My HP laptop monitor has gone crazy! The display is mostly purple and pink. No black at all! Blocky, rectangular shapes make up the display. The word "psychedelic" comes to mind... All video drivers are up to date. Any suggestions?
  • 84 Answers
Try to replace the video card , that causing the different colors.
Posted on Aug 20, 2008
Gr dv900
Display problems are among the most common difficulties people have when upgrading either Windows or their computers. Here are solutions to some common display problems.
You can also try running a troubleshooter to diagnose and fix common problems with Windows Aero, which can cause display problems.
To run a Windows Aero troubleshooter
  1. Click this button:
    15ad0d89-8be7-4885-80c5-77c64a7460e6_17.pngFix this problem
  2. In the File Download dialog box, click Run, and then follow the steps in the wizard.
Show all
expcol_imgs.pngHow do I determine what is causing my display problem?
expcol_imgs.pngHow do I find out what kind of video card my computer has?
expcol_imgs.pngWhat kind of monitor do I have?
expcol_imgs.pngWhy does my monitor show only limited resolutions?
expcol_imgs.pngWhy am I seeing horizontal lines, flickering, or other strange interference on the screen of my CRT monitor?
expcol_imgs.pngWhat is DirectX and how can I troubleshoot it?
expcol_imgs.pngI've changed the resolution of my monitor, and now I can't see the display.
expcol_imgs.pngWhy does the text on my monitor appear blurry?
expcol_imgs.pngHow do I set up multiple monitors?
expcol_imgs.pngWhy do I get an error when I use different video cards for multiple monitors?
expcol_imgs.pngCan I change the brightness and contrast of my monitor?
Like us on Facebook
Stay in touch with Windows.
Share this page
Apr 25, 2013 | HP Pavilion dv9000z Notebook
Screen is going crazy
Okay, it could be two things, 1.) Your graphics card is either overheated or going out. 2.) it's possible you have a messed up display screen. I'd try looking at your computer display settings and see if you can calibrate the color on your screen to see if it helps or not.
Jun 05, 2012 | ASUS K52F Notebook
My screan is gone pink and purple what can i do
Check that the monitor cable is securely connected to the video card. Also restart the computer. Now just as the computer is starting up, is the text pink/purple? If so, it is likely that your monitor has failed. -Ravi Shanghavi
Aug 19, 2010 | Computers & Internet
Pink/purple vertical line visible
Anytime you see visible lines running through a display, this is usually an sign of an eminent screen failure. It could stay that way for weeks or the lines could multiply and then it could fail. There is no repair for this, only screen replacement.
Feb 20, 2010 | HP w17e Monitor
My NC-10 screen just went crazy. I can tap on the
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
Sep 29, 2009 | Samsung Computers & Internet
Got a used Compaq Pressario SR1303wm and need to set up correctly
Monitor into Small Blue connector at back.
If Mouse and keyboard are Round and not Rectangular in shape then that's a PS/2 Mouse and keyboard. Purple goes into Keyboard slot at back. Green goes into Mouse at back. Watch for the design as the pins inside each one need to be inserted accordingly.
If they ARE rectangular then that is a USB connection. On the back connect the keyborad and mouse to the top two. Again, only going to insert one ways.
Jun 26, 2009 | HP Compaq Presario SR1303wm PC Desktop
Laptop gone crazy
Sounds like a video card problem, take it to a tech store to get it evaluated, there is not much else I can say
Dec 22, 2008 | HP Computers & Internet
My iBook is Sad.
I would connect another monitor to it, if you see the same on the monitor, the videocard/GPU is toast, if not , the onboard display is.
Aug 22, 2008 | Apple iBook G3 Mac Notebook
Picture problems
My computer did this and I think my TVs just gone the same way. Was definitely a loose connection somewhere. In the computer monitor it was because the pins in the plug were slightly bent and if I moved the wire the picture got better. In the end I had to replace the connecting cable
Mar 17, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
