You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd then stat plot, and then select 4:PlotsOff. By the way it is easy to graphing function y=x^3-x^2-10x-8. See captured images: full graph and detail of the left side max
As you can see this function have zero values in the points -2, -1 and 4
If the message appears when you try to graph functions deactivate the
statistical plots. To do so:
Press [2nd][Y=] to access (STAT
PLOTs) Select [4:PlotsOff] then [ENTER]
That should solve your
problem. Post a comment to this thread if you still have trouble
graphing.If the message appears in another context, it sure
would help knowing the context of the error.
Hello, The easiest and quickest way to start graphing is to reset the RAM. Press [2nd][MEM][7:Reset][1:All Ram][2:Reset], then [CLEAR] to clear the RAM Cleared Message and go to the main screen. Hope it helps.
Hello, [2nd][MEM][7:Reset][1:All ram][2:Reset] [ENTER]. Screen shows RAM cleared. Clear the screen and use [Y=] to enter the functions you want to graph. Hope it helps.
Hello, Here is what the manual says INVALID DIM : The dimension of the argument is incompatible with th current operation. (As dimension of a matrix, a list).
You can tell us more about what your were trying to do, we may able to help. Reset memory to default, the error may disappear. [2nd][MEM][7][2][2] Defaults set.
