Question about Logitech X-230 Computer Speakers
X230 logitech not working.
Did't know my brother's logitech speakers is 120v. i plugged it in a220v.. help!!! its not working anymore.. pls email me..
  • youresohotth Aug 20, 2008
    didn't know my brother's logitech x230 speakers is 110v, i plugged it in a 220v! thanks
I did the same to mine,
just replace the power transformer with one that accepts 110-240 volts
easy to do, but check cost might be better to buy a new set depends on your situation
Posted on Jun 11, 2009
Schematics for logitech x230 speakers
Hey Jaime,
Unfortunately, Dell does not have any available schematics for wiring the x230 speakers available. You would have to maybe contact Logitech.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 06, 2014 | Dell Dimension 2350 PC Desktop
Broken green pin on logitech x230 can this be replaced
if the green pin is what plugs into your computer, a traditional, headphone 1/8th inch headphone jack, it can be replaced, however there is some soldering involved. Radio shack sells the replaceable ends for just a couple dollars. the only problem is knowing which wires to connect to which points on the new end. i would have to see the wire with the insulation stripped off to be able to tell you which are which
Oct 18, 2012 | Logitech X-230 Computer Speakers
How do i connect my logic speakers x230 to my pc with windows xp
Connect 3.5 mm Jack to the Line out port & get connected your speakers to PC.
Happy to help you.
Apr 24, 2010 | Logitech X-230 Computer Speakers
Tried to connect to samsung lcd no sound
Plug the green lead on the speakers into the headphone socket on the television. You may need to go into the menu to turn up the headphone output. Turn it to 70% on the TV, then use the volume control on the speakers
Jan 10, 2010 | Logitech X-230 Computer Speakers
Will my Logitech X-230 speakers work in a country with 220-240 V power outlets or would i need an adapter to use them there? If i connect them directly to the 240 V outlet, will they run properly or would...
Check the back of your sub to check your voltage range. You will see something like this: 110V-120V or 110V-220V. If you see the later, you are ready to go. If you see 110-120V only, you will need a power converter to power your speakers as well as any other 110-120V equipment. But no matter what, if it is 110-120V DO NOT PLUG DIRECT TO 220V!! It will blow your speakers. (I lived in Germany for 11 years.)
Aug 12, 2009 | Logitech Z-2300 Computer Speakers
My x230 wont work it work for a min then cut out and dont work!!!
Try and twist the jack which is connected to your PC, the solder inside could have snapped. If it has a diferent pwer source for the sound system, then power on, hold the jack and short the ends with your fingertips. If the speakers dont respond then its not getting any power, which could be simple loose connection too. Test both and then decide. If you dont have the correct driver then download from:
Feb 23, 2009 | Logitech X-230 Computer Speakers
Logitech x230 speaker system right hand speaker stopped working
speakers do unfortutionly go bad better just to buy another speaker just watch the ohms should not be more than 8 ohm speaker. please make sure you can return if you buy incorrect.
Nov 18, 2008 | Logitech X-530 Computer Speakers
Crap sound, subwoofer no longer working
Guys try to reinstall your audio drivers, because i had the same exact problem, so find out what sounds card you have and go on their website and download the latest sound card driver
Mar 03, 2008 | Logitech X-230 Computer Speakers
Logitech x230 speakers
Reinstall sound card drivers.
Jan 11, 2007 | Logitech X-230 Computer Speakers
Logitech X-230 Computer Speakers Logo
389 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
