the e-bay or Amazon vendors, such as Nigara, Bike Wagon.
Sep 16, 2014 | Mavic Crossmax Slr Disc Mountian Bike...
New wheel required
salvage yards hav them-----maybe try fixin it---library has many motorc repair books----purchase a clymer manual for full repair details
Jan 22, 2014 | Honda Vigor FX 650 Motorcycles
How to remove a rear axle on a 98 Chevy K1500 truck
first up jack up the vehicle and remove the damaged wheel
fit the spare tire and then place an indicator ( rod on a brick ) close to the rim of the spare and turn the wheel
if the axle of hub is bent you will see the rim get closer then further away from the indicator as you turn the wheel
if it is , replace the axle and bearings
if not there will be no axle damage but the bearing could be "brinnelled "( a bearing term where the balls or rollers have been imprinted into the race from impact) in which bearing failure will become evident in 10-20,000 miles
next step is to go and get a rear end wheel alignment done as there could be suspension damage that will cause handling and tire wear problems
Jul 16, 2017 | 2002 Chevrolet S-10
Have roadmaster mens bike 26in. Rear rim is bent need to pull out guts to replace with new rim. Cant remove part were chain goes on rim
No guts need be pulled out. You just have to remove the gears to get at the hub flanges straight-on.
You know, a complete wheel replacement might set you back less than the parts and tools you would need to do it correctly.
http://www.parktool.com/blog/repair-help/categories/wheel-and-rim-service
http://www.parktool.com/blog/repair-help/wheel-and-rim-truing
http://www.parktool.com/blog/repair-help/freehub-service
Google "bicycle rim replacement" for the actual procedure.
Like this one that starts out, "The wide availability of inexpensive, well-built replacement wheels has reduced the need for wheelbuilding in retail bike shops."...
http://sheldonbrown.com/wheelbuild.html
Apr 13, 2011 | Cycling
I need a front rim assembly for a mongoose spark 26" X1.95 dual disc brakes. i purchased this bike at wal.mart north Olmsted, Ohio 44070. the bike was hit at the front rim is bent beyond repair. i...
If you want only the rim who would assemble it for you? At this level of bicycle it's usually cheaper to buy a wheel than to buy a rim and have a shop swap it over.
Look at the disc itself and count the bolts holding it on. You want to order or locate a 26-inch disc wheel with a hub that matches the disc rotor you have because you'll be transferring it to the new wheel.
You probably also would want it to match cosmetically. Then look closely at the rear wheel and assess what brand (or at least what color) the hub and rim are.
A quick search of eBay for generic "26" disc front wheel" 's brings up 37 of them starting at $45 including shipping. OR you could drag the Bike or just the bad wheel to a real Bicycle Shop and let experts take care of everything.
Mar 23, 2011 | Cycling
Had a flat tire on my GMC Sonoma. Changed the
wheel rim damaged ?? locating pin for wheel not lined up
May 16, 2010 | 1993 Nissan Altima
Nx 650 dominator rims and tubeless tyres
If the hubs and sprocket locations are the same, then you could change it no problem.I personally found that there is little or no advantage having one or the other, except that if the wheel combination of tyre and rim is lighter, then your handling will benefit marginally for obvious reasons.
If you go bigger on the rim, you lose out slightly on acceleration, but improve your MPG or you could simply compensate by going up a tooth or two on your back sprocket.
As far as your long outback trek, I would recommend using a tube as if you have a problem with the tyre or rim, you can get stuck with no way to pump it up.Whatever you decide, I recommend taking a spare tube , puncture repair kit.
Hope this helps, and good luck on your trip.
Sep 20, 2009 | 2001 Honda XR 650 L
Need spare rear wheel for P&T e3
I have ordered several replacement parts for my phil and ted sport from Regal Lager its based in the US. Google Regal Lager They are great they could get you the part or tell you where to get it.
Jan 03, 2009 | Phil & Teds E3 Jogger
Hauck Infinity Stroller Logo
853 people viewed this question
Top Hauck Baby Gear Experts
Kelley Hopper
ray gallant
Dorel UK
Dorel UK
Are you a Hauck Baby Gear Expert? Answer questions, earn points and help others
