Question about Nvidia GFORCE FX5700LE 256DDR WITH TV+DVI Graphic Card
Gforce 6200, and the on-board video
So, my dad bought a gforce6200 and pluged it in, and kept using the onboard vid, so nothing is working right on his pc, i cant get the gforce to work and i'm about to lose my mind, any input?
  • 111 Answers
Hello i can't install a AGP 512 videocart I bought
your computer needs more than the video card ram amount to use a particular video card. if you do not have at least 512mb of system ram, that may be your problem. if you have sufficient ram, then you do not have a powerful enough power supply for the new card.
Nov 22, 2010 | EliteGroup KV2 Lite (V1.0) Motherboard
Hi, I'm thinking about adding a GForce 6200 LE graphics card to the system, do I need to disable the on board graphics ? And how do you do that ? Thank You.
A Geforce 6200LE would work perfectly with that motherboard, all you have to do is clip it into the AGP8x slot and disconnect your monitor VGA cable from the onboard graphics and into the 6200LE graphics card. Once the Graphics card is inserted correctly and plugged in your sytem automatically disables onboard graphics as it is no longer needed.
Please rate me high.
Thanks.
Oct 31, 2010 | PC Chips M957G Motherboard
Video
go to Nvidia web site and dowload the correct driver for the OS that you have.
Apr 01, 2009 | Nvidia GeForce 6200 AGP Graphic Card
Display error with nvida Gforce
1st see from the bios whether you can get the graphics card in the agp slot or not.....try to take the display with out graphics card from onboard.......always check from bios....may be the card is not properly inserted into the agp slot
Mar 14, 2009 | Nvidia GeForce 6200 AGP Graphic Card
P4m800pro-m478 "No video"
if you have another pci slot install the card there
if that does'nt work
your card has probably gone
please rate me
thanx
Feb 02, 2009 | EliteGroup ECS P4M800-M Socket...
K9mm-v via k8m800 + vt8237r / amd athlon / running ubuntu 7.10 video problems
MY GUESS IS THE NORTH BRIDGE ON MOTHER BOARD IS BAD, REPLACE MOTHER BOARD.
Dec 16, 2008 | Computers & Internet
Won't boot
You will need to flash the graphics bios of you comp. Put the CD that you got along with the Card and reboot your computer and then follow the onscreen instructions to flash it.
Let me know if you need more help!
Regards,
Sai.
Sep 26, 2008 | Gateway 510 X (10272197) PC Desktop
ASUS M2A-VM Motherboard is registering my GForce 7800
Did you disable the onboard video?
Click Here for review and comments regarding your board and video card.
Jun 29, 2008 | ASUS M2A-VM (0610839149438) Motherboard
I865gvm-i motherboard
Enter your bios & make sure the video is set to AGP.
Your card has two VGA outputs. One VGA & one HDMI (high def). Switch your monitor cable that connects to the video output to the other femal connector at the Pc. You can do that while the system is running.
If that does not help think of this. You have been using the onboard video for some time. It must be dirty as heck. Remove the 6200 & blow it out with some canned air. No canned air. Use a clean paint brush & a sweaper. Than grab some alcohol & a cotton swab. Lightly dampen the cotton swab (no dripping). Wipe the copper retainer contacts of the video slot. Let it dry completely. Re-seat the card applying even pressure side to side till the card is seated firmly into the slot. Some cards require additional power. Check your 6200's install manual.
please vote...
Feb 18, 2008 | Intel Motherboard
Video card
actually your computer is working on the onboard video adapter.
1. connect first the monitor to the onboard video card.( do not remove the connected geforce video card.)
2. switch on the computer and press "F2" on new model computer, "Delete" on old model computer.
so that you can enter to bios setup.
3. if bios setup is open; try to find the "AGP bridge configuration"
(some other bios AGP B C is in chipset) by arrow up,down,side left and right) enter.
4. Find " primary graphics adapter"
5. In there, select : If Video card is "pci" connected ; select "pci"
If Video card is "AGP" connected ; select "AGP"
6. press F10 to save and exit the setup.
7. after saving the configuration, disconnect power cord and transfer the monitor to the video card (Gforce). and then connect the ac power cord and then start. or switch on the computer.
Note: be sure to install the drivers of your GFORCE for optimum performance of the card.
hope this help.
Dec 21, 2007 | ASUS P4P800 SE (890552603657) Motherboard
Nvidia GFORCE FX5700LE 256DDR WITH TV+DVI Graphic Card Logo
98 people viewed this question
Top Nvidia Computers & Internet Experts
Terry
David
David
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
