Question about Roper RGS7745PQ Dryer
Dryer will not heat up. replaced the cutoff-tml thermostats.
  • Roper Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Posted on Aug 13, 2011
    Brigadier General:
  • 3,301 Answers
3 Suggested Answers
SOURCE:
caroldon
  • 17130 Answers
SOURCE: Have roper electric dryer. That will not start.
Yes as suggested it can easily be confirmed iff you can use a multimeter and trace the power cord to the dryer. The fuse can be found and it must be the fault if the main switch ois working- test with the meter for the switch continuity to confirm.
Posted on Sep 28, 2011
BElectric
  • 1140 Answers
SOURCE: roper dryer heats
Michael: Offsite Experts' Lounge
(Run by experts for experts)
Posted on Dec 13, 2011
Roper dryer heats
Hello James,
The reason the clothes are so hot and the cause of the thermal cutoff going out in the first place was due to very poor air flow through out the dryer causing excessive heat to be built up in the dryer. What needs to be checked is for built up lint in the blower housing and or a blocked/ restricted vent tube.
GENE
Nov 03, 2011 | Roper REX4634KQ Electric Dryer
Dryer runs, no heat, element OK 10.5ohm, Hi limit thermostat .8 ohm, next one is thermal cutoff or operating thermostat, open no meter readings. Part # FSP 3399848 could this be my problem? Thank You
Both the Thermal cutoff and the operating t-stat should have ZERO ohms resistiance 0.8 is fine but open on either they are bad
That part number you have listed is what ya would need..even if only the thermal cutoff is open replace both the thermal cutoff and high limit t-stat at the same time
also if the cycling t-stat is open replace it too...if its fairly modenr and hasa digital display the cycling thermostat is a thermister and at room temp that will be about 5.8 thousand ohms
if has timer the cycling t-stat will look like the high limit t-stat and should be closed
GENE
Aug 29, 2011 | Dryers
Have replaced heat element, thermostat, thermal cutoff, thermal fuse and cycle thermostat on whirlpool dryer. keeps blowing thermal cutoff! Exhaust is clear inside dryer and outside! What is causing all...
I'd like you to try something easy. Set the dryer to Air Fluff and see if the dryer still puts
out Heat let it run for about 2 full minutes If you dryer is still putting out Heat get back to me
Nov 06, 2010 | Whirlpool LER4634J Electric Dryer
I cannot afford a service tech right now to come to the house. I hope you can help me through this service. I have a kenmore elite clothes dryer model # 110.63012101 Dryer was not making any heat. ...
you're doing the right thing except for changing out the element without reading it out first.when you check the parts make sure the dryer is unpluged and that you pull at least one of the wires off the part you're checking. check the thermostats on the heater box part
279769 which is part 47,also remove the duct that the lint filter slides into and clean it,if you have a long vent line remove it from the back of the dryer and blow it out with a leaf blower and if you have a shop vac put it on blow and blow off the motor and blow all the lint from the back inside of dryer so it blows to the front and vac it up so you don't have to pull the drum if you don't want to.the thermal cutoff pops when it gets to hot in the dryer most likely from a back up in the vent line or the duct,also go outside and make sure the vent is clear,you should be fine
Sep 29, 2010 | Kenmore Dryers
I have a kenmore series 80 dryer and i have check the element and it gets 9.4ohm i have check the themal cutoff and that has resistance but the cutoff-tml has no resistance and i dont know if it is an open...
Take a looke4cac94.jpgNumber 1 is open no continuity? That is the problem. The cause of that one blowing is air restrictions.f73ac85.jpg03d0579.jpgVent clogging definately makes that smal limit go bad. If it ain't got continuity it is bad and its cousin
number 3 in the photo above is bad also even if it has continuity.
Why? because it is supposed to shut off at 250f. The limit above it dies at 300f so both are bad and both come together in a packaged9444e5.jpgThe timer is easy to check clip a lead of your meater to the terminal marked RH after you have removed the fat red wire going down to the heater. Try and get continuity from any other terminal on that timer. Turning that timer. If you cannnot get continuity you have a burn leg (very common). Manual and more HERE9994972.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 24, 2010 | Kenmore 62802 Electric Dryer
Kemore dryer model110.67522600, checked continuity on heating element,OK, Thermal fuse OK,cutoff-tml ? Thermostat #3977767 no continuity.Thermostat #3387134 ?
Both the high limit thermostat #3977767 and the operating thermostat #3387134 are normally closed switches and should have continuity. These thermostats are usually replaced as a set because when one fails its often caused damage to the other. The part # for the kit is 279816 and comes with both and is cheaper than if bought separate
Sep 16, 2010 | Kenmore Dryers
Can't control heat setting
Either your dryer vent is clogged, the blower wheel is striped out and not turning or the internal bias thermostat you bought is bad. These are the only things that can make the dryer over heat.
Please rate solution.
Sep 04, 2009 | Whirlpool Dryers
No heat have replaced thermo cutoff
have you checked the heating element with then omns meter?what make?where is the lint filter?-mike
Apr 14, 2009 | Dryers
Clothes dryer not heating
I eventually changed the thermal cutoff switch and the high limit thermostat as suggested in one of your replies to another consumer and now the dryer is working fine. Thanks.
Nov 13, 2008 | Zanussi TC7114W Electric Dryer
Kenmore 80 Series Dryer - No Heat - Thermal Cutoff Kit 279769
that therm. will actually come off the heating element part, it is always good to change both, I use a small screwdriver to get it off
Nov 07, 2008 | Kenmore 63942 Dryer
Dryers Logo
158 people viewed this question
Top Roper Dryers Experts
Craig Butler
Craig Butler
Marvin
Marvin
Dennis Boxerman
Are you a Roper Dryer Expert? Answer questions, earn points and help others
