Question about Philips 50P8341 50" Rear Projection Television
50' Philips tv issues
At first my t.v. would shut off by its self ad continue to do for about 10 minutes, then it would stop and work fine for a couple of days then start turning off again. Now I have to power off and on until the picture pops up and I have no sound now. Do you think this could be the IC chip you talked about in a blog or the Large Signal Board or both or what?
  • Philips Master
  • 3,459 Answers
If you power up/down a bunch of times in a row (10-20 times)
Do you see a bright flash before it shuts down?
If so my guess is a faulty resistor and not the chip I mentioned earlier. I have seen a few posts on this site in regards to faulty resistors on the CRT board(s). If they go bad the set will shut down so that it does not damage the CRT.
Posted on Aug 20, 2008
Power light blinks 4 times pauses then blinks 6
Not sure what the code means (mine occurred after a slight power surge...maybe an overheat or some kind of overload), but after leaving the tv off for 10-15 minutes the flashing stopped and the picture was fine on restart. I know you've probably figured this out already, but hope it helps somebody because Philips apparently does not want to make it easy to figure out what these codes mean.
May 27, 2010 | Philips 50PFP5332D 50 in. Plasma...
Philips 190s turns itself on/off
Mine is a 190s Monitor and not a TV with any kind of remote unit controlling it. I had this issue about a year ago and it sorted it's self after a week or so left turned off. This makes me wonder if it has to do with heat and humidity affecting the micro switches located behind the push button controls on the removable screen surround.
Dec 01, 2009 | Philips 190S8FS 19 inch LCD Monitor
May Magnavox MWC24T5B tv/vcr/dvd combo will not stay on.
I've found the center LED in the VHS player faulty with those symptoms. Change it you'll be fine. Larry
Jun 17, 2009 | Philips Televison & Video
KDS-R60XBR1 Sony Projection SXRD
The lamp may be starting to go, the symptoms you describe are classic warning signs. You could unplug tv let it cool down and check lamp most likely the glass will not look clear maybe a little milky or smoky in areas..dead give away.
Mar 07, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
JVC HD DILA 56G886. replaced lamp and now it shuts down after 10
we found that it is an auto shut off system on the TV due to over heating. The lamp, if not cooled correctly shuts down. We added a mini fan in the back and it seems to work fine now.
Jan 25, 2009 | JVC HD-56G886 56" Rear Projection HDTV
Philips model projection
hello dm beatty, First i must ask if you have anything placed on top of the tv? second what i would suggest is for a professional repairman to come and fix it. There are proceedures which you may do it yourself but if you were to mess up it would cost you a new tv. If you would like more assistance to do it yourself place post again and i will be happy to assist.
Please post what you do and how you did it. I look forward to your posts.
Nov 02, 2008 | Philips 50P8341 50" Rear Projection...
Philips FTR 9964 Receiver Problem
The problem is in your cable connection on the back of your monitor or Box. I had the same problem and solved it by reattaching the VGA cable that was loose.
Nov 14, 2007 | Philips FTR-9964 Tuner/Receiver for Plasma
Phillips 64" PTV Issues
sounds like vertical problems see if you have bad solder connections then get back to me
Nov 02, 2007 | Philips 50P8341 50" Rear Projection...
PHILIPS TV 32PT6441/37 SHUT DOWN
it might be due to
  • plug or socket loose where tv is connected.
  • loose connection in switch.
  • some connector loose in power supply
  •  switching transistor in power supply &horizontal section loose or wire open
  • some capacitor loose in oscilltor section in power supply.
  • if you are not tech. person please take help.
  • hope this will help
  • good luck
Oct 16, 2007 | Philips 32PT6441/37 32" TV
Magnavox 15
IT IS YOUR POWER SOURCE HAD SAME PROBLEM CHANGED POWER PLUG HAS HOT TURNED OFF SINCE
Oct 10, 2007 | Philips Magnavox 15MF400T 15 in. LCD...
Philips 50P8341 50" Rear Projection Television Logo
60 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
