Question about Kirby G6 Bagged Upright Vacuum
Kirby G6 without suction
When powering on the vacuum, the light comes on and continues to flicker but therre is no suction. Vacuum sounds unusual. Both the belt and bag look good.
  • grisdahlin Aug 21, 2008
    The feed from the vacuum head if free of any clogs. The unit powers on and both the main headlight and green light indicator flicker. There is also an electrical odor (not from a burning belt).
  • Anonymous Mar 13, 2014
    Red light comes on then cuts out.
  • 357 Answers
The power head light flickers when the brushroll is temporarily not spinning. You may need a new belt and/or a new brushroll. As for the unusual sound, you may need to replace the fan. See my troubleshooting guide and from there, you can view my so it yourself guides for fixing your Kirby.
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
Posted on Aug 28, 2008
  • 89 Answers
You probably have a clog in the feed tube going from vacuum head to the bag try removing bag and check for clog there hope this helps
Posted on Aug 20, 2008
Not very good suction on my kirby g6d
Change the bag? Change the Belt? Check the brush roller.
It's one of those three 99% of the time.
Jan 30, 2013 | Kirby G6 Bagged Upright Vacuum
Kirby G6 not vacuuming
The dirt path probably is clogged. The brushes are not turning because the drive belt is disconnected/broken/stretched
Sep 23, 2012 | Kirby G6 Bagged Upright Vacuum
Kirby G6 - won't power on
Check the cords two wires with an OHM meter for continuity replace if you get a reading showing OL The ground wire you can forget about this test
If any sort of numbers appear in the meters display the cord is good
Replace the switch instead
Jul 10, 2010 | Kirby G6 Bagged Upright Vacuum
Replace power cord on Kirby G6
The Kirby vacuum cord can be found at http://www.totalvac.com/K-192099ES.html
Jun 16, 2010 | Kirby G6 Bagged Upright Vacuum
Kirby g2000 not picking up dirt
It is most likely the belt. You cannot reverse the suction. First check to see if the bag is expanding when running. If the bag is blowing up then it is the belt if not it is clogged just take the bag off from the vacuum and remove the head you will see the obstruction.
Dec 16, 2009 | Kirby G6 Bagged Upright Vacuum
Kirby g6 will not pic up dirt. Belt is on and bag
check for blockage or impeller if vacum makes loud noise the impeller is the part that gives it suction
Oct 15, 2009 | Kirby G6 Bagged Upright Vacuum
Shampooer won't pick up water
look on the vacuum where the suction is to pick up and you will see its clogged ,clean out the suction ports
Apr 13, 2009 | Kirby G6 Bagged Upright Vacuum
Gear lever
here are a few links to repair proceedures for the kirby (pictures included)
Transmission:
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
On/Off switch
http://www.greatvacs.com/Kirby%20Powerswitch.shtml
Hope that helps!
Jan 02, 2008 | Kirby G6 Bagged Upright Vacuum
My kirby has no suction
Even if you have a new belt, do everything this guide tells you to do. The seller may have the power nozzle assembled improperly. If the brushroll is in wrong or the base plate is not on correctly, it may cause these symptoms.
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Hope this helps,
Marci
Nov 10, 2007 | Kirby G6 Bagged Upright Vacuum
Kirby G6 Bagged Upright Vacuum Logo
188 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
