Question about Olympus FE-230 Digital Camera
Wet ok. dont lagh! dropped or should i say camera fell out of pocket, after i flushed the toilet it was only in there for a second or two. was left over night to dry out, but still no luck. is it worth persisting, getting fixed or do i just throw it in the bin?
  • 667 Answers
I've rescued cameras and cel phones from such a fate, but I worked on them while still wet. After they dry, not much hope, sorry
Posted on Aug 20, 2008
SOURCE:
Do you turn the screw to the left or right on a american standard toilet to adjust the water level in the toilet tank
Usually to the right will drop the float, deceasring the water level, left will increase the water level.
Aug 25, 2014 | Cadet Manufacturing American Standard...
Koehler one piece toilet trickling water into tank
The flapper at the bottom of the tank is leaking and needs replacement.
Feb 08, 2014 | Kohler SAILE ELONGATED ONE-PIECE TOILET...
Toilet BLUBS downstairs when flushed upstairs.
Your sewer vent may be clogged, or if you are in the northern climates, frosted shut. When you flush the toilet the water displaces the air in the drain piping. The vent gives the air somewhere to go. If the vent is plugged the dispaced air forces it's way out through the path of least resistance( the lower toilet in this case).Pour some hot water down the vent where it comes through the roof to thaw it out.or run a snake down the vent. Hope this helps.
Jan 01, 2014 | Home
Flush is weakening. Toilet paper won"t flush
Sorry to read about your problem, I hope this helps you out.
i dont think you have toilet issue,
Try this. take a large bucket, like a paint or home depot orange bucket. fill 1/2 way...
put some toilet paper in the toilet. Then pour the water in fast, and see how it flushes. it it does a easy flush then your drain is ok. if its slow, you have a drain issue and not the toilet.
if that the case, then goto the toilet, and clean out all of the little holes, that are around the unit.. where you see the water come out. they can be clogged up. a small type wire like a clothes hanger.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 31, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
Nikon Coolpix S50 lens Problem
No. Water ruins cameras, water and damage due to being dropped is even worse. Now that you've let it sit and dry corrosion will have set into various electronic and mechanical components and there will be residual conductive salts left where the water evaporated.
Your camera is unrepairable. Buy another one and take better care of it, or buy a rugged tough camera designed to be "you proof" or given that it fell down a toilet, maybe that should be "poo proof"...
Feb 08, 2010 | Nikon Coolpix S50 Digital Camera
Water level drops in bowl after it fills
If very little water is used on initial flush, The bowl is functioning as a tank for second thorough flush. The high water level cannot stay high in the bowl while in motion or you would have a mess ion start and stops.
May 28, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
Nokia N70 fell in the toilet
Its better not to use it because even if it be repaired this will not be reliable.
best solution ?
please dont forget to vote if you consider my suggestion helpfull.
Dec 28, 2007 | Nokia 7260 Cellular Phone
Olympus FE-230 Digital Camera Logo
63 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
