F1 error
Hello friend, thank you for your post!
Based off the information you have provided your question is under an "F13" error code but you also stated that it is showing you an "F1" error. I have researched both error codes for you. "F13" usually indicates error identification, which could be an issue within your control board. "F1" typically can indicate that the range has detected an issue with the runaway temperature (overheating). Both codes could be corrected with a reset, which you can do by flipping the household circuit breaker for roughly ten minutes. If that does not correct the issue I would recommend contacting a professional. I hope this is helpful. -Matt
Was baking, the F1 display begin to sound, over had become very hot/overheated and would not turn off. Had to flip the breaker in the garage because I could not get to the power outlet.
My oven was not in operation and early this AM started beeping with "f1" on the display - I have a frigidaire model ES100 gas sealed range.....
How hard is this to fix, I'll be tackling it myself if possible - I'm a smart girl, just never tried appliance repair before!
I used the self cleaning program and when it was finished I couldn't open the door. had to pull the breaker in order to get the door open. Now it says "F1" and instead of heating to the desired temperature. The temperature keeps getting hotter and hotter like it wants to self clean. I keep pulling the breaker to reset the unit. It says to replace the eoc controller. What is an eoc controller and where can I find it? Thanks
I have the same problem with Frigidaire FEFL77ASA. Where ca I get an EOC, and how hard is it to replace?
Was baking, the F1 display begin to sound, over had become very hot/overheated and would not turn off. The door also locked. Had to flip the breaker in the garage to shut oven off. It comes back on if we turn flip the breaker back on.
